Hi… Please Help…
HARDWARE
16GB Rock 5 B
WD_Black 2TB SN850X NVME M.2 SSD
PSU
When I first got the Rock, I was unable to reliably boot with the OKdo 36W PSU, so I bought a “dumb” 3V to 24V 5A adjustable PSU and currently have it set to ~15V
PROBLEM
- When the SSD is installed into the Rock 5 B board and I am running the Nethermind Ethereum software, the database on the SSD consistently becomes corrupt, and I believe it’s related to the Rock’s ability to correctly write to the SSD
- Ideally I would run the SSD on board but out of desperation I bought an NVME M.2 SSD USB enclosure to see if it would work that way, but I can’t even mount it and I get an error in the dmesg logs. It works fine when connected to a Raspberry Pi 4
OTHER DETAILS
I have reason to believe that the SSD is fine as I have two of the same model and I have the same issues with both of them
I also have reason to believe that the Rock 5 B board itself is not defective as I have returned and replaced it once
Updating the firmware on the SSD did not help
This is extremely frustrating… Any ideas?
Thank you
md5sum /dev/mtdblock0
$ sudo md5sum /dev/mtdblock0
cf53d06b3bfaaf51bbb6f25896da4b3a /dev/mtdblock0
PROBLEM 1 - Nethermind logs snippet
16 Jul 07:38:28 | Corrupted DB detected on path /ethclient/nethermind/nethermind_db/holesky/state/0. Please restart Nethermind to attempt repair.
16 Jul 07:38:28 | Error when handling response RocksDbSharp.RocksDbException: Corruption: block checksum mismatch: stored = 1863351859, computed = 1623628796, type = 4 in /ethclient/nethermind/nethermind_db/holesky/state/0/000174.sst offset 486728 size 32295
at Nethermind.Db.Rocks.DbOnTheRocks.GetWithColumnFamily(ReadOnlySpan1 key, ColumnFamilyHandle cf, IteratorManager iteratorManager, ReadFlags flags) in /src/Nethermind/Nethermind.Db.Rocks/DbOnTheRocks.cs:line 778 at Nethermind.Trie.NodeStorage.Get(Hash256 address, TreePath& path, ValueHash256& keccak, ReadFlags readFlags) in /src/Nethermind/Nethermind.Trie/NodeStorage.cs:line 115 at Nethermind.Trie.Pruning.TrieStore.IsPersisted(Hash256 address, TreePath& path, ValueHash256& keccak) in /src/Nethermind/Nethermind.Trie/Pruning/TrieStore.cs:line 601 at Nethermind.Synchronization.SnapSync.SnapProviderHelper.IsChildPersisted(TrieNode node, TreePath& nodePath, Int32 childIndex, IScopedTrieStore store) in /src/Nethermind/Nethermind.Synchronization/SnapSync/SnapProviderHelper.cs:line 317 at Nethermind.Synchronization.SnapSync.SnapProviderHelper.StitchBoundaries(List1 sortedBoundaryList, IScopedTrieStore store) in /src/Nethermind/Nethermind.Synchronization/SnapSync/SnapProviderHelper.cs:line 302
at Nethermind.Synchronization.SnapSync.SnapProviderHelper.AddAccountRange(StateTree tree, Int64 blockNumber, ValueHash256& expectedRootHash, ValueHash256& startingHash, ValueHash256& limitHash, IReadOnlyList1 accounts, IReadOnlyList1 proofs) in /src/Nethermind/Nethermind.Synchronization/SnapSync/SnapProviderHelper.cs:line 77
at Nethermind.Synchronization.SnapSync.SnapProvider.AddAccountRange(Int64 blockNumber, ValueHash256& expectedRootHash, ValueHash256& startingHash, IReadOnlyList1 accounts, IReadOnlyList1 proofs, Nullable1& hashLimit) in /src/Nethermind/Nethermind.Synchronization/SnapSync/SnapProvider.cs:line 99 at Nethermind.Synchronization.SnapSync.SnapProvider.AddAccountRange(AccountRange request, AccountsAndProofs response) in /src/Nethermind/Nethermind.Synchronization/SnapSync/SnapProvider.cs:line 62 at Nethermind.Synchronization.SnapSync.SnapSyncFeed.HandleResponse(SnapSyncBatch batch, PeerInfo peer) in /src/Nethermind/Nethermind.Synchronization/SnapSync/SnapSyncFeed.cs:line 63 at Nethermind.Synchronization.ParallelSync.SyncDispatcher1.DoHandleResponse(T request, PeerInfo allocatedPeer) in /src/Nethermind/Nethermind.Synchronization/ParallelSync/SyncDispatcher.cs:line 186
16 Jul 07:38:30 | Corrupted DB detected on path /ethclient/nethermind/nethermind_db/holesky/state/0. Please restart Nethermind to attempt repair.
16 Jul 07:38:30 | Error when handling response RocksDbSharp.RocksDbException: Corruption: block checksum mismatch: stored = 2224436863, computed = 2896197617, type = 4 in /ethclient/nethermind/nethermind_db/holesky/state/0/000193.sst offset 227020 size 32755
PROBLEM 2 - dmesg snippet
[ 35.433743] usb 2-1: new high-speed USB device number 2 using ehci-platform
[ 35.590898] usb 2-1: New USB device found, idVendor=0bda, idProduct=9210, bcdDevice=20.01
[ 35.590928] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 35.590949] usb 2-1: Product: Ugreen Storage Device
[ 35.590968] usb 2-1: Manufacturer: Ugreen
[ 35.590987] usb 2-1: SerialNumber: 0129380513BA
[ 35.684351] usb-storage 2-1:1.0: USB Mass Storage device detected
[ 35.689237] scsi host0: usb-storage 2-1:1.0
[ 35.689576] usbcore: registered new interface driver usb-storage
[ 35.693643] usbcore: registered new interface driver uas
[ 36.705892] scsi 0:0:0:0: Direct-Access Realtek RTL9210 1.00 PQ: 0 ANSI: 6
[ 36.715602] sd 0:0:0:0: [sda] Read Capacity(10) failed: Result: hostbyte=0x00 driverbyte=0x08
[ 36.715615] sd 0:0:0:0: [sda] Sense Key : 0x5 [current]
[ 36.715621] sd 0:0:0:0: [sda] ASC=0x24 ASCQ=0x0
[ 36.715633] sd 0:0:0:0: [sda] 0 512-byte logical blocks: (0 B/0 B)
[ 36.715638] sd 0:0:0:0: [sda] 0-byte physical blocks
[ 36.716340] sd 0:0:0:0: [sda] Write Protect is off
[ 36.716347] sd 0:0:0:0: [sda] Mode Sense: 37 00 00 08
[ 36.720608] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn’t support DPO or FUA
[ 36.752121] sd 0:0:0:0: [sda] Read Capacity(10) failed: Result: hostbyte=0x00 driverbyte=0x08
[ 36.752137] sd 0:0:0:0: [sda] Sense Key : 0x5 [current]
[ 36.752143] sd 0:0:0:0: [sda] ASC=0x24 ASCQ=0x0
[ 36.759654] sd 0:0:0:0: [sda] Attached SCSI disk
