Hi.
I have installed the Debian 11 image on a Rock 4 SE.
https://github.com/radxa-build/rock-4se/releases/download/20230312-1521/rock-4se_debian_bullseye_kde_b33.img.xz
The system works OK but the WiFi configuration is wrong. I cannot see all the WiFi channels. I think this is because the WiFi country:
root@rock-4se:~# iw reg get
global
country 00: DFS-UNSET
(2402 - 2472 @ 40), (6, 20), (N/A)
(2457 - 2482 @ 20), (6, 20), (N/A), AUTO-BW, PASSIVE-SCAN
(2474 - 2494 @ 20), (6, 20), (N/A), NO-OFDM, PASSIVE-SCAN
(5170 - 5250 @ 80), (6, 20), (N/A), AUTO-BW, PASSIVE-SCAN
(5250 - 5330 @ 80), (6, 20), (0 ms), DFS, AUTO-BW, PASSIVE-SCAN
(5490 - 5730 @ 160), (6, 20), (0 ms), DFS, PASSIVE-SCAN
(5735 - 5835 @ 80), (6, 20), (N/A), PASSIVE-SCAN
(57240 - 63720 @ 2160), (N/A, 0), (N/A)
If I try to set the country to ES, there is no change. I have also used the rsetup utility.
Maybe the error comes from this one in dmesg:
[ 20.718877] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 20.739776] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 20.741631] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 20.742135] cfg80211: failed to load regulatory.db
Any suggestions?
