I currently use my Rock 5B as a media server with DietPi as the OS and Jellyfin & Ente Photos.
Will probable add something for streaming music as well later. Other than that only Pi-hole is running on it. I already populated the M.2 slot with either an 500 GB or 1 TB SSD. I don’t remember which and checking is a bit complicated since I removed the sticker thinking it was E-waste only to later find out that the firmware of the external enclosure where I had used it before was the reason why I behaved like it was broken.
What’s important that the M.2 slot is already populated and since it isn’t a 5B+it doesn’t have another.
Now for streaming movies an M.2 SSD is quite helpful (maybe also for streaming music) however for backing up photos and other files an HDD should still do.
I have a spare 2.5’’ 1TB HGST HDD from my PS4 Pro after replacing the HDD with an SSD and there is also a 3.5’’ HDD in my dads PC that he doesn’t need since he doesn’t have that many files on it. I have heard from this post that the Penta SATA HAT isn’t recommended for the Rock 5B/5B+ due to blocking the SOC under it which makes cooling it harder. Currently, I don’t have any cooling on the Rock 5B, neither a heat sink nor a fan. I have 1 Sabrent SATA to USB3.1 (Type A) adapter which comes in quite handy when transferring files while backing stuff up. Since the Rock 5B has two USB3.1 ports I could in theory connect both HDDs using USB with one of those adapters, right? Cause that seems like the most sensible option to me. No need for extra power cables and if I wanted to add cooling to the SOC I’m not limited in any way.
I currently power the Rock 5B with a 30W PD3.0 USB-C to USB-C charger.
