On the Rock 5C using the Linux 6.1 Debian CLI vendor image (specifically release t8) upon each reboot of the device the Wifi MAC Address changes. This prevents assignment of static IP from DHCP server.
As a work around to set a persistent MAC address do the following.
The Wi-Fi/BT module used in ROCK 5C is AIC8800. To set a fixed Wi-Fi MAC address, you need to write the MAC address to the EFUSE of the AIC8800. The EFUSE MAC address can only be written twice.(it may have already been burned once at the factory). Below is the script and the image I used. Additionally, you need to place an extra bin file in the same directory as the script (I executed it in the /home/radxa directory.).
script: flash_mac.sh flash_mac.zip (994 Bytes)
image: https://github.com/radxa-build/rock-5c-6_1/releases/download/rsdk-t3/rock-5c-6_1_bookworm_kde_t3.output.img.xz
bin: lmacfw_rf_8800d80_u02.bin lmacfw_rf_8800d80_u02.zip (155.7 KB)
I have cleaned the script up a bit to remove the hardcoded paths and kernel version and put some instructions of the process here https://github.com/swdee/aic8800-flash-mac for any one else who wants to do this.
