I’ve been lurking here a week now, reading up on all the posts, but I haven’t found a solution to my boot problem yet.
I initially booted with Ubuntu and played around a bit with the Rock 5B, but after about an hour, it randomly stopped working (HDMI died). Since then, I can’t get past the post. I see about half a page of Ubuntu boot messages (maybe 1 second worth), then the HDMI stops, and all I have is a green LED on the board.
So far I have tried the following:
3 different SD cards
the 64GB eMMC from Allnet
5 different USB C power supplies + multiple USB C cables
a Barrel-jack to USB converter, and 2 different 12V power supplies, 3A and 5A
3 different distros
SPI flashing and erasing
The board is not dead, as I can flash the SPI from my Linux box over USB. It just won’t finish booting!
Does anyone have any tips/tricks/ or just advice on returning this thing?
I put the new Armbian image on an SD card, and used the barrel adapter. I saw the boot last way longer this time, maybe 20 seconds of booting, before a green screen of death. Attaching the device to ethernet, and rebooting I see:
Request timeout for icmp_seq 50
Request timeout for icmp_seq 51
64 bytes from 192.168.3.94: icmp_seq=52 ttl=64 time=34.432 ms
64 bytes from 192.168.3.94: icmp_seq=53 ttl=64 time=4.018 ms
64 bytes from 192.168.3.94: icmp_seq=54 ttl=64 time=5.848 ms
64 bytes from 192.168.3.94: icmp_seq=55 ttl=64 time=3.730 ms
64 bytes from 192.168.3.94: icmp_seq=56 ttl=64 time=4.020 ms
64 bytes from 192.168.3.94: icmp_seq=57 ttl=64 time=5.598 ms
64 bytes from 192.168.3.94: icmp_seq=58 ttl=64 time=4.421 ms
Request timeout for icmp_seq 59
Request timeout for icmp_seq 60
Request timeout for icmp_seq 61
Request timeout for icmp_seq 62
so, it was alive for a short time!
On a hunch, I removed the HDMI cable, and it booted!
I can SSH into the system, and run a CPU benchmark etc.
This only word on one of my microSD cards, a cheap old 8Gb card. On my good SanDisk ExtremePro 256Gb, I have the same crash a few seconds into boot (as seen by pinging the board)
On the eMMC, I don’t even get that far. Pinging the board never gets a response
But now I have more weirdness…
If I have keyboard plugged in (I have tried 2 different ones), and I touch any key, at any time, the system crashes instantly!
As I want to use the board with a camera/keyboard, this is a big problem
