I run a ROCK 5 as a home server and also rent a small VPS in Canada. Because some of what I host involves client data, PIPEDA, BC rules and Quebec Law 25 shaped how I split things up:
1. **Media, local backups and home automation stay on the ROCK 5.** They need fast LAN access, not public uptime.
2. **Anything public goes on the VPS**, so my home IP is never exposed.
3. **The two talk over WireGuard**, with no ports opened on the home router.
4. **Boot from NVMe, not SD**, for anything that writes often. My SD cards died far sooner.
5. **Use a proper power supply and cooling**, because throttling and undervoltage looked like software bugs at first.
6. **Back up each side to the other**, with versioning, so one failure doesn’t take everything.
7. **Keep client data on the VPS in a known Canadian city**, so I can answer when someone asks where it lives.
How do you split workloads between your board and the cloud?
