Hi everyone,
I recently purchased a fan so I could finally check out my board I had been meaning to boot up, and I have not been able to get it booted via SD or eMMC. It just hangs with the green light on, no matter which power supply I tried. It shows up in maskrom, however the RKDevTool fails at any interaction, including reading capability. I plugged it into my UART adapter and I get the below results every time it is plugged in. Can anyone offer any advice?
R Version V1.08 20220617
LPDDR4X, 2112MHz
channel[0] BW=16 Col=10 Bk=8 CS0 Row=16 CS=1 Die BW=16 Size=1024MB
channel[1] BW=16 Col=10 Bk=8 CS0 Row=16 CS=1 Die BW=16 Size=1024MB
channel[2] BW=16 Col=10 Bk=8 CS0 Row=16 CS=1 Die BW=16 Size=1024MB
channel[3] BW=16 Col=10 Bk=8 CS0 Row=16 CS=1 Die BW=16 Size=1024MB
Manufacturer ID:0x6
ch:1 dq0 fail,write:0x1,read:0x2
ch:1 dq1 fail,write:0x2,read:0x4
ch:1 dq2 fail,write:0x4,read:0x8
ch:1 dq3 fail,write:0x8,read:0x10
ch:1 dq4 fail,write:0x10,read:0x20
ch:1 dq5 fail,write:0x20,read:0x40
ch:1 dq6 fail,write:0x40,read:0x80
ch:1 dq7 fail,write:0x80,read:0x0
ch:1 dq8 fail,write:0x100,read:0x200
ch:1 dq9 fail,write:0x200,read:0x400
ch:1 dq10 fail,write:0x400,read:0x800
ch:1 dq11 fail,write:0x800,read:0x1000
ch:1 dq12 fail,write:0x1000,read:0x2000
ch:1 dq13 fail,write:0x2000,read:0x4000
ch:1 dq14 fail,write:0x4000,read:0x8000
ch:1 dq15 fail,write:0x8000,read:0x0
ch:1 dq0 fail,write:0xfffffffe,read:0xfffefffc
ch:1 dq1 fail,write:0xfffffffd,read:0xfffefffa
ch:1 dq2 fail,write:0xfffffffb,read:0xfffefff6
ch:1 dq3 fail,write:0xfffffff7,read:0xfffeffee
ch:1 dq4 fail,write:0xffffffef,read:0xfffeffde
ch:1 dq5 fail,write:0xffffffdf,read:0xfffeffbe
ch:1 dq6 fail,write:0xffffffbf,read:0xfffeff7e
ch:1 dq7 fail,write:0xffffff7f,read:0x0
ch:1 dq8 fail,write:0xfffffeff,read:0xfffefdfe
ch:1 dq9 fail,write:0xfffffdff,read:0xfffefbfe
ch:1 dq10 fail,write:0xfffffbff,read:0xfffef7fe
ch:1 dq11 fail,write:0xfffff7ff,read:0xfffeeffe
ch:1 dq12 fail,write:0xffffefff,read:0xfffedffe
ch:1 dq13 fail,write:0xffffdfff,read:0xfffebffe
ch:1 dq14 fail,write:0xffffbfff,read:0xfffe7ffe
ch:1 dq15 fail,write:0xffff7fff,read:0x0
error
ERR
I purchased this from ameriDroid and waited beyond their 4 week return window unfortunately.
