Rock 5a with A8 Wifi Module unsteady
We experience periodically disconnects from our WLANs with Rock 5a and Wireless Module A8.
We use a Rock 5a with the latest official ubuntu cli build (Release b18 · radxa-build/rock-5a · GitHub), due to compatibility issues with our software, so currently there’s no plan to switch to debian.
the current wpa_supplicant config looks like:
country=DE
ctrl_interface=DIR=/run/wpa_supplicant GROUP=netdev
update_config=1
p2p_disabled=1
network={
    ssid="*internal_ssid*"
    psk=*passphrase*
    priority=1
network={
    ssid="*customer_ssid*"
    psk=*passphrase*
journalctl log example looks like:
wpa_supplicant[629]: wlan0: Associated with 76:1a:e0:e4:cc:80
wpa_supplicant[629]: wlan0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
wpa_supplicant[629]: wlan0: CTRL-EVENT-DISCONNECTED bssid=76:1a:e0:e4:cc:80 reason=15
wpa_supplicant[629]: wlan0: WPA: 4-Way Handshake failed - pre-shared key may be incorrect
wpa_supplicant[629]: wlan0: CTRL-EVENT-SSID-TEMP-DISABLED id=2 ssid="Internet" auth_failures=261 duration=1059 reason=WRONG_KEY
wpa_supplicant[629]: BSSID 76:1a:e0:e4:cc:80 ignore list count incremented to 2, ignoring for 10 seconds
wpa_supplicant[629]: wlan0: CTRL-EVENT-SSID-REENABLED id=2 ssid="Internet"
wpa_supplicant[629]: wlan0: Trying to associate with 76:1a:e0:e4:cc:80 (SSID='Internet' freq=2437 MHz)
wpa_supplicant[629]: nl80211: kernel reports: Match already configured
wpa_supplicant[629]: wlan0: CTRL-EVENT-SSID-TEMP-DISABLED id=2 ssid="Internet" auth_failures=263 duration=1292 reason=WRONG_KEY
wpa_supplicant[629]: wlan0: CTRL-EVENT-SSID-TEMP-DISABLED id=2 ssid="Internet" auth_failures=264 duration=1635 reason=CONN_FAILED
wpa_supplicant[629]: wlan0: CTRL-EVENT-SSID-TEMP-DISABLED id=2 ssid="Internet" auth_failures=265 duration=1728 reason=WRONG_KEY
wpa_supplicant[629]: wlan0: WPA: Key negotiation completed with 76:1a:e0:e4:cc:80 [PTK=CCMP GTK=TKIP]
wpa_supplicant[629]: wlan0: CTRL-EVENT-CONNECTED - Connection to 76:1a:e0:e4:cc:80 completed [id=2 id_str=]
-- Boot 1b46274c46e3405a8cce96b467bbc381 --
systemd[1]: Started WPA supplicant daemon (interface-specific version).
wpa_supplicant[603]: Successfully initialized wpa_supplicant
wpa_supplicant[603]: nl80211: kernel reports: Match already configured
wpa_supplicant[603]: wlan0: CTRL-EVENT-SCAN-FAILED ret=-16 retry=1
wpa_supplicant[603]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=DRIVER type=WORLD
wpa_supplicant[603]: wlan0: Trying to associate with 76:1a:e0:e4:cc:80 (SSID='Internet' freq=2437 MHz)
wpa_supplicant[603]: wlan0: Associated with 76:1a:e0:e4:cc:80
wpa_supplicant[603]: wlan0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
wpa_supplicant[603]: wlan0: WPA: Key negotiation completed with 76:1a:e0:e4:cc:80 [PTK=CCMP GTK=TKIP]
wpa_supplicant[603]: wlan0: CTRL-EVENT-CONNECTED - Connection to 76:1a:e0:e4:cc:80 completed [id=2 id_str=]
multiple issues are bothering me in this log:
  • multiple CTRL-EVENT-SCAN-FAILED ret=-16 retry=1 after reboot
  • dozens of nl80211: kernel reports: Match already configured
  • authentication failures with WRONG_KEY, while the psk is definitely correct, since the device can connect otherwise.
Is there anything I can add or change in my wpa_supplicant config to get rid of the errors and reduce the disconnects? Or at least get the device to reconnect after the errors.
Please try this image: Release b3 (rsdk) · radxa-build/rock-5a · GitHub
Thank you for the link, I am aware of this build and will test it.
Is there a cli-only version of this image, I would prefer to have no kde?
