I tried everything, only the green light is there (Original powersupply). Now i have this over Uart serial with putty:
someone any ideas??
▒@▒▒` ▒▒▒▒▒▒▒▒▒▒@▒▒▒▒▒▒▒▒G▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒DDR 9fa84341ce typ 24/09/06-09:51:11,fwver: v1.18
ch0 ttot6
ch1 ttot6
ch2 ttot6
ch3 ttot6
ch0 ttot7
LPDDR5, 2400MHz
channel[0] BW=16 Col=10 Bk=16 CS0 Row=16 CS=1 Die BW=16 Size=2048MB
channel[1] BW=16 Col=10 Bk=16 CS0 Row=16 CS=1 Die BW=16 Size=2048MB
channel[2] BW=16 Col=10 Bk=16 CS0 Row=16 CS=1 Die BW=16 Size=2048MB
ch3 ttot7
channel[3] BW=16 Col=10 Bk=16 CS0 Row=16 CS=1 Die BW=16 Size=2048MB
Manufacturer ID:0x6
ch:1 dq0 fail,write:0x1,read:0x0
ch:1 dq1 fail,write:0x2,read:0x0
ch:1 dq2 fail,write:0x4,read:0x0
ch:1 dq3 fail,write:0x8,read:0x0
ch:1 dq4 fail,write:0x10,read:0x20
ch:1 dq5 fail,write:0x20,read:0x40
ch:1 dq6 fail,write:0x40,read:0x80
ch:1 dq7 fail,write:0x80,read:0x0
ch:1 dq8 fail,write:0x100,read:0x2
ch:1 dq9 fail,write:0x200,read:0x4
ch:1 dq10 fail,write:0x400,read:0x8
ch:1 dq11 fail,write:0x800,read:0x10
ch:1 dq12 fail,write:0x1000,read:0x2000
ch:1 dq13 fail,write:0x2000,read:0x4000
ch:1 dq14 fail,write:0x4000,read:0x0
ch:1 dq15 fail,write:0x8000,read:0x0
ch:1 dq0 fail,write:0xfffffffe,read:0x0
ch:1 dq1 fail,write:0xfffffffd,read:0x400
ch:1 dq2 fail,write:0xfffffffb,read:0x0
ch:1 dq3 fail,write:0xfffffff7,read:0x1000
ch:1 dq4 fail,write:0xffffffef,read:0x75ff75df
ch:1 dq5 fail,write:0xffffffdf,read:0x75ff75bf
ch:1 dq6 fail,write:0xffffffbf,read:0x75ff757f
ch:1 dq7 fail,write:0xffffff7f,read:0x0
ch:1 dq8 fail,write:0xfffffeff,read:0x75ff75fd
ch:1 dq9 fail,write:0xfffffdff,read:0x75ff75fb
ch:1 dq10 fail,write:0xfffffbff,read:0x75ff75f7
ch:1 dq11 fail,write:0xfffff7ff,read:0x75ff75ef
ch:1 dq12 fail,write:0xffffefff,read:0x75ff55ff
ch:1 dq13 fail,write:0xffffdfff,read:0x75ff35ff
ch:1 dq14 fail,write:0xffffbfff,read:0x75ff75ff
ch:1 dq15 fail,write:0xffff7fff,read:0x0
ch:2 dq0 fail,write:0x1,read:0x0
ch:2 dq1 fail,write:0x2,read:0x0
ch:2 dq2 fail,write:0x4,read:0x0
ch:2 dq3 fail,write:0x8,read:0x0
ch:2 dq4 fail,write:0x10,read:0x20
ch:2 dq5 fail,write:0x20,read:0x40
ch:2 dq6 fail,write:0x40,read:0x80
ch:2 dq7 fail,write:0x80,read:0x0
ch:2 dq8 fail,write:0x100,read:0x2
ch:2 dq9 fail,write:0x200,read:0x4
ch:2 dq10 fail,write:0x400,read:0x8
ch:2 dq11 fail,write:0x800,read:0x10
ch:2 dq12 fail,write:0x1000,read:0x2000
ch:2 dq13 fail,write:0x2000,read:0x0
ch:2 dq14 fail,write:0x4000,read:0x8000
ch:2 dq15 fail,write:0x8000,read:0x0
ch:2 dq0 fail,write:0xfffffffe,read:0x200
ch:2 dq1 fail,write:0xfffffffd,read:0x0
ch:2 dq2 fail,write:0xfffffffb,read:0x0
ch:2 dq3 fail,write:0xfffffff7,read:0x0
ch:2 dq4 fail,write:0xffffffef,read:0xa2ffa2df
ch:2 dq5 fail,write:0xffffffdf,read:0xa2ffa2bf
ch:2 dq6 fail,write:0xffffffbf,read:0xa2ffa27f
ch:2 dq7 fail,write:0xffffff7f,read:0x0
ch:2 dq8 fail,write:0xfffffeff,read:0xa2ffa2fd
ch:2 dq9 fail,write:0xfffffdff,read:0xa2ffa2fb
ch:2 dq10 fail,write:0xfffffbff,read:0xa2ffa2f7
ch:2 dq11 fail,write:0xfffff7ff,read:0xa2ffa2ef
ch:2 dq12 fail,write:0xffffefff,read:0xa2ff82ff
ch:2 dq13 fail,write:0xffffdfff,read:0xa2ffa2ff
ch:2 dq14 fail,write:0xffffbfff,read:0xa2ff22ff
ch:2 dq15 fail,write:0xffff7fff,read:0x0
error
ERR
With RkdevTool there is fail, too.
