Hi
I’m testing to replace my application from Raspberry PI3B+ to ROCK Pi 4 for performance issues.
My ROCK Pi 4 resetted after few days(one or two) in stress test with heavy load on USB3.0 and Gb Ethernet.
Do you know the cause?
Did anyone check whether there is any problem with this test?
http://www.linux-usb.org/usbtest/
Test environment:
Model: ROCK Pi 4 1GB
OS: ARMBIAN 5.67 user-built Debian GNU/Linux 9 (stretch) 4.4.154-rk3399rockpi4b
USB 3.0 device: 128GB ssd(performance 180GB/s)
Attachment: Heatsink, cooling fan
Gb Ehernet : GbE 8port hub
Core temp while testing: 60 - 70
Gb Ethernet test code:
client(rock pi4):
sudo route add -net 224.0.0.0/4 dev eth0
iperf -c 224.0.55.55 -u -T 32 -t 10000000000000 -i 1 -b 1G --udp-counters-64bit
server(pc):
iperf -s -u -B 224.0.55.55 -i 1 --udp-counters-64bit
USB 3.0 test code(rock pi4):
watch dd if=/dev/sda of=/dev/null
Thank you.
