On a Rock 5B+ SBC, I have observed the following:
I have a 1TB Samsung Evo Plus NVMe SSD. When I insert this SSD directly into either of the SBC’s NVMe ports, it continuously heats up over time. After 10 minutes, it reaches 45°C, and later, it climbs up to 60°C, even though I am not doing anything with it, it is completely idle (not even mounted).
SMART data after 10 minutes:
I bought an NVMe extension cable from AliExpress (link). Under the same conditions, when I connect the same SSD via this extension cable, it does not heat up. After 10 minutes, the temperature is only 30°C and remains stable.
SMART data after 10 minutes using the extension cable:
Of course, the data is accurate when checked manually, the temperature difference is significantly noticeable.
Can anyone explain this phenomenon?
