Got my Rock Pi 4 couple of days ago. Was very excited. And I just can’t boot it up.
I tried:
3 different microSD cards.
6 different images (Armbian, Manjaro ARM minimal / KDE, Ubuntu Bionic, Debian Stretch, Android) found on the Radxa download page and in the wild Internet and burnt with Etcher.
When I plug the power, there is a bright green LED. But then nothing happens, I waited about 2-4 minutes on each image. HDMI output is black, no other LEDs blinking. Network LEDs are blinking but my router doesn’t see any new device.
I also tried to flash SPI using the guide from wiki. I can see the device in maskrom mode (with rkdeveloptool and lsusb), but when I trying to do anything with rkdeveloptool, it just stucks, even with “rid” or “rd” commands. No error, no result, nothing.
I don’t know my wall charger supports QC3 properly, I don’t have any QC-enabled devices. But the box stated QC3 support and there is 9V/2A mode, if letters on the charger don’t lie.
Please, can you help me boot it up or detect a hardware / software problem? Thank you.
I found something. I ran rkdeveloptool on another Linux (Fedora) machine and it fails on each command. I tried rid, rd, rci. Every time I get <command> failed!, like, Reset Device failed!. rkdeveloptool ld and lsusb are showing the device with correct VID & PID. Switch is in H (device) mode.
I have similar problems and I checked the several hints made before:
Hint: Does the light next to the green light blink?
Answer: No
H: Behind the USB, there is a switch, high level is in device mode.
H: Please switch to H, execute lsusb and tell me the result.
A: Switched to H - nothing, can’t execute lsusb because system doesn’t boot
H: The SD card should be inserted facing up towards the board.
A: Correct side up, as shown
In addition: checked HDMI-Cable and connection: Ok, works good with another Linux-machine …
I had inserted an EMMC-Card. In this case appears a message after connecting to power:
“please download + write os image to the eMMC module from rock.sh/pi4 …”
I use a Rock Pi 4 zbh Power Adapter QC 3.0 EU
My conclusion is:
power connction works
eMMC Port ok,
SD-Port damaged.
good news. Just switched back to my linux-monitor. Everything running, I could login to the armbian start-login.
I think I was too impatient …
Regards
Wolfgang
What I found is impossible
Writing the SD card using dd failed to make a bootable card
Writing the SD card with etcher DID make a bootable card.
This is so bizare that I checked 3 times using different block size
dd if=rockpi4-debian-stretch-desktop-arm64-20190730_2022-gpt.img of-/dev/disk2 (whatever you device is) bs=1M (tried 4M and no bs entry)
I was having similar issues with android i used etcher to make the image on sd card didnt work then i used 7zip to unzip the android 9 image and used that “the unzipped iso” and it booted perfectly the board even corrected the kernel im guessing from when i ran debian on it which didnt work out because the desktop was too wide and i couldnt see the panels or edges “can anyone help with that?”
I have the same problem as the TO:
New Rock Pi 4 A 1.4, plus big heatsink, plus 500GB NVME
New 16GB SD-Chip
Downloaded today Ubuntu Server 20.04 from Radxa Downloads
Downloaded today Balena Etcher
Etcher brought twice “Data suddenly interrupted”.
Downloaded the image again. This time flashing went through.
Flashed it on Linux Mint. And then:
Green Led on, nothing on the monitor.
Not yet asking for help, want to try other images first.
I am rather good “with computers”, but with Linux i am still VERY noob.
