I’m currently experiencing a boot loop on the Rock 5B board. I’ve tried several USB power sources with no luck. I’m presuming that’s the problem. If so, I was wondering if it were possible to supply this board with power directly, not needing the USB C? I’m aware this would be at my own risk, but are there pads or pins that could be used to supply power? Otherwise, what specific rating am I looking for when finding an adequate USB C power source?
Just a side note, I was able to run the Rock 5B board for almost a week before this issue happened. It’s not clear to me why the board will no longer boot.
I bought the PSU on allnetchina and experienced system crashes, reboots, so on.
Once I understood the problem I bought a new higher class power supply, I opted for Ugreen 65W, perfect, no problem.
Blue light is blinking when my board runs Debian or Ubuntu etc. I’m using it on sd card. So blue light means your linux is running, just try to reach over ssh if it answers to your ssh request then your problem might be hdmi cable or resolution.
Nothing over SSH, no device found on my router. It’s very clearly boot looping. I can watch my bench supply go through the exact same current profile over and over.
I also left the UART hooked up while trying to boot into maskrom mode, though I have no idea if there should be any output, nor whether the baud would be right (likely not 1.5Mb) but either way, I saw no output there.
Mmm… let me tell you my experiences.
I have no boot problems with official Ubuntu image, also with dedicated PD (a ugreen one 65W) and also with my laptop powered usb-c port, all well done.
I have boot problems with last Armbian image with both methods.
Something like a software problem? So strange…
Armbian: same problem
Different SD card: same problem
Various reset methods: same problem
Official Ubuntu image (assuming “official” means “the one from https://wiki.radxa.com/Rock5/downloads”): same problem
I was kind of expecting there to be some u-boot/firmware update I could try, as this device is straight out of the box as of yesterday… but I can’t really find anything.
Hello everyone,
I am having the same issue as @kusma and have tried different SD cards, the latest Radxa Ubuntu, Debian and Android images. Unfortunately my Rock 5B board is also stuck in a boot loop. Here is what I see with the status LEDs for the Debian image:
supply power via USB-C (85W supply)
green LED turns on for 2s
blue LED turns on for 8s
blue LEDs flashes once and turns off (green stays on)
green LED turns off after 0.5s of blue flashing.
repeat at step 2.
Any ideas what could be causing these issues and how to solve them?
Thanks!
Do the SPI flashing make sure your type c cables are 4k capable (thunderbolt).
If still happens then I suggest you the Samsung 45W which is the one that works for me or a more armbian stable image.
