Rock 5C V1.1 not booting thru eMMC/ SD/ USB
Processor RK3588S, not booting through eMMC/ SD/ USB? I’m getting Blank screen in HDMI. Kindly suggest me the solution for troubleshooting ROCK 5C V1.1 Board.
Thanks,
HR
How did u flashed it?
I flashed using eMMC card reader module from Radxa only.
So in short you used the rkdevtools and did you extracted the img.xz file before flashing? It needs to be extracted in .img file. only if flashed with rkdevtools
Thank you. Yes, you are right. I’m following the same process as described by you. Do we have test points in ROCK 5C V1.1 Board, whether i’m getting desired signal or voltage in that particular test points.
Good.. for what its worth I have a guide to help in some points and I suggest you to try arch linux from kwankiu or ubuntu from either joshua or armbian.
More technical stuff Im not your guy. But.. good luck !
Thanks, need more support w.r.t Hardware. I feel like i don’t have any issues in OS. I feel like RK3588S not working.
