Anywhere on the web or in the forum i cannot find list of supported NVMEs. I found out that for RockPi 4 there has been some limitations. I also want to boot from NVME.
Can i simply use any NVME ?
Can you post which NVME is working for you ?
I’m using without any errors or problem:
root@rock-5b:~# nvme list
Node Generic SN Model Namespace Usage Format FW Rev
/dev/nvme0n1 /dev/ng0n1 S34DNX0J904767 SAMSUNG MZVKW1T0HMLH-000H1 1 60,09 GB / 1,02 TB 512 B + 0 B CXA74H0Q
root@rock-5b:~#
Small disclaimer - it’s not RockPi 5B anymore, it’s just ROCK 5B (by Radxa)
Some time ago radxa decided to clean up naming convention
For NVMe - on my side HP Ex900 was not working and WD SN570 works as well as some small hynix drives.
No issues with my 1 TB NVMe. Use it as a bootable disk.
root# nvme list
Node SN Model Namespace Usage Format FW Rev
/dev/nvme0n1 211605A000A7 WDC WDS100T2B0C-00PXH0 1 1.00 TB / 1.00 TB 512 B + 0 B 211210WD
Crucial p3+ 4tb has been working flawless as well:
/dev/nvme0n1 2249E6905238 CT4000P3SSD8 1 4.00 TB / 4.00 TB 512 B 0 B P9CR30A
Disk /dev/nvme0n1: 953.87 GiB, 1024209543168 bytes, 2000409264 sectors
Disk model: Reletech P400 M.2 SSD 1024GB
Chinese SSD no problems.
Kingston NV2 2TB works very well, does not need a heatsink and has low power consumption.
This drive has worked well for me:
Western Digital 500GB WD Blue SN570 NVMe Internal Solid State Drive SSD - Gen3 x4 PCIe 8Gb/s, M.2 2280, Up to 3,500 MB/s - WDS500G3B0C
No problems here with my Nvme. I used also a 2 mm thermalpad to transfer the heat to the metal case. That also has not given me any problems.
/dev/nvme0n1 S6P1NX0TA14325N Samsung SSD 970 EVO Plus 2TB 1 749.64 GB / 2.00 TB 512 B + 0 B 4B2QEXM7
I think a list of those that wont work is better… I mean… what doesnt exactly?
Thought I’d add, I had no such luck with the 970 EVO Plus 2TB, using the Phoenix controller. Would be curious if perhaps you have the Elpis controller version. Mine worked ok for a period with intermittent crashes. Eventually, my 5B simply ceased to recognize it. Wound up moving it to my desktop where it works well.
I replaced the Samsung with the more power efficient SK Hynix P31 Gold. No problems since, and this drive runs cool.
Tested two nvme, all works fine.
I do regularly a firmware update check. I have even made an alias for it. Maybe there is something wrong which the firmware-update has fixed it??
#Check firmware updates + update them
alias update-firmware=‘sudo systemctl start fwupd && sudo fwupdmgr refresh --force && sudo fwupdmgr update’
As you can see on the output down below, it does see the 970 and shows that there is no firmware updates available for it in my case.
EDIT:
<USER>@<DEVICE>:~$ update-firmware
WARNING: UEFI capsule updates not available or enabled in firmware setup
See https://github.com/fwupd/fwupd/wiki/PluginFlag:capsules-unsupported for more information.
Updating lvfs
Downloading? [***************************************]
Successfully downloaded new metadata: 0 local devices supported
Devices with no available firmware updates:
? SSD 970 EVO Plus 2TB
? loader
No updatable devices
