I’m using Android TV version rkr12, it always failed to login Google Account. I can’t use Google Play.
Is that anybody have same issue? And Chrome is always exit automatically.
Rock 5b cannot login Google account on Android TV rkr12 version
yes, i faced the same issue, it might be hard for radxa personnel to test out account functionality due to restriction in china. it will be best to use thc013 android tv build for tv usage.
You need to register the device ID with google. Use this: (for a device that isn’t certified): https://support.google.com/android/answer/10248227?hl=en#zippy=%2Cdevice-isnt-certified
Thanks for your response! I’m not an Android developer, I just want to build a high performance Android TV Box with Rock5b.
Do you have any Android TV build that Google Play works for this device?
You mentioned version thc013 of Android TV. Do you mean it is better that Radxa should use this version to build Android TV image for Rock5b? Or you have your own build for it?
Thanks for your response! I will have a look at the article first.
refer below for the image
