Is the m.2 B-key on the Rock 5B+ actually limited to USB 2.0 speeds?
The schematic seems to indicate this is the case, please tell me this isn’t so.
@Peter.Wang can you confirm?
I don’t understand asking such a simple question and even tagging an engineer and still not getting an answer after four days.
Hi, @rooted
You are correct. ROCK 5B+ B Key only supports 4G or 5G modules with USB interface.
I want to know if the m.2 B-key speed is USB 2.0 or USB 3.0?
@rooted m.2 B-key speed is USB 2.0
That’s really a shame, the whole reason I got this device was to port OpenWrt and use it as a 5G gateway but USB 2.0 will limit the speeds and won’t work for this application.
Thanks for the answer.
