I’ve had it for a couple of months, working fine.
This afternoon, the HDMI just stopped working.
It’s as if the Desktop went to sleep, but now can’t see any wakeup signals (mouse movement, KB) - even though the mouse & KB are clearly working.
I can still login via SSH.
Full details here:
https://www.rs-online.com/designspark/rock-4c-hdmi-stopped-working
Is it broken? What other tests can I do?
Dumb question; Did you try the other hdmi connection ? I have had these flip which port is active.
Yes - see the linked post.
Smarter people than me may have better suggestions, but I would use xrandr to send screen through the other port as long as you have an ssh connection.
I had never tried the other port before - should it “just work”? Should I be seeing something on it anyhow?
But none of this answers the primary question of why the 4K port has stopped working - and what to do about it.
awneil
May 31, 2023, 12:24pm
6
bubbajaysparx:
xrandr
As in this: xrandr - ArchWiki ?
More specifically: Multihead - ArchWiki ?
Update (from the DesignSpark thread):
It had been going through an HDMI switch. Removing the switch and connecting direct to the monitor, it works again!
So that leaves 2 questions:
How come it was working fine for a couple of months, and then just stopped?
How to diagnose what’s going wrong when using the switch?
Note that other devices (a Windows PC; a Raspberry Pi) still work fine through the switch.
awneil
August 1, 2023, 8:30pm
8
Somebody else having trouble with the HDMI output from a Rock Pi 4:
I’m working with a RockPi4 using DietPi. Now I’m facing an issue with a projector which doesn’t get recognized at the startup and the only way I found it to be tricked is starting up with another screen and then switching plugs. I’ve just purchased one of those HDMI plugs that might solve it but, in the meantime and cause I may need it for other purposes what I’ve seen is the “soft” solution which I’ve seen that in other SBCs is as simple as adding “hdmi_force_hotplug=1” in the config.txt. …
maybe more:
https://forum.radxa.com/t/rock-pi-4c-plus-defective
