Yes, USB is definitely not working properly. Or maybe I have configured something wrong in the kernel (I use arm64 defconfig).
This is dmesg from mainline. A bit modest…
root@rock-5b-plus:~# dmesg | grep usb
[ 0.168029] /i2c@feac0000/usb-typec@22/connector: Fixed dependency cycle(s) with /usb@fc000000
[ 0.172849] /i2c@feac0000/usb-typec@22/connector: Fixed dependency cycle(s) with /phy@fed80000
[ 0.173689] /usb@fc000000: Fixed dependency cycle(s) with /phy@fed80000
[ 0.174334] /phy@fed80000: Fixed dependency cycle(s) with /i2c@feac0000/usb-typec@22/connector
[ 0.210977] usbcore: registered new interface driver usbfs
[ 0.211507] usbcore: registered new interface driver hub
[ 0.212029] usbcore: registered new device driver usb
[ 0.408361] usbcore: registered new interface driver usb-storage
[ 0.415507] /i2c@feac0000/usb-typec@22/connector: Fixed dependency cycle(s) with /phy@fed80000
[ 0.416316] /i2c@feac0000/usb-typec@22/connector: Fixed dependency cycle(s) with /usb@fc000000
[ 0.446638] usbcore: registered new interface driver usbhid
[ 0.447130] usbhid: USB HID core driver
[ 1.947852] ehci-platform fc800000.usb: EHCI Host Controller
[ 1.948373] ehci-platform fc800000.usb: new USB bus registered, assigned bus number 1
[ 1.949138] ehci-platform fc800000.usb: irq 90, io mem 0xfc800000
[ 1.951170] ehci-platform fc880000.usb: EHCI Host Controller
[ 1.951679] ohci-platform fc8c0000.usb: Generic Platform OHCI controller
[ 1.951704] ohci-platform fc8c0000.usb: new USB bus registered, assigned bus number 2
[ 1.952404] ehci-platform fc880000.usb: new USB bus registered, assigned bus number 3
[ 1.953162] ohci-platform fc8c0000.usb: irq 92, io mem 0xfc8c0000
[ 1.953861] ehci-platform fc880000.usb: irq 91, io mem 0xfc880000
[ 1.959742] ehci-platform fc800000.usb: USB 2.0 started, EHCI 1.00
[ 1.975736] ehci-platform fc880000.usb: USB 2.0 started, EHCI 1.00
[ 2.207862] usb 1-1: new high-speed USB device number 2 using ehci-platform
[ 4.137949] usb usb5: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 4.689347] usb usb7: We don’t know the algorithms for LPM for this host, disabling LPM.
For comparison same system but with Radxa kernel (rockchip_linux_defconfig)…
[ 7.502707] platform fed80000.phy: Fixed dependency cycle(s) with /i2c@feac0000/fusb302@22/connector
[ 7.596677] usbcore: registered new interface driver usbfs
[ 7.596711] usbcore: registered new interface driver hub
[ 7.596739] usbcore: registered new device driver usb
[ 8.338205] phy phy-fd5d0000.syscon:[email protected]: Looking up phy-supply from device tree
[ 8.338216] phy phy-fd5d0000.syscon:[email protected]: Looking up phy-supply property in node /syscon@fd5d0000/usb2-phy@0/otg-port failed
[ 8.338289] phy phy-fd5d0000.syscon:[email protected]: Looking up vbus-supply from device tree
[ 8.338297] phy phy-fd5d0000.syscon:[email protected]: Looking up vbus-supply property in node /syscon@fd5d0000/usb2-phy@0/otg-port failed
[ 8.339824] phy phy-fd5d8000.syscon:[email protected]: Looking up phy-supply from device tree
[ 8.339835] phy phy-fd5d8000.syscon:[email protected]: Looking up phy-supply property in node /syscon@fd5d8000/usb2-phy@8000/host-port failed
[ 8.341116] phy phy-fd5dc000.syscon:[email protected]: Looking up phy-supply from device tree
[ 8.341126] phy phy-fd5dc000.syscon:[email protected]: Looking up phy-supply property in node /syscon@fd5dc000/usb2-phy@c000/host-port failed
[ 8.342711] phy phy-fd5d4000.syscon:[email protected]: Looking up phy-supply from device tree
[ 8.342721] phy phy-fd5d4000.syscon:[email protected]: Looking up phy-supply property in node /syscon@fd5d4000/usb2-phy@4000/otg-port failed
[ 8.342806] phy phy-fd5d4000.syscon:[email protected]: Looking up vbus-supply from device tree
[ 8.342814] phy phy-fd5d4000.syscon:[email protected]: Looking up vbus-supply property in node /syscon@fd5d4000/usb2-phy@4000/otg-port failed
[ 8.463428] usbcore: registered new interface driver rtl8150
[ 8.463458] usbcore: registered new device driver r8152-cfgselector
[ 8.463489] usbcore: registered new interface driver r8152
[ 8.464012] platform fc000000.usb: Fixed dependency cycle(s) with /i2c@feac0000/fusb302@22
[ 8.480455] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[ 8.480484] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.480500] usb usb1: Product: xHCI Host Controller
[ 8.480512] usb usb1: Manufacturer: Linux 6.1.84-yocto-preempt-rt xhci-hcd
[ 8.480525] usb usb1: SerialNumber: xhci-hcd.12.auto
[ 8.481146] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 8.481147] ehci-platform fc800000.usb: EHCI Host Controller
[ 8.481169] ohci-platform fc840000.usb: Generic Platform OHCI controller
[ 8.481218] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01
[ 8.481224] ehci-platform fc880000.usb: EHCI Host Controller
[ 8.481233] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.481235] ohci-platform fc8c0000.usb: Generic Platform OHCI controller
[ 8.481271] usb usb2: Product: xHCI Host Controller
[ 8.481283] usb usb2: Manufacturer: Linux 6.1.84-yocto-preempt-rt xhci-hcd
[ 8.481296] usb usb2: SerialNumber: xhci-hcd.12.auto
[ 8.481928] phy phy-fd5d4000.syscon:[email protected]: illegal mode
[ 8.481929] ehci-platform fc800000.usb: new USB bus registered, assigned bus number 3
[ 8.482022] ehci-platform fc800000.usb: irq 79, io mem 0xfc800000
[ 8.482057] ehci-platform fc880000.usb: new USB bus registered, assigned bus number 6
[ 8.482060] ohci-platform fc840000.usb: new USB bus registered, assigned bus number 4
[ 8.482101] ohci-platform fc8c0000.usb: new USB bus registered, assigned bus number 5
[ 8.482148] ehci-platform fc880000.usb: irq 80, io mem 0xfc880000
[ 8.482265] ohci-platform fc840000.usb: irq 81, io mem 0xfc840000
[ 8.482304] ohci-platform fc8c0000.usb: irq 82, io mem 0xfc8c0000
[ 8.482622] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[ 8.482640] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.482654] usb usb7: Product: xHCI Host Controller
[ 8.482666] usb usb7: Manufacturer: Linux 6.1.84-yocto-preempt-rt xhci-hcd
[ 8.482679] usb usb7: SerialNumber: xhci-hcd.13.auto
[ 8.483259] usb usb8: We don't know the algorithms for LPM for this host, disabling LPM.
[ 8.483332] usb usb8: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01
[ 8.483350] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.483364] usb usb8: Product: xHCI Host Controller
[ 8.483376] usb usb8: Manufacturer: Linux 6.1.84-yocto-preempt-rt xhci-hcd
[ 8.483389] usb usb8: SerialNumber: xhci-hcd.13.auto
[ 8.483961] usbcore: registered new interface driver cdc_acm
[ 8.484169] usbcore: registered new interface driver uas
[ 8.484235] usbcore: registered new interface driver usb-storage
[ 8.484291] usbcore: registered new interface driver usbserial_generic
[ 8.484313] usbserial: USB Serial support registered for generic
[ 8.484345] usbcore: registered new interface driver aircable
[ 8.484365] usbserial: USB Serial support registered for aircable
[ 8.484393] usbcore: registered new interface driver ark3116
[ 8.484412] usbserial: USB Serial support registered for ark3116
[ 8.484440] usbcore: registered new interface driver belkin_sa
[ 8.484459] usbserial: USB Serial support registered for Belkin / Peracom / GoHubs USB Serial Adapter
[ 8.484490] usbcore: registered new interface driver ch341
[ 8.484509] usbserial: USB Serial support registered for ch341-uart
[ 8.484539] usbcore: registered new interface driver cp210x
[ 8.484558] usbserial: USB Serial support registered for cp210x
[ 8.484600] usbcore: registered new interface driver cyberjack
[ 8.484619] usbserial: USB Serial support registered for Reiner SCT Cyberjack USB card reader
[ 8.484651] usbcore: registered new interface driver cypress_m8
[ 8.484670] usbserial: USB Serial support registered for DeLorme Earthmate USB
[ 8.484691] usbserial: USB Serial support registered for HID->COM RS232 Adapter
[ 8.484711] usbserial: USB Serial support registered for Nokia CA-42 V2 Adapter
[ 8.484741] usbcore: registered new interface driver usb_debug
[ 8.484763] usbserial: USB Serial support registered for debug
[ 8.484782] usbserial: USB Serial support registered for xhci_dbc
[ 8.484811] usbcore: registered new interface driver digi_acceleport
[ 8.484831] usbserial: USB Serial support registered for Digi 2 port USB adapter
[ 8.484851] usbserial: USB Serial support registered for Digi 4 port USB adapter
[ 8.484881] usbcore: registered new interface driver io_edgeport
[ 8.484900] usbserial: USB Serial support registered for Edgeport 2 port adapter
[ 8.484921] usbserial: USB Serial support registered for Edgeport 4 port adapter
[ 8.484941] usbserial: USB Serial support registered for Edgeport 8 port adapter
[ 8.484962] usbserial: USB Serial support registered for EPiC device
[ 8.484995] usbcore: registered new interface driver io_ti
[ 8.485015] usbserial: USB Serial support registered for Edgeport TI 1 port adapter
[ 8.485037] usbserial: USB Serial support registered for Edgeport TI 2 port adapter
[ 8.485069] usbcore: registered new interface driver empeg
[ 8.485089] usbserial: USB Serial support registered for empeg
[ 8.485122] usbcore: registered new interface driver f81534a_ctrl
[ 8.485148] usbcore: registered new interface driver f81232
[ 8.485168] usbserial: USB Serial support registered for f81232
[ 8.485187] usbserial: USB Serial support registered for f81534a
[ 8.485218] usbcore: registered new interface driver f81534
[ 8.485238] usbserial: USB Serial support registered for Fintek F81532/F81534
[ 8.485269] usbcore: registered new interface driver ftdi_sio
[ 8.485288] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 8.485378] usbcore: registered new interface driver garmin_gps
[ 8.485397] usbserial: USB Serial support registered for Garmin GPS usb/tty
[ 8.485426] usbcore: registered new interface driver ipaq
[ 8.485446] usbserial: USB Serial support registered for PocketPC PDA
[ 8.485506] usbcore: registered new interface driver ipw
[ 8.485527] usbserial: USB Serial support registered for IPWireless converter
[ 8.485556] usbcore: registered new interface driver ir_usb
[ 8.485576] usbserial: USB Serial support registered for IR Dongle
[ 8.485605] usbcore: registered new interface driver iuu_phoenix
[ 8.485625] usbserial: USB Serial support registered for iuu_phoenix
[ 8.485653] usbcore: registered new interface driver keyspan
[ 8.485673] usbserial: USB Serial support registered for Keyspan - (without firmware)
[ 8.485694] usbserial: USB Serial support registered for Keyspan 1 port adapter
[ 8.485714] usbserial: USB Serial support registered for Keyspan 2 port adapter
[ 8.485737] usbserial: USB Serial support registered for Keyspan 4 port adapter
[ 8.485770] usbcore: registered new interface driver keyspan_pda
[ 8.485790] usbserial: USB Serial support registered for Keyspan PDA
[ 8.485810] usbserial: USB Serial support registered for Keyspan PDA - (prerenumeration)
[ 8.485841] usbcore: registered new interface driver kl5kusb105
[ 8.485862] usbserial: USB Serial support registered for KL5KUSB105D / PalmConnect
[ 8.485894] usbcore: registered new interface driver kobil_sct
[ 8.485914] usbserial: USB Serial support registered for KOBIL USB smart card terminal
[ 8.485944] usbcore: registered new interface driver mct_u232
[ 8.485964] usbserial: USB Serial support registered for MCT U232
[ 8.485996] usbcore: registered new interface driver metro_usb
[ 8.486017] usbserial: USB Serial support registered for Metrologic USB to Serial
[ 8.486047] usbcore: registered new interface driver mos7720
[ 8.486066] usbserial: USB Serial support registered for Moschip 2 port adapter
[ 8.486097] usbcore: registered new interface driver mos7840
[ 8.486117] usbserial: USB Serial support registered for Moschip 7840/7820 USB Serial Driver
[ 8.486150] usbcore: registered new interface driver mxuport
[ 8.486169] usbserial: USB Serial support registered for MOXA UPort
[ 8.486199] usbcore: registered new interface driver navman
[ 8.486221] usbserial: USB Serial support registered for navman
[ 8.486251] usbcore: registered new interface driver omninet
[ 8.486271] usbserial: USB Serial support registered for ZyXEL - omni.net usb
[ 8.486301] usbcore: registered new interface driver opticon
[ 8.486320] usbserial: USB Serial support registered for opticon
[ 8.486349] usbcore: registered new interface driver option
[ 8.486369] usbserial: USB Serial support registered for GSM modem (1-port)
[ 8.486495] usbcore: registered new interface driver oti6858
[ 8.486515] usbserial: USB Serial support registered for oti6858
[ 8.486546] usbcore: registered new interface driver pl2303
[ 8.486567] usbserial: USB Serial support registered for pl2303
[ 8.486601] usbcore: registered new interface driver qcaux
[ 8.486621] usbserial: USB Serial support registered for qcaux
[ 8.486651] usbcore: registered new interface driver qcserial
[ 8.486671] usbserial: USB Serial support registered for Qualcomm USB modem
[ 8.486711] usbcore: registered new interface driver quatech2
[ 8.486731] usbserial: USB Serial support registered for Quatech 2nd gen USB to Serial Driver
[ 8.486763] usbcore: registered new interface driver safe_serial
[ 8.486805] usbserial: USB Serial support registered for safe_serial
[ 8.486839] usbcore: registered new interface driver sierra
[ 8.486860] usbserial: USB Serial support registered for Sierra USB modem
[ 8.486895] usbcore: registered new interface driver usb_serial_simple
[ 8.486916] usbserial: USB Serial support registered for carelink
[ 8.486938] usbserial: USB Serial support registered for flashloader
[ 8.486959] usbserial: USB Serial support registered for funsoft
[ 8.486978] usbserial: USB Serial support registered for google
[ 8.486999] usbserial: USB Serial support registered for hp4x
[ 8.487019] usbserial: USB Serial support registered for kaufmann
[ 8.487041] usbserial: USB Serial support registered for libtransistor
[ 8.487061] usbserial: USB Serial support registered for moto_modem
[ 8.487081] usbserial: USB Serial support registered for motorola_tetra
[ 8.487102] usbserial: USB Serial support registered for nokia
[ 8.487122] usbserial: USB Serial support registered for novatel_gps
[ 8.487142] usbserial: USB Serial support registered for siemens_mpi
[ 8.487162] usbserial: USB Serial support registered for suunto
[ 8.487183] usbserial: USB Serial support registered for vivopay
[ 8.487202] usbserial: USB Serial support registered for zio
[ 8.487234] usbcore: registered new interface driver spcp8x5
[ 8.487256] usbserial: USB Serial support registered for SPCP8x5
[ 8.487287] usbcore: registered new interface driver ssu100
[ 8.487307] usbserial: USB Serial support registered for Quatech SSU-100 USB to Serial Driver
[ 8.487339] usbcore: registered new interface driver symbolserial
[ 8.487360] usbserial: USB Serial support registered for symbol
[ 8.487389] usbcore: registered new interface driver ti_usb_3410_5052
[ 8.487411] usbserial: USB Serial support registered for TI USB 3410 1 port adapter
[ 8.487433] usbserial: USB Serial support registered for TI USB 5052 2 port adapter
[ 8.487466] usbcore: registered new interface driver upd78f0730
[ 8.487487] usbserial: USB Serial support registered for upd78f0730
[ 8.487519] usbcore: registered new interface driver visor
[ 8.487540] usbserial: USB Serial support registered for Handspring Visor / Palm OS
[ 8.487563] usbserial: USB Serial support registered for Sony Clie 5.0
[ 8.487584] usbserial: USB Serial support registered for Sony Clie 3.5
[ 8.487615] usbcore: registered new interface driver wishbone_serial
[ 8.487636] usbserial: USB Serial support registered for wishbone_serial
[ 8.487666] usbcore: registered new interface driver whiteheat
[ 8.487688] usbserial: USB Serial support registered for Connect Tech - WhiteHEAT - (prerenumeration)
[ 8.487711] usbserial: USB Serial support registered for Connect Tech - WhiteHEAT
[ 8.487743] usbcore: registered new interface driver xr_serial
[ 8.487770] usbserial: USB Serial support registered for xr_serial
[ 8.487801] usbcore: registered new interface driver xsens_mt
[ 8.487822] usbserial: USB Serial support registered for xsens_mt
[ 8.488535] usbcore: registered new interface driver usbtouchscreen
[ 8.494808] ehci-platform fc800000.usb: USB 2.0 started, EHCI 1.00
[ 8.495010] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[ 8.495033] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.495048] usb usb3: Product: EHCI Host Controller
[ 8.495060] usb usb3: Manufacturer: Linux 6.1.84-yocto-preempt-rt ehci_hcd
[ 8.495073] usb usb3: SerialNumber: fc800000.usb
[ 8.510803] ehci-platform fc880000.usb: USB 2.0 started, EHCI 1.00
[ 8.511004] usb usb6: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[ 8.511029] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.511044] usb usb6: Product: EHCI Host Controller
[ 8.511056] usb usb6: Manufacturer: Linux 6.1.84-yocto-preempt-rt ehci_hcd
[ 8.511069] usb usb6: SerialNumber: fc880000.usb
[ 8.513695] typec_fusb302 4-0022: Looking up vbus-supply from device tree
[ 8.543046] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.01
[ 8.543099] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.543135] usb usb5: Product: Generic Platform OHCI controller
[ 8.543166] usb usb5: Manufacturer: Linux 6.1.84-yocto-preempt-rt ohci_hcd
[ 8.543197] usb usb5: SerialNumber: fc8c0000.usb
[ 8.544635] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.01
[ 8.544686] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.544723] usb usb4: Product: Generic Platform OHCI controller
[ 8.544753] usb usb4: Manufacturer: Linux 6.1.84-yocto-preempt-rt ohci_hcd
[ 8.544785] usb usb4: SerialNumber: fc840000.usb
[ 8.548159] usbcore: registered new interface driver uvcvideo
[ 8.550272] usbcore: registered new interface driver bfusb
[ 8.550317] usbcore: registered new interface driver btusb
[ 8.615189] usbcore: registered new interface driver usbhid
[ 8.615217] usbhid: USB HID core driver
[ 8.621501] usbcore: registered new interface driver snd-usb-audio
[ 8.750989] usb 3-1: new high-speed USB device number 2 using ehci-platform
[ 8.908334] usb 3-1: New USB device found, idVendor=1a40, idProduct=0101, bcdDevice= 1.11
[ 8.908387] usb 3-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 8.908418] usb 3-1: Product: USB 2.0 Hub
[ 9.314989] usb 3-1.3: new full-speed USB device number 3 using ehci-platform
[ 9.545721] usb 3-1.3: New USB device found, idVendor=13d3, idProduct=3572, bcdDevice= 0.00
[ 9.545799] usb 3-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 9.545832] usb 3-1.3: Product: Bluetooth Radio
[ 9.545857] usb 3-1.3: Manufacturer: Realtek
[ 9.545882] usb 3-1.3: SerialNumber: 00e04c000001
[ 11.367114] usb 3-1.4: new high-speed USB device number 4 using ehci-platform
[ 11.577626] usb 3-1.4: New USB device found, idVendor=0e8d, idProduct=2000, bcdDevice= 1.00
[ 11.577733] usb 3-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 11.577805] usb 3-1.4: Product: MT65xx Preloader
[ 11.577865] usb 3-1.4: Manufacturer: MediaTek
[ 12.835899] usb 3-1.4: USB disconnect, device number 4
[ 28.775075] usb 3-1.4: new high-speed USB device number 5 using ehci-platform
[ 28.986009] usb 3-1.4: New USB device found, idVendor=0e8d, idProduct=7127, bcdDevice= 0.01
[ 28.986143] usb 3-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 28.986225] usb 3-1.4: Product: FM350-GL
[ 28.986284] usb 3-1.4: Manufacturer: Fibocom Wireless Inc.
[ 29.012417] usbcore: registered new interface driver cdc_ether
[ 29.017430] rndis_host 3-1.4:1.0 eth0: register 'rndis_host' at usb-fc800000.usb-1.4, RNDIS device, 00:00:11:12:13:14
[ 29.017611] usbcore: registered new interface driver rndis_host
[ 29.023542] usbcore: registered new interface driver rndis_wlan
