After installing Rock 5C on NVME disk using the B1 CLI Image everything works as expected.
After running:
sudo apt update
sudo apt upgrade
the kernel gets updated from 6.1.43-15 to 6.1.43-20. After doing so the device doesn’t boot anymore. Modifying /boot/extlinux/extlinux.conf to use the old kernel makes the device boot sucessfully again.
I tried the same thing with an SD card and after updating the kernel it still boots. Are there any additional steps to take when updating the kernel if booting from NVME disk?
I can’t reproduce this, I suspect it might be caused by a mix of sdcard, emmc and pcie @Mathijs Could you please show the results of running lspci and lsblk in the terminal in your picture?
I have found the key to the problem, please keep using the 15-rk2312 kernel version until we wait for a solution, thanks for the feedback and understanding!
