My internal Antenna for my M.2 Wifi module ended up accidentally touching the bottom of the board for about 1 second with it’s aluminum side. It ended up making some noise while powered on and seemingly corrupting the SPI NOR flash. Now it won’t boot. Nothing showing up in serial console and can’t Use Maskrom mode anymore.
I can see both Green and Blue Light indicators at the same time when powered on which leads me to believe U-boot is there but corrupted. Using an SD card with Vendor U-Boot also does nothing. There doesn’t appear to be a guide on unbricking like there is for rock and rock2. Is it bricked for good or is there any chance of recovering it?
Edit:
When I hold down the power button the blue LED turns off. Leaving only the green LED. Pressing it again makes it show up again like normal. However nothing works. The Intensity of the blue LED is seemingly random.
Touched Area:
