Hello Radxa Support Team,
We are experiencing an issue with a Radxa ROCK 5T that we purchased through a reseller in China.
Problem:
The ROCK 5T is unable to boot into the operating system. Our technical team has already performed multiple troubleshooting attempts, but the board still cannot boot normally.
Based on our testing so far, we suspect that this may be a hardware-related issue.
Product information:
Model: Radxa ROCK 5T
Serial number (S/N): photo attached
Purchase source: Reseller in China (Pangle Store on Aliexpress)
Troubleshooting already performed:
Reflashed/reinstalled the operating system image
Tested different boot attempts/configurations
Checked the power supply and connections
Repeated the test several times
The board still cannot successfully boot into the OS
We also have photos and videos showing the issue and can provide additional logs, test results, system image/version information, or any other information required by the Radxa technical team.
We previously tried to contact Radxa customer support regarding this issue but have not yet received a response, so we are reaching out directly through the official Radxa forum.
Could the Radxa technical team please help us:
Diagnose whether this is a hardware failure;
Advise us on any additional tests we should perform;
Confirm the warranty/RMA procedure if the board is defective;
Advise whether the board can be sent directly to Radxa for inspection, repair, or replacement.
We would prefer to work directly with Radxa technical support for the diagnosis and RMA process.
We are ready to provide the serial number, purchase documents, photos, videos, and any other information you may need.
Thank you very much for your support. We look forward to your reply.
