mara
July 10, 2022, 7:31pm
1
I tried the XFCE image, but it doesn’t boot; maybe tomorrow I’ll hook up a serial console to debug this.
It’s possible that this patch is what is required to get it to boot.
The image references mmcblk0p2 as the root partition, but my µSD card actually appears at mmcblk2. u-boot didn’t manage to get that far anyway
I also manually installed slarm64 to my nvme drive using another u-boot and kernel, though it took a while to get working because findfs couldn’t find my LVM volume by UUID, and after fixing that booting failed at the fsck step because I didn’t update /etc/fstab. However, after logging in via SSH and setting up accounts, trying to log in fails with sshd writing this to syslog:
PAM: pam_setcred(): Authentication failure
If I blank the password entry in /etc/shadow then SSH works again. Logging in via public-key authentication also works.
mara
July 23, 2022, 3:34pm
4
The new ones at least start loading the kernel, but that seems to hang before running init from the initrd… using dyndbg="file * +p" as a command line argument and increasing the verbosity shows these as the last messages on the serial console:
[ 58.829525] rk3x-i2c fd880000.i2c: IRQ: state 3, ipd: 3b
[ 58.830937] Freeing unused kernel memory: 5760K
[ 58.834902] rk3x-i2c fd880000.i2c: Combined write/read from addr 0x42
[ 58.836528] rk3x-i2c fd880000.i2c: IRQ: state 3, ipd: 3b
** 967 console messages dropped **
This was after fixing the DTB name, which is rk3588-rock-5b.dtb but specified as rk3588-rock-rock-5b.dtb in uEnv.txt.
Time to learn how to use kdb?
mara
July 24, 2022, 5:50am
6
Thanks @icecream95 ,
I’ll fix that too, but the kernel is what the radxa team uses for their images.
mmcblk0 179:0 0 14.4G 0 disk
|-mmcblk0p1 179:1 0 512M 0 part
`-mmcblk0p2 179:2 0 13.9G 0 part /
So it is mmcblk0 after all!
It’d probably be better to use the partition UUID for the root device in uEnv.txt and fstab like most other distributions do, in case kernel changes move it around again.
After making that change, the latest image does boot and appears to work well enough. The board tends to reset once during startup because of flaky USB-PD, but that’s no worse than many of the other images at the moment.
The -server images at least are missing the dependencies for quite a few packages—I noticed that man doesn’t work (libseccomp.so.2 is not there), nor does sshfs (libfuse3.so.3), and without libinih.so.0 anyone wanting to install to XFS will have difficulties.
mara
July 29, 2022, 9:41am
9
@icecream95 Thanks, reboot at the first start expands the partition to the entire memory card.
Ive added it on the discord too if you could join it would also be cool for sharing info
waymore
February 10, 2023, 10:47pm
13
Currently I get “Forbidden You don’t have permission to access this resource.”
when trying to access the README.TXT.
mara
February 10, 2023, 11:04pm
14
Access is restored, there are problems with electricity.
mirror
waymore
February 10, 2023, 11:12pm
15
Can confirm I have access now. Thank you.
mara
May 2, 2023, 7:42pm
16
installation README.TXT
kernel 5.10.110
slarm64-current-aarch64-core-rock_5-5.10.110-build-20230502.img.zst
slarm64-current-aarch64-core-rock_5-5.10.110-build-20230502.img.zst.sha256
slarm64-current-aarch64-server-rock_5-5.10.110-build-20230502.img.zst
slarm64-current-aarch64-server-rock_5-5.10.110-build-20230502.img.zst.sha256
slarm64-current-aarch64-xfce-rock_5-5.10.110-build-20230502.img.zst
slarm64-current-aarch64-xfce-rock_5-5.10.110-build-20230502.img.zst.sha256
DDR Version V1.08 20220617
LPDDR4X, 2112MHz
channel[0] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=16 Size=4096MB
channel[1] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=16 Size=4096MB
channel[2] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=16 Size=4096MB
channel[3] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=16 Size=4096MB
Manufacturer ID:0xff
CH0 RX Vref:26.7%, TX Vref:22.8%,22.8%
CH1 RX Vref:29.7%, TX Vref:21.8%,21.8%
CH2 RX Vref:24.7%, TX Vref:24.8%,23.8%
CH3 RX Vref:28.7%, TX Vref:23.8%,23.8%
change to F1: 528MHz
change to F2: 1068MHz
change to F3: 1560MHz
change to F0: 2112MHz
out
U-Boot SPL board init
U-Boot SPL 2017.09-rk3588 (May 02 2023 - 21:59:05)
Trying to boot from MMC1
Trying fit image at 0x4000 sector
## Verified-boot: 0
## Checking atf-1 0x00040000 ... sha256(bb1bbbc832...) + OK
## Checking uboot 0x00200000 ... sha256(375d6e529a...) + OK
## Checking fdt 0x00311908 ... sha256(83adf972b8...) + OK
## Checking atf-2 0x000f0000 ... sha256(30812190d0...) + OK
## Checking atf-3 0xff100000 ... sha256(cb7bdbec2b...) + OK
Jumping to U-Boot(0x00200000) via ARM Trusted Firmware(0x00040000)
Total: 584.47 ms
INFO: Preloader serial: 2
NOTICE: BL31: v2.3():v2.3-499-ge63a16361:derrick.huang
NOTICE: BL31: Built : 10:58:38, Jan 10 2023
INFO: spec: 0x1
INFO: ext 32k is not valid
INFO: ddr: stride-en 4CH
INFO: valid_cpu_msk=0xff bcore0_rst = 0x0, bcore1_rst = 0x0
INFO: system boots from cpu-hwid-0
INFO: idle_st=0x21fff, pd_st=0x11fff9, repair_st=0xfff70001
INFO: dfs DDR fsp_params[0].freq_mhz= 2112MHz
INFO: dfs DDR fsp_params[1].freq_mhz= 528MHz
INFO: dfs DDR fsp_params[2].freq_mhz= 1068MHz
INFO: dfs DDR fsp_params[3].freq_mhz= 1560MHz
INFO: BL31: Initialising Exception Handling Framework
INFO: Entry point address = 0x200000
INFO: SPSR = 0x3c9
U-Boot 2017.09-rk3588 (May 02 2023 - 22:00:59 +0300)
Model: Radxa ROCK 5B
PreSerial: 2, raw, 0xfeb50000
DRAM: 15.7 GiB
Sysmem: init
Relocation Offset: eda65000
Relocation fdt: eb9f95d8 - eb9fecd0
CR: M/C/I
Using default environment
mmc@fe2c0000: 0, mmc@fe2e0000: 1
Bootdev(atags): mmc 0
MMC0: Legacy, 52Mhz
PartType: EFI
DM: v1
boot mode: normal
CLK: (sync kernel. arm: enter 1008000 KHz, init 1008000 KHz, kernel 0N/A)
b0pll 24000 KHz
b1pll 24000 KHz
lpll 24000 KHz
v0pll 24000 KHz
aupll 24000 KHz
cpll 1500000 KHz
gpll 1188000 KHz
npll 24000 KHz
ppll 1100000 KHz
aclk_center_root 702000 KHz
pclk_center_root 100000 KHz
hclk_center_root 396000 KHz
aclk_center_low_root 500000 KHz
aclk_top_root 750000 KHz
pclk_top_root 100000 KHz
aclk_low_top_root 396000 KHz
Net: No ethernet found.
Hit key to stop autoboot('CTRL+C'): 0
switch to partitions #0, OK
mmc0 is current device
mmc@fe2c0000: 0 (SD)
mmc@fe2e0000: 1
Scanning mmc 0:1...
Found U-Boot script /boot.scr
2604 bytes read in 10 ms (253.9 KiB/s)
## Executing script at 00500000
Boot script loaded from mmc 0
173 bytes read in 13 ms (12.7 KiB/s)
250246 bytes read in 127 ms (1.9 MiB/s)
30685696 bytes read in 15022 ms (1.9 MiB/s)
libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND
6397 bytes read in 86 ms (72.3 KiB/s)
Applying kernel provided DT overlay rockchip-rk3588-opp-oc-24ghz.dtbo
** File not found /dtb/rockchip/overlay/rockchip-fixup.scr **
17672258 bytes read in 8165 ms (2.1 MiB/s)
Fdt Ramdisk skip relocation
## Loading init Ramdisk from Legacy Image at 0a200000 ...
Image Name: uInitrd
Image Type: AArch64 Linux RAMDisk Image (gzip compressed)
Data Size: 17672194 Bytes = 16.9 MiB
Load Address: 00000000
Entry Point: 00000000
Verifying Checksum ... OK
## Flattened Device Tree blob at 0x0a100000
Booting using the fdt blob at 0x0a100000
reserving fdt memory region: addr=a100000 size=a3000
'reserved-memory' cma: addr=10000000 size=10000000
'reserved-memory' ramoops@110000: addr=110000 size=f0000
Using Device Tree in place at 000000000a100000, end 000000000a1a5fff
Adding bank: 0x00200000 - 0xf0000000 (size: 0xefe00000)
Adding bank: 0x100000000 - 0x3fc000000 (size: 0x2fc000000)
Adding bank: 0x3fc500000 - 0x3fff00000 (size: 0x03a00000)
Total: 23936.88 ms
Starting kernel ...
[ 25.766532] fiq_debugger fiq_debugger.0: IRQ fiq not found
[ 25.766545] fiq_debugger fiq_debugger.0: IRQ wakeup not found
[ 25.766552] fiq_debugger_probe: could not install nmi irq handler
[ 26.678841] mpp-iep2 fdbb0000.iep: allocate roi buffer failed
[ 26.679327] rk-pcie fe170000.pcie: IRQ msi not found
[ 26.679338] rk-pcie fe170000.pcie: Missing *config* reg space
[ 26.679407] rk-pcie fe170000.pcie: Missing *config* reg space
[ 26.679432] rk-pcie fe170000.pcie: invalid resource
[ 26.690336] rk-pcie fe150000.pcie: IRQ msi not found
[ 26.690369] rk-pcie fe150000.pcie: Missing *config* reg space
[ 26.690497] rk-pcie fe150000.pcie: Missing *config* reg space
[ 26.690534] rk-pcie fe150000.pcie: invalid resource
[ 26.690613] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_a is not found!
[ 26.690622] rkvdec2_init:1008: No niu aclk reset resource define
[ 26.690628] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_h is not found!
[ 26.690634] rkvdec2_init:1011: No niu hclk reset resource define
[ 26.691281] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_a is not found!
[ 26.691288] rkvdec2_init:1008: No niu aclk reset resource define
[ 26.691295] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_h is not found!
[ 26.691300] rkvdec2_init:1011: No niu hclk reset resource define
[ 26.756070] rk806 spi2.0: no sleep-setting state
[ 26.756087] rk806 spi2.0: no reset-setting pinctrl state
[ 26.756094] rk806 spi2.0: no dvs-setting pinctrl state
[ 27.088394] arm-scmi firmware:scmi: Failed. SCMI protocol 17 not active.
[ 27.103427] debugfs: File 'Capture' in directory 'dapm' already present!
[ 27.104444] rk-multicodecs es8316-sound: ASoC: Property 'rockchip,audio-routing' does not exist or its length is not even
[ 27.719817] mmc1: delay init for 600 ms to enable UHS mode
[ 27.721209] debugfs: File 'Left Hp mixer' in directory 'dapm' already present!
[ 27.721257] debugfs: File 'Right Hp mixer' in directory 'dapm' already present!
[ 27.721295] debugfs: File 'HPCP L' in directory 'dapm' already present!
[ 27.721318] debugfs: File 'HPCP R' in directory 'dapm' already present!
[ 27.721348] debugfs: File 'HPVOL L' in directory 'dapm' already present!
[ 27.721370] debugfs: File 'HPVOL R' in directory 'dapm' already present!
[ 27.768422] debugfs: Directory 'fb000000.gpu-mali' with parent 'vdd_gpu_s0' already present!
[ 27.771562] rockchip-dmc dmc: failed to get vop bandwidth to dmc rate
[ 27.771600] rockchip-dmc dmc: failed to get vop pn to msch rl
[ 27.772693] rockchip-dmc dmc: could not find power_model node
[ 27.780291] rk-pcie fe190000.pcie: IRQ msi not found
[ 27.780319] rk-pcie fe190000.pcie: Missing *config* reg space
[ 27.780426] rk-pcie fe190000.pcie: Missing *config* reg space
[ 27.780447] rk-pcie fe190000.pcie: invalid resource
[ 27.784324] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdab0000-0xfdabffff]
[ 27.784363] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdac0000-0xfdacffff]
[ 27.784386] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdad0000-0xfdadffff]
[ 27.788526] debugfs: Directory 'fdab0000.npu-rknpu' with parent 'vdd_npu_s0' already present!
[ 27.810214] RKNPU fdab0000.npu: failed to find power_model node
[ 27.810241] RKNPU fdab0000.npu: RKNPU: failed to initialize power model
[ 27.810254] RKNPU fdab0000.npu: RKNPU: failed to get dynamic-coefficient
[ 29.152386] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_cancel_cpu_limit_freq freq qos nod add
[ 31.355973] BUG: spinlock bad magic on CPU#5, udevd/468
[ 31.356019] lock: 0xffffffc012a29080, .magic: 00000000, .owner: <none>/-1, .owner_cpu: 0
if you want to transfer the system to SDcard to internal memory (eMMC or NAND),
follow transfer-to-disk
slarm64 GNU/Linux (ttyFIQ0)
Kernel 5.10.110 (aarch64)
rock-5 login:
mara
May 13, 2023, 1:57pm
17
kernel 5.10.110
slarm64-current-aarch64-core-rock_5-5.10.110-build-20230513.img.zst
slarm64-current-aarch64-core-rock_5-5.10.110-build-20230513.img.zst.sha256
slarm64-current-aarch64-server-rock_5-5.10.110-build-20230513.img.zst
slarm64-current-aarch64-server-rock_5-5.10.110-build-20230513.img.zst.sha256
slarm64-current-aarch64-xfce-rock_5-5.10.110-build-20230513.img.zst
slarm64-current-aarch64-xfce-rock_5-5.10.110-build-20230513.img.zst.sha256
[ 26.581] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[ 26.581] (==) modeset(0): RGB weight 888
[ 26.581] (==) modeset(0): Default visual is TrueColor
[ 26.581] (II) Loading sub module "glamoregl"
[ 26.581] (II) LoadModule: "glamoregl"
[ 26.581] (II) Loading /usr/lib64/xorg/modules/libglamoregl.so
[ 26.599] (II) Module glamoregl: vendor="X.Org Foundation"
[ 26.599] compiled for 1.21.1.8, module version = 1.0.1
[ 26.599] ABI class: X.Org ANSI C Emulation, version 0.4
[ 27.878] (II) modeset(0): glamor X acceleration enabled on Mali-G610 (Panfrost)
[ 27.879] (II) modeset(0): glamor initialized
[ 27.879] (==) modeset(0): VariableRefresh: disabled
[ 27.879] (==) modeset(0): AsyncFlipSecondaries: disabled
[ 27.879] (II) modeset(0): Output HDMI-1 has no monitor section
[ 28.025] (II) modeset(0): Output HDMI-2 has no monitor section
[ 28.026] (II) modeset(0): Output DP-1 has no monitor section
[ 28.027] (II) modeset(0): EDID for output HDMI-1
[ 28.169] (II) modeset(0): EDID for output HDMI-2
[ 28.169] (II) modeset(0): Manufacturer: SAM Model: f57 Serial#: 810834008
[ 28.169] (II) modeset(0): Year: 2019 Week: 26
[ 28.169] (II) modeset(0): EDID Version: 1.3
[ 28.169] (II) modeset(0): Digital Display Input
[ 28.169] (II) modeset(0): Max Image Size [cm]: horiz.: 60 vert.: 34
[ 28.170] (II) modeset(0): Gamma: 2.20
[ 28.170] (II) modeset(0): DPMS capabilities: Off
[ 28.170] (II) modeset(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[ 28.170] (II) modeset(0): First detailed timing is preferred mode
[ 28.170] (II) modeset(0): redX: 0.652 redY: 0.341 greenX: 0.320 greenY: 0.608
[ 28.170] (II) modeset(0): blueX: 0.146 blueY: 0.065 whiteX: 0.313 whiteY: 0.329
video is played by ffplay and mpv --vo=gpu
mara
May 27, 2023, 10:48am
19
Well, after another power outage, the board stopped working, the power LED lights up on uart, there is also nothing but a little garbage, the power button stopped turning off the board when pressed for a long time.
when connected in a maskrom, the board is determined in the system
> lsusb
Bus 005 Device 018: ID 2207:350b Fuzhou Rockchip Electronics Company
> rkdeveloptool ld
DevNo=1 Vid=0x2207,Pid=0x350b,LocationID=501 Maskrom
if you use the method Install the bootloader to the SPI NOR flash
> rkdeveloptool db rk3588_spl_loader_v1.08.111.bin
Downloading bootloader succeeded.
> rkdeveloptool wl 0 rock-5b-spi-image-g3caf61a44c2-debug.img
Write LBA failed!
> rkdeveloptool wl 0 zero.img
Write LBA failed!
