I am planning a small dual-screen Linux handheld based on the ROCK 4D (RK3576), mainly for Nintendo DS emulation.
My intended setup is:
Top screen: small HDMI display
Bottom screen: 3.5–4.3" MIPI-DSI touch display, used in landscape orientation
Both displays need to run simultaneously as independent outputs
The bottom touchscreen must work correctly, including touch-coordinate rotation
OS: Radxa Debian or another supported Linux image
I found the Waveshare 4-DSI-TOUCH-A (SKU 34354), but its documentation seems focused on Raspberry Pi. Before buying it, I would like to avoid relying on an incompatible DSI connector or Raspberry Pi-specific driver.
Could anyone recommend a small DSI touchscreen that has been actually tested with the ROCK 4D / RK3576?
In particular, I would be grateful for:
The exact display model and compatible FFC cable/adapter
The device-tree overlay or driver configuration required
Confirmation that DSI and HDMI can work simultaneously with separate images
Whether the touchscreen works correctly after rotating the display to landscape
Thank you for any tested setup, documentation, or advice.
