我试着短接11与13脚
11脚运行官方的mraa pwm.c示例,如下
* Author: Thomas Ingleby <[email protected]>
* Contributors: Manivannan Sadhasivam <[email protected]>
* Copyright (c) 2014 Intel Corporation.
* SPDX-License-Identifier: MIT
* Example usage: Generates PWM signal of period 200us with variable dutycyle
* repeately. Press Ctrl+C to exit
/* standard headers */
#include <signal.h>
#include <stdlib.h>
#include <unistd.h>
/* mraa header */
#include "mraa/pwm.h"
/* PWM declaration */
#define PWM 11
/* PWM period in us */
#define PWM_FREQ 200
volatile sig_atomic_t flag = 1;
void
sig_handler(int signum)
if (signum == SIGINT) {
fprintf(stdout, "Exiting...\n");
flag = 0;
int
main(void)
mraa_result_t status = MRAA_SUCCESS;
mraa_pwm_context pwm;
float value = 0.0f;
float output;
/* initialize mraa for the platform (not needed most of the times) */
mraa_init();
//! [Interesting]
pwm = mraa_pwm_init(PWM);
if (pwm == NULL) {
fprintf(stderr, "Failed to initialize PWM\n");
mraa_deinit();
return EXIT_FAILURE;
/* set PWM period */
status = mraa_pwm_period_us(pwm, PWM_FREQ);
if (status != MRAA_SUCCESS) {
goto err_exit;
/* enable PWM */
status = mraa_pwm_enable(pwm, 1);
goto err_exit;
while (flag) {
value = value + 0.01f;
/* write PWM duty cyle */
status = mraa_pwm_write(pwm, value);
goto err_exit;
usleep(50000);
if (value >= 1.0f) {
value = 0.0f;
/* read PWM duty cyle */
output = mraa_pwm_read(pwm);
fprintf(stdout, "PWM value is %f\n", output);
/* close PWM */
mraa_pwm_close(pwm);
//! [Interesting]
/* deinitialize mraa for the platform (not needed most of the times) */
mraa_deinit();
return EXIT_SUCCESS;
err_exit:
mraa_result_print(status);
/* close PWM */
mraa_deinit();
13脚运行基于官方改的读取pwm的c,如下
#include <signal.h>
#include <stdlib.h>
#include <unistd.h>
/* mraa header */
#define PWM 13
void
flag = 0;
int
main(void)
float value = 0.0f;
float output;
mraa_init();
//! [Interesting]
if (pwm == NULL) {
mraa_deinit();
goto err_exit;
/* enable PWM */
goto err_exit;
while (flag) {
/* value = 0.01f;
write PWM duty cyle
goto err_exit;
usleep(1000000);
value = 0.0f;
usleep(1000000);
/* close PWM */
//! [Interesting]
mraa_deinit();
err_exit:
/* close PWM */
mraa_deinit();
运行结果如下
chen@rockpi4b:~/examples/c/pwm$ sudo ./pwm_in
PWM value is 0.000000
^C
