Hi I tried using this power supply to power the Radxa 5T, but it wouldn’t boot.
I just get a solid yellow light and nothing else. I tried booting from Nvme and SD card but none of them worked. Anyone else had the same setup?
Electrically that combo should be within spec: Radxa’s ROCK 5T power page lists DC 9-20V input with 12V recommended, and the DC12 60W delivers exactly 12V/5A center positive. So the adapter itself is unlikely to be the mismatch. Radxa’s 5T FAQ says the green LED should light on normal power, so a solid yellow one is worth chasing. Their Rock 5 series troubleshooting FAQ (written with the 5A/5B in mind, but the basics apply) suggests: disconnect all USB devices, make sure the image you flashed is the one built specifically for the 5T since an image for another model will not boot, and check that the flashing tool unpacked the image rather than writing it compressed. On the 5A/5B a blinking blue LED means the board actually booted, so watch the LEDs after a clean reflash. My hypothesis would be the image or flash, not the PSU.
I got it running by unzipping and burning the Armbian image to an SD card, but nothing else works. How do you get it to boot from NVMe, which is more reliable?
Radxa has an official NVMe install guide for the 5T, and since you have a booting SD card you are already half way there. The flow from that guide: boot from the SD card, update the SPI bootloader with the rsetup tool (System Maintenance, then Update SPI Bootloader), then write the system image to the NVMe drive from the running system, roughly xzcat of the image piped into dd onto /dev/nvme0n1, then remove the SD card and boot. Two cautions from the same guide: check with lsblk that the SSD really is nvme0n1 before the dd, because the wrong target device destroys data, and the guide is written for Radxa OS, so if your SD card runs Armbian the rsetup step may not exist there - easiest is to borrow a Radxa OS card for the bootloader step. After the SPI bootloader is updated the board boots straight from NVMe with no SD card inserted.
Can I write the OS to NVMe with a different computer after updating the SPI Bootloader?
Radxa’s official NVMe guide for the 5T only documents writing the image from the running board with dd, so there is no documented PC route I can point to. If you have a USB NVMe adapter, flashing the same image to the NVMe from another computer should work just like flashing an SD card - as far as I can tell the boot step does not depend on which machine wrote the image, once the SPI bootloader is updated. That is my reading, not an official Radxa statement. Same dd caution on the PC: writing the image erases whatever is on the selected drive, so double-check the target device and back up anything on it you still need.
Before I update the SPI loader, can this brick my board, if so can I fix the loader? Can the updated loader still able too boot from SD card? Radxa didn’t state if it could in their instruction
A failed SPI write can stop the board from booting normally. Radxa documents a Maskrom procedure for erasing the 5T’s SPI flash, so there is a documented recovery route, though that isn’t a guarantee for every failure. I couldn’t verify whether the updated loader will boot your Armbian SD card: the NVMe guide uses a microSD card to flash SPI, but doesn’t confirm SD boot afterwards. Radxa’s rsetup docs also say to avoid updating or erasing bootloaders unless necessary, so I’d leave the update alone until that compatibility question is settled.
In case of armbian, to install the correct SPI image for nvme booting, you use armbian-install
I use Radxa OS at the moment. I am just scared of doing the wrong update and bricking the board. I am not sure whether I will lose the SD card boot if I update, so I am always stuck with one media. I assume an SPI update with RSetup is pretty safe, but I want to know it is 100% okay to do, since the RSetup update caused the board to lose the Wi-Fi driver and I spent ages getting it back.
