Rock 4C plus Chromium Browser shown " error code :256
Hi All, anyone here can help to resolve my issues as I cannot browser internet even my Wi-Fi is connected.
Thanks in advance
please show the kernel version by the cmd “uname -a”
Hi Nasca,
attached as request.
Thanks
can you try b39 kernel ?
and , is the image you download b60?
yes, from the official website
Would you encounter this issue if you use an Ethernet cable?
I never tried using Ethernet cable before as since the Wi-Fi able to connect.
you can install b39 header and b39 image deb first, then let’s see if this can fix the bug you’re experiencing.
ok thanks for your prompt reply
Hi Nasca, i have this error unable to install
and, do you have the stable OS image? cause since day one (06/08/24) till now i can’t make this to work really frustrated.
Thanks
please open the terminal, then install the kernel packages by the cmd “sudo dpkg -i linux*.deb”
this is what i get
You need to open terminal in the directory containing the kernel packages.
Hi Nasca,
is this correct?
yeah, it’s right.
Then, upon rebooting your system, it will boot with the new kernel.
Hi Nasca,
same
i try to follow the step the 2nd time and this error pop up
