I’m trying to figure out what memory bandwidth the rock 5A has.
From the RK3588 and RK3588S datasheets it looks like both processors have the same memory bandwidth: four channels of 16-bit LPDDR4/4x or LPDDR5.
The rock 5A has LPDDR4x memory according to the specs, but when I compare the schematics for rock 5A and 5B it looks like there is some difference in the DDR memory to CPU connectivity. Does the 5B use four channels and the 5A only two? I don’t understand the schematics.
In any case, according to https://en.wikipedia.org/wiki/LPDDR the transfer rate of LPDDR4x is 4267 MT/s. With 16 data pins per channel that gives 8,53GB/s per channel. Four channels would then give a theoretical upper limit of 34GB/s. Right?
But are the memory channels “interleaved” so that if I just read data sequentially I will benefit from all four channels? And is each channel equally tightly bound to each core?
I did some experiments with the memory bandwidth benchmark program mbw. I have a Rock 5A with 16GB RAM. The system is a very minimal Armbian image. Only 328MB Ram is used, the rest is free. CPU load is 0.00. Results differed a lot between different runs. See below. Results vary between 3,3GB/s and 22,6GB/s. This number is copy rate, i.e. read + write, so 22GB/s *2 = 44GB/s. But that seems to be more than the theoretical upper limit of 34GB/s I just calculated above?
Can someone explain what’s going on?
root@rocky5-2:/home/enok# mbw 1024 -t2 -b $((1024*1024*16))
Long uses 8 bytes. Allocating 2*134217728 elements = 2147483648 bytes of memory.
Using 16777216 bytes as blocks for memcpy block copy test.
Getting down to business... Doing 10 runs per test.
0 Method: MCBLOCK Elapsed: 0.30637 MiB: 1024.00000 Copy: 3342.353 MiB/s
1 Method: MCBLOCK Elapsed: 0.30460 MiB: 1024.00000 Copy: 3361.775 MiB/s
2 Method: MCBLOCK Elapsed: 0.30420 MiB: 1024.00000 Copy: 3366.251 MiB/s
3 Method: MCBLOCK Elapsed: 0.30426 MiB: 1024.00000 Copy: 3365.532 MiB/s
4 Method: MCBLOCK Elapsed: 0.30397 MiB: 1024.00000 Copy: 3368.709 MiB/s
5 Method: MCBLOCK Elapsed: 0.30193 MiB: 1024.00000 Copy: 3391.548 MiB/s
6 Method: MCBLOCK Elapsed: 0.30176 MiB: 1024.00000 Copy: 3393.380 MiB/s
7 Method: MCBLOCK Elapsed: 0.29961 MiB: 1024.00000 Copy: 3417.833 MiB/s
8 Method: MCBLOCK Elapsed: 0.29930 MiB: 1024.00000 Copy: 3421.362 MiB/s
9 Method: MCBLOCK Elapsed: 0.29951 MiB: 1024.00000 Copy: 3418.918 MiB/s
AVG Method: MCBLOCK Elapsed: 0.30255 MiB: 1024.00000 Copy: 3384.559 MiB/s
0 Method: MCBLOCK Elapsed: 0.30750 MiB: 1024.00000 Copy: 3330.038 MiB/s
1 Method: MCBLOCK Elapsed: 0.30648 MiB: 1024.00000 Copy: 3341.186 MiB/s
2 Method: MCBLOCK Elapsed: 0.30652 MiB: 1024.00000 Copy: 3340.761 MiB/s
3 Method: MCBLOCK Elapsed: 0.30570 MiB: 1024.00000 Copy: 3349.700 MiB/s
4 Method: MCBLOCK Elapsed: 0.30438 MiB: 1024.00000 Copy: 3364.271 MiB/s
5 Method: MCBLOCK Elapsed: 0.30430 MiB: 1024.00000 Copy: 3365.078 MiB/s
6 Method: MCBLOCK Elapsed: 0.30422 MiB: 1024.00000 Copy: 3366.018 MiB/s
7 Method: MCBLOCK Elapsed: 0.30442 MiB: 1024.00000 Copy: 3363.730 MiB/s
8 Method: MCBLOCK Elapsed: 0.30434 MiB: 1024.00000 Copy: 3364.625 MiB/s
9 Method: MCBLOCK Elapsed: 0.30416 MiB: 1024.00000 Copy: 3366.660 MiB/s
AVG Method: MCBLOCK Elapsed: 0.30520 MiB: 1024.00000 Copy: 3355.157 MiB/s
root@rocky5-2:/home/enok# mbw 1024 -t2 -b $((1024*1024))
Using 1048576 bytes as blocks for memcpy block copy test.
0 Method: MCBLOCK Elapsed: 0.27831 MiB: 1024.00000 Copy: 3679.350 MiB/s
1 Method: MCBLOCK Elapsed: 0.27823 MiB: 1024.00000 Copy: 3680.382 MiB/s
2 Method: MCBLOCK Elapsed: 0.27792 MiB: 1024.00000 Copy: 3684.540 MiB/s
3 Method: MCBLOCK Elapsed: 0.27777 MiB: 1024.00000 Copy: 3686.450 MiB/s
4 Method: MCBLOCK Elapsed: 0.27767 MiB: 1024.00000 Copy: 3687.804 MiB/s
5 Method: MCBLOCK Elapsed: 0.27765 MiB: 1024.00000 Copy: 3688.070 MiB/s
6 Method: MCBLOCK Elapsed: 0.27773 MiB: 1024.00000 Copy: 3687.074 MiB/s
7 Method: MCBLOCK Elapsed: 0.27759 MiB: 1024.00000 Copy: 3688.920 MiB/s
8 Method: MCBLOCK Elapsed: 0.27754 MiB: 1024.00000 Copy: 3689.492 MiB/s
9 Method: MCBLOCK Elapsed: 0.27789 MiB: 1024.00000 Copy: 3684.872 MiB/s
AVG Method: MCBLOCK Elapsed: 0.27783 MiB: 1024.00000 Copy: 3685.692 MiB/s
Using 262144 bytes as blocks for memcpy block copy test.
0 Method: MCBLOCK Elapsed: 0.15515 MiB: 1024.00000 Copy: 6599.979 MiB/s
1 Method: MCBLOCK Elapsed: 0.15248 MiB: 1024.00000 Copy: 6715.723 MiB/s
2 Method: MCBLOCK Elapsed: 0.15353 MiB: 1024.00000 Copy: 6669.532 MiB/s
3 Method: MCBLOCK Elapsed: 0.15216 MiB: 1024.00000 Copy: 6729.581 MiB/s
4 Method: MCBLOCK Elapsed: 0.15102 MiB: 1024.00000 Copy: 6780.694 MiB/s
5 Method: MCBLOCK Elapsed: 0.15252 MiB: 1024.00000 Copy: 6714.050 MiB/s
6 Method: MCBLOCK Elapsed: 0.15204 MiB: 1024.00000 Copy: 6734.893 MiB/s
7 Method: MCBLOCK Elapsed: 0.15100 MiB: 1024.00000 Copy: 6781.457 MiB/s
8 Method: MCBLOCK Elapsed: 0.15196 MiB: 1024.00000 Copy: 6738.748 MiB/s
9 Method: MCBLOCK Elapsed: 0.15209 MiB: 1024.00000 Copy: 6732.900 MiB/s
AVG Method: MCBLOCK Elapsed: 0.15240 MiB: 1024.00000 Copy: 6719.376 MiB/s
0 Method: MCBLOCK Elapsed: 0.15048 MiB: 1024.00000 Copy: 6804.755 MiB/s
1 Method: MCBLOCK Elapsed: 0.14979 MiB: 1024.00000 Copy: 6836.146 MiB/s
2 Method: MCBLOCK Elapsed: 0.14968 MiB: 1024.00000 Copy: 6841.490 MiB/s
3 Method: MCBLOCK Elapsed: 0.14930 MiB: 1024.00000 Copy: 6858.490 MiB/s
4 Method: MCBLOCK Elapsed: 0.14919 MiB: 1024.00000 Copy: 6863.777 MiB/s
5 Method: MCBLOCK Elapsed: 0.14912 MiB: 1024.00000 Copy: 6866.815 MiB/s
6 Method: MCBLOCK Elapsed: 0.14767 MiB: 1024.00000 Copy: 6934.475 MiB/s
7 Method: MCBLOCK Elapsed: 0.14780 MiB: 1024.00000 Copy: 6928.141 MiB/s
8 Method: MCBLOCK Elapsed: 0.14778 MiB: 1024.00000 Copy: 6929.125 MiB/s
9 Method: MCBLOCK Elapsed: 0.14797 MiB: 1024.00000 Copy: 6920.322 MiB/s
AVG Method: MCBLOCK Elapsed: 0.14888 MiB: 1024.00000 Copy: 6878.073 MiB/s
0 Method: MEMCPY Elapsed: 0.31557 MiB: 1024.00000 Copy: 3244.942 MiB/s
1 Method: MEMCPY Elapsed: 0.31837 MiB: 1024.00000 Copy: 3216.424 MiB/s
2 Method: MEMCPY Elapsed: 0.31786 MiB: 1024.00000 Copy: 3221.534 MiB/s
3 Method: MEMCPY Elapsed: 0.31565 MiB: 1024.00000 Copy: 3244.058 MiB/s
4 Method: MEMCPY Elapsed: 0.31536 MiB: 1024.00000 Copy: 3247.093 MiB/s
5 Method: MEMCPY Elapsed: 0.31545 MiB: 1024.00000 Copy: 3246.187 MiB/s
6 Method: MEMCPY Elapsed: 0.31552 MiB: 1024.00000 Copy: 3245.436 MiB/s
7 Method: MEMCPY Elapsed: 0.31535 MiB: 1024.00000 Copy: 3247.186 MiB/s
8 Method: MEMCPY Elapsed: 0.31566 MiB: 1024.00000 Copy: 3244.048 MiB/s
9 Method: MEMCPY Elapsed: 0.31542 MiB: 1024.00000 Copy: 3246.455 MiB/s
AVG Method: MEMCPY Elapsed: 0.31602 MiB: 1024.00000 Copy: 3240.300 MiB/s
0 Method: DUMB Elapsed: 0.31287 MiB: 1024.00000 Copy: 3272.904 MiB/s
1 Method: DUMB Elapsed: 0.31269 MiB: 1024.00000 Copy: 3274.777 MiB/s
2 Method: DUMB Elapsed: 0.31289 MiB: 1024.00000 Copy: 3272.684 MiB/s
3 Method: DUMB Elapsed: 0.31298 MiB: 1024.00000 Copy: 3271.795 MiB/s
4 Method: DUMB Elapsed: 0.31280 MiB: 1024.00000 Copy: 3273.626 MiB/s
5 Method: DUMB Elapsed: 0.31286 MiB: 1024.00000 Copy: 3273.029 MiB/s
6 Method: DUMB Elapsed: 0.31268 MiB: 1024.00000 Copy: 3274.924 MiB/s
7 Method: DUMB Elapsed: 0.31267 MiB: 1024.00000 Copy: 3274.966 MiB/s
8 Method: DUMB Elapsed: 0.31289 MiB: 1024.00000 Copy: 3272.716 MiB/s
9 Method: DUMB Elapsed: 0.31281 MiB: 1024.00000 Copy: 3273.532 MiB/s
AVG Method: DUMB Elapsed: 0.31282 MiB: 1024.00000 Copy: 3273.495 MiB/s
0 Method: MCBLOCK Elapsed: 0.16242 MiB: 1024.00000 Copy: 6304.836 MiB/s
1 Method: MCBLOCK Elapsed: 0.16153 MiB: 1024.00000 Copy: 6339.380 MiB/s
2 Method: MCBLOCK Elapsed: 0.16297 MiB: 1024.00000 Copy: 6283.519 MiB/s
3 Method: MCBLOCK Elapsed: 0.16278 MiB: 1024.00000 Copy: 6290.776 MiB/s
4 Method: MCBLOCK Elapsed: 0.16181 MiB: 1024.00000 Copy: 6328.371 MiB/s
5 Method: MCBLOCK Elapsed: 0.16159 MiB: 1024.00000 Copy: 6336.869 MiB/s
6 Method: MCBLOCK Elapsed: 0.16329 MiB: 1024.00000 Copy: 6271.167 MiB/s
7 Method: MCBLOCK Elapsed: 0.16224 MiB: 1024.00000 Copy: 6311.793 MiB/s
8 Method: MCBLOCK Elapsed: 0.16306 MiB: 1024.00000 Copy: 6279.743 MiB/s
9 Method: MCBLOCK Elapsed: 0.16157 MiB: 1024.00000 Copy: 6337.810 MiB/s
AVG Method: MCBLOCK Elapsed: 0.16233 MiB: 1024.00000 Copy: 6308.328 MiB/s
root@rocky5-2:/home/enok# mbw 4096
Long uses 8 bytes. Allocating 2*536870912 elements = 8589934592 bytes of memory.
0 Method: MEMCPY Elapsed: 1.26159 MiB: 4096.00000 Copy: 3246.707 MiB/s
1 Method: MEMCPY Elapsed: 1.20823 MiB: 4096.00000 Copy: 3390.094 MiB/s
2 Method: MEMCPY Elapsed: 0.50646 MiB: 4096.00000 Copy: 8087.477 MiB/s
3 Method: MEMCPY Elapsed: 0.50663 MiB: 4096.00000 Copy: 8084.859 MiB/s
4 Method: MEMCPY Elapsed: 0.50672 MiB: 4096.00000 Copy: 8083.423 MiB/s
5 Method: MEMCPY Elapsed: 0.50682 MiB: 4096.00000 Copy: 8081.733 MiB/s
6 Method: MEMCPY Elapsed: 0.50679 MiB: 4096.00000 Copy: 8082.291 MiB/s
7 Method: MEMCPY Elapsed: 0.50687 MiB: 4096.00000 Copy: 8080.952 MiB/s
8 Method: MEMCPY Elapsed: 0.50697 MiB: 4096.00000 Copy: 8079.294 MiB/s
9 Method: MEMCPY Elapsed: 0.50704 MiB: 4096.00000 Copy: 8078.226 MiB/s
AVG Method: MEMCPY Elapsed: 0.65241 MiB: 4096.00000 Copy: 6278.248 MiB/s
0 Method: DUMB Elapsed: 0.47094 MiB: 4096.00000 Copy: 8697.462 MiB/s
1 Method: DUMB Elapsed: 0.47085 MiB: 4096.00000 Copy: 8699.217 MiB/s
2 Method: DUMB Elapsed: 0.47095 MiB: 4096.00000 Copy: 8697.295 MiB/s
3 Method: DUMB Elapsed: 0.47084 MiB: 4096.00000 Copy: 8699.309 MiB/s
4 Method: DUMB Elapsed: 0.47097 MiB: 4096.00000 Copy: 8696.945 MiB/s
5 Method: DUMB Elapsed: 0.47097 MiB: 4096.00000 Copy: 8697.000 MiB/s
6 Method: DUMB Elapsed: 0.47100 MiB: 4096.00000 Copy: 8696.335 MiB/s
7 Method: DUMB Elapsed: 0.47090 MiB: 4096.00000 Copy: 8698.219 MiB/s
8 Method: DUMB Elapsed: 0.47110 MiB: 4096.00000 Copy: 8694.526 MiB/s
9 Method: DUMB Elapsed: 0.47099 MiB: 4096.00000 Copy: 8696.649 MiB/s
AVG Method: DUMB Elapsed: 0.47095 MiB: 4096.00000 Copy: 8697.295 MiB/s
0 Method: MCBLOCK Elapsed: 0.18193 MiB: 4096.00000 Copy: 22514.525 MiB/s
1 Method: MCBLOCK Elapsed: 0.18064 MiB: 4096.00000 Copy: 22674.431 MiB/s
2 Method: MCBLOCK Elapsed: 0.18076 MiB: 4096.00000 Copy: 22659.755 MiB/s
3 Method: MCBLOCK Elapsed: 0.18101 MiB: 4096.00000 Copy: 22628.334 MiB/s
4 Method: MCBLOCK Elapsed: 0.18088 MiB: 4096.00000 Copy: 22645.473 MiB/s
5 Method: MCBLOCK Elapsed: 0.18073 MiB: 4096.00000 Copy: 22664.144 MiB/s
6 Method: MCBLOCK Elapsed: 0.18074 MiB: 4096.00000 Copy: 22663.015 MiB/s
7 Method: MCBLOCK Elapsed: 0.18090 MiB: 4096.00000 Copy: 22642.469 MiB/s
8 Method: MCBLOCK Elapsed: 0.18069 MiB: 4096.00000 Copy: 22669.161 MiB/s
9 Method: MCBLOCK Elapsed: 0.18072 MiB: 4096.00000 Copy: 22665.272 MiB/s
AVG Method: MCBLOCK Elapsed: 0.18090 MiB: 4096.00000 Copy: 22642.569 MiB/s
0 Method: MEMCPY Elapsed: 0.12354 MiB: 1024.00000 Copy: 8289.149 MiB/s
1 Method: MEMCPY Elapsed: 0.12347 MiB: 1024.00000 Copy: 8293.445 MiB/s
2 Method: MEMCPY Elapsed: 0.12344 MiB: 1024.00000 Copy: 8295.327 MiB/s
3 Method: MEMCPY Elapsed: 0.12349 MiB: 1024.00000 Copy: 8292.169 MiB/s
4 Method: MEMCPY Elapsed: 0.12347 MiB: 1024.00000 Copy: 8293.445 MiB/s
5 Method: MEMCPY Elapsed: 0.12348 MiB: 1024.00000 Copy: 8292.505 MiB/s
6 Method: MEMCPY Elapsed: 0.12348 MiB: 1024.00000 Copy: 8292.639 MiB/s
7 Method: MEMCPY Elapsed: 0.12349 MiB: 1024.00000 Copy: 8291.901 MiB/s
8 Method: MEMCPY Elapsed: 0.12351 MiB: 1024.00000 Copy: 8290.760 MiB/s
9 Method: MEMCPY Elapsed: 0.12351 MiB: 1024.00000 Copy: 8290.961 MiB/s
AVG Method: MEMCPY Elapsed: 0.12349 MiB: 1024.00000 Copy: 8292.230 MiB/s
0 Method: DUMB Elapsed: 0.11363 MiB: 1024.00000 Copy: 9012.101 MiB/s
1 Method: DUMB Elapsed: 0.11368 MiB: 1024.00000 Copy: 9007.820 MiB/s
2 Method: DUMB Elapsed: 0.11363 MiB: 1024.00000 Copy: 9011.387 MiB/s
3 Method: DUMB Elapsed: 0.11359 MiB: 1024.00000 Copy: 9014.799 MiB/s
4 Method: DUMB Elapsed: 0.11362 MiB: 1024.00000 Copy: 9012.418 MiB/s
5 Method: DUMB Elapsed: 0.11471 MiB: 1024.00000 Copy: 8926.703 MiB/s
6 Method: DUMB Elapsed: 0.11366 MiB: 1024.00000 Copy: 9009.564 MiB/s
7 Method: DUMB Elapsed: 0.11361 MiB: 1024.00000 Copy: 9013.053 MiB/s
8 Method: DUMB Elapsed: 0.11363 MiB: 1024.00000 Copy: 9011.625 MiB/s
9 Method: DUMB Elapsed: 0.11363 MiB: 1024.00000 Copy: 9012.022 MiB/s
AVG Method: DUMB Elapsed: 0.11374 MiB: 1024.00000 Copy: 9003.076 MiB/s
0 Method: MCBLOCK Elapsed: 0.05301 MiB: 1024.00000 Copy: 19315.652 MiB/s
1 Method: MCBLOCK Elapsed: 0.05176 MiB: 1024.00000 Copy: 19781.706 MiB/s
2 Method: MCBLOCK Elapsed: 0.05226 MiB: 1024.00000 Copy: 19594.711 MiB/s
3 Method: MCBLOCK Elapsed: 0.05186 MiB: 1024.00000 Copy: 19746.992 MiB/s
4 Method: MCBLOCK Elapsed: 0.05178 MiB: 1024.00000 Copy: 19776.739 MiB/s
5 Method: MCBLOCK Elapsed: 0.05155 MiB: 1024.00000 Copy: 19862.668 MiB/s
6 Method: MCBLOCK Elapsed: 0.05161 MiB: 1024.00000 Copy: 19841.501 MiB/s
7 Method: MCBLOCK Elapsed: 0.05122 MiB: 1024.00000 Copy: 19993.752 MiB/s
8 Method: MCBLOCK Elapsed: 0.05140 MiB: 1024.00000 Copy: 19920.241 MiB/s
9 Method: MCBLOCK Elapsed: 0.05117 MiB: 1024.00000 Copy: 20013.290 MiB/s
AVG Method: MCBLOCK Elapsed: 0.05176 MiB: 1024.00000 Copy: 19782.776 MiB/s
