ROCK 5B 的Android12 sdk 源码如何下载
如题,目前只看到Android12的镜像,想咨询一下对应的sdk源码如何下载,谢谢
https://wiki.radxa.com/Rock5/guide/android12
谢谢回复,我按照这个指导下载的是rk8,编译烧写后发现HWC报错,想咨询一下
radxa:rock-android12 $ repo init -u https://github.com/radxa/manifests.git -b Android12_RK3588_Radxa_rk8 -m rockchip-s-release.xml
radxa:rock-android12 $ repo sync -d --no-tags -j4
1.看到有rk8和rk10两个分支,想咨询一下两个有什么区别,我只能下载rk8,rk10下载提示失败
2.当前rk8能否正常启动,我这个是哪里的问题呀
非常感谢
01-01 12:00:14.066 348 362 E hwc-drm-two: ValidateDisplay,line=1617 init_success_=0 skip.
01-01 12:00:14.066 328 328 E HWComposer: getDeviceCompositionChanges: presentOrValidate failed for display 0: BadDisplay (2)
01-01 12:00:14.066 328 328 E CompositionEngine: chooseCompositionStrategy failed for Internal display: -2147483648 (Unknown error -2147483648)
01-01 12:00:14.066 348 362 E hwc-drm-two: PresentDisplay,line=1314 init_success_=0 skip.
01-01 12:00:14.066 328 328 E HWComposer: presentAndGetReleaseFences: present failed for display 0: BadDisplay (2)
01-01 12:00:14.075 731 731 I mediaserver: ServiceManager: 0xf6f00c90
01-01 12:00:14.075 731 731 W BatteryNotifier: batterystats service unavailable!
01-01 12:00:14.105 679 713 I zygote64: Verified 2763 classes from mainline modules in 173.523ms
01-01 12:00:14.149 348 362 E hwc-drm-two: ValidateDisplay,line=1617 init_success_=0 skip.
01-01 12:00:14.149 328 328 E HWComposer: getDeviceCompositionChanges: presentOrValidate failed for display 0: BadDisplay (2)
01-01 12:00:14.149 328 328 E CompositionEngine: chooseCompositionStrategy failed for Internal display: -2147483648 (Unknown error -2147483648)
01-01 12:00:14.149 348 362 E hwc-drm-two: PresentDisplay,line=1314 init_success_=0 skip.
01-01 12:00:14.149 328 328 E HWComposer: presentAndGetReleaseFences: present failed for display 0: BadDisplay (2)
01-01 12:00:14.165 680 718 I zygote : Verified 2763 classes from mainline modules in 223.722ms
01-01 12:00:14.176 484 666 W ServiceManager: Service package_native didn’t start. Returning NULL
01-01 12:00:14.176 432 432 E [email protected]: Kernel version is 5.10: Permission denied
01-01 12:00:14.176 484 666 E storaged: getService package_native failed
01-01 12:00:14.176 432 432 E [email protected]: Wifi driver is not ready.: Permission denied
01-01 12:00:14.215 679 679 D MtpDeviceJNI: register_android_mtp_MtpDevice
01-01 12:00:14.227 679 679 I zygote64: Thread[1,tid=679,Native,Thread*=0xb400007515dab7b0,peer=0x13980000,“main”] recursive attempt to load library “librtp_jni.so”
01-01 12:00:14.232 348 362 E hwc-drm-two: ValidateDisplay,line=1617 init_success_=0 skip.
01-01 12:00:14.232 328 328 E HWComposer: getDeviceCompositionChanges: presentOrValidate failed for display 0: BadDisplay (2)
01-01 12:00:14.232 328 328 E CompositionEngine: chooseCompositionStrategy failed for Internal display: -2147483648 (Unknown error -2147483648)
01-01 12:00:14.233 348 362 E hwc-drm-two: PresentDisplay,line=1314 init_success_=0 skip.
01-01 12:00:14.233 328 328 E HWComposer: presentAndGetReleaseFences: present failed for display 0: BadDisplay (2)
01-01 12:00:14.266 348 362 E hwc-drm-two: ValidateDisplay,line=1617 init_success_=0 skip.
01-01 12:00:14.266 328 328 E HWComposer: getDeviceCompositionChanges: presentOrValidate failed for display 0: BadDisplay (2)
01-01 12:00:14.266 328 328 E CompositionEngine: chooseCompositionStrategy failed for Internal display: -2147483648 (Unknown error -2147483648)
01-01 12:00:14.266 348 362 E hwc-drm-two: PresentDisplay,line=1314 init_success_=0 skip.
01-01 12:00:14.266 328 328 E HWComposer: presentAndGetReleaseFences: present failed for display 0: BadDisplay (2)
rk10更新一些
rk8 可以启动
你好,请问下
1 RK10分支下载命令是什么呀
2 RK8分支按照官方指导下载代码及yijian编译
the rkr10 manifest is not correct the gitlab repo is missing most of the rkr10 branches only a few are correct
you can also just use the rkr10 manifest from khadas for the edge2
and the uboot, kernel, rksdk etc from the raxda gitlab repo wich are on rkr10 just look at the activity tab to see wich repos are updated on the raxda gitlab .
the major diffrence between rkr8 and rkr10 is hdmi-in and some ai updates for tvbox
i more interested in rkr11 in or rkr12 due there are mpp updates and android 13 is there the rkr10 is already a few moths old
it is just a mess
that isnt there for example
https://gitlab.com/rockchip_android_s/rk/platform/vendor/rockchip/hardware/hardware/-/commit/9285083ed496a0288a50fdac12b119b7cf92fdaf
and the “other” yowo raxda android repo isnt much better .
The link is 404, what do you mean by “refs/tags/android-12.1.0_r8 in the rkr10 xml”
hey Jack
yeah 404 but it should be the rkr10 /vendor/hardware branch download link for raxda android rkr10 branch
Android12_RK3588_Radxa_rk10.xml has
<project name=“rk/platform/vendor/rockchip/hardware/hardware” path=“vendor/rockchip/hardware” remote=“rk” revision=“9285083ed496a0288a50fdac12b119b7cf92fdaf”
so manifest points to the 404 because or the branch is hidden on not yet synced
:frowning: that is indeed a mistake from me about the refs tag
请回答一下第二个问题,为啥用官方指导下载rk8分支代码编译后安卓启动失败呀,hwc异常,log见上,你们能否复现?
你好,请回答一下第二个问题,为啥用官方指导下载rk8分支代码编译后安卓启动失败呀,hwc异常,log见上,你们能否复现?
we are a week in the future but still you didnt fix the manifest !!
and the spi config is not in the source !!
Googletv :slight_smile:
https://drive.google.com/file/d/11QWORSTOsD_40gbDtFgY7x5SzaT0jnjB/view?usp=share_link
thnx for updating :slight_smile:
edit 3-12
the manifest is still not correct
where are ?
gs901
gs-common
gs901-sepolicy
ravioli
aic
car/systemlibs
gchips
hardware/bes
按照 Rock5/guide/android12 - Radxa Wiki步骤
在执行dockerfile那个脚本的时候会报错,为什么呢?
