Rock 5B doesn’t boot. You can see it in the video that i gave power supply 2 times and the blue led is lighting continiously instead of blinking.
Button number 2 should be lighting on my ATEN KVM switch (that i’m pointing at in the video) if the USB port of Rock 5B is active where the mouse and keyboard
are attached to, but seemingly those USB ports don’t work either. I tried to use all the 4 available USB ports, but none of them is active when the SBC is
powered on. MASKROM and LOADER modes are available, i flashed the SPI NOR successfully, but nothing changed.
Do you guys have any idea what can the problem be? And how the device could be resurrected.
It seems that the EMMC card died. This is the second one in the last 2 weeks.
The board seemingly kills EMMC cards for some reason. Radxa team (@jack , @Stephen, @hipboi) are you aware of this issue? When can we expect a fix for this problem? (If it can be fixed at all…).
1 week / EMMC card is not a good ratio.
What You are using on it? What is brand of your eMMC? Do You have any external eMMC reader?
so far none of my eMMC died on any of my boards but I got one faulty from allnet (and managed to fixed its connector).
