Rock 5b Plus and decklink sdi micro not work
Hi. i have Rock 5b Plus and m.2 capture Decklink SDI micro
driver setup ok
sdk from bleckmagic compile ok
but when i try capture or play video program not response and only hard reset (5V adapter tern off) help reboot
i use image t2 from radxa
Interesting card:
This sounds like power issues,
What ac adapter are You using? Any other accessories?
Anything left on console?
i use 5V 3A , i can try anothe AC adapter .
not Any other accessories
on console nothing - CTRL-C and CTRL-Z not work , in anothe console “sudo reboot” not rebooting rock5bplus
I don’t know this card much, but for two nvme 3A may be not enough on peak, usually sbc reboots or pcie device disconnects,
leave dmesg -w on one console and check out if there is anything in system log,
check device id with lspci and grep dmesg for any errors on init.
root@rock-5b-plus:/home/radxa# lspci | grep Blackmagic
0001:11:00.0 Multimedia video controller: Blackmagic Design DeckLink SDI Micro
root@rock-5b-plus:/home/radxa# dmesg -w | grep Blackmagic
[ 17.819731] BlackmagicIO: Driver version 14.4.1a4 loading
[ 17.820577] BlackmagicIO: Enabled device “DeckLink SDI Micro” x1/5 GT/s (e8849840,5c1100) FW Date: 06-01 16:36
[ 17.822972] BlackmagicIO: DeckLink SDI Micro as blackmagic!io0 [0001:11:00.0]
[ 17.822979] BlackmagicIO: Initialised serial driver for blackmagic!io0
