It has taken me weeks to get a Rock 4 SE + OV5647 Camera working. It seems none of the documentation out there provide a clear or working set of steps, using the latest kernel and latest OS.
This post was going to be to ask for help, but I finally have something basic that works, so I thought I’d share it for anyone else interested and ask for comments. Would this make useful documentation? How could the approach be improved?
My set up is using a Rock 4 SE and a 5M Camera (OV5647 sensor). I have:
- Installed
rockpi4-debian-stretch-desktop-arm64-20190730_2022-gpt - Ran, $
rsetup> Overlays > Manage Overlays > Enable OKdo 5MP Camera - Rebooted
- Installed v4l2-utils
sudo apt-get update sudo apt-get install v4l-utils
List the video devices:
v4l2-ctl --list-devices
rkisp1-statistics (platform: rkisp1):
/dev/video3
/dev/video4
rkisp1_mainpath (platform:ff910000.rkisp1):
/dev/video0
/dev/video1
/dev/video2
rkisp1 (platform:rkisp1):
/dev/media0
List formats of /dev/video0:
v4l2-ctl -d /dev/video0 --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
Type: Video Capture Multiplanar
[0]: 'YUYV' (YUYV 4:2:2)
Size: Stepwise 32x16 - 2592x1944 with step 8/8
[1]: '422P' (Planar YUV 4:2:2)
[2]: 'NV16' (Y/CbCr 4:2:2)
[3]: 'NV61' (Y/CrCb 4:2:2)
[4]: 'YM16' (Planar YUV 4:2:2 (N-C))
[5]: 'NV21' (Y/CrCb 4:2:0)
[6]: 'NV12' (Y/CbCr 4:2:0)
[7]: 'NM21' (Y/CrCb 4:2:0 (N-C))
[8]: 'NM12' (Y/CbCr 4:2:0 (N-C))
[9]: 'YU12' (Planar YUV 4:2:0)
[10]: 'YM24' (Planar YUV 4:4:4 (N-C))
[11]: 'RGGB' (8-bit Bayer RGRG/GBGB)
[12]: 'GRBG' (8-bit Bayer GRGR/BGBG)
[13]: 'GBRG' (8-bit Bayer GBGB/RGRG)
[14]: 'BA81' (8-bit Bayer BGBG/GRGR)
[15]: 'RG10' (10-bit Bayer RGRG/GBGB)
[16]: 'BA10' (10-bit Bayer GRGR/BGBG)
[17]: 'GB10' (10-bit Bayer GBGB/RGRG)
[18]: 'BG10' (10-bit Bayer BGBG/GRGR)
[19]: 'RG12' (12-bit Bayer RGRG/GBGB)
[20]: 'BA12' (12-bit Bayer GRGR/BGBG)
[21]: 'GB12' (12-bit Bayer GBGB/RGRG)
[22]: 'BG12' (12-bit Bayer BGBG/GRGR)
Get the format details of device video0, format 0
v4l2-ctl --verbose -d /dev/video0 --get-fmt-video
VIDIOC_QUERYCAP: ok
VIDIOC_G_FMT: ok
Format Video Capture Multiplanar:
Width/Height : 2592/1944
Pixel Format : 'YUYV' (YUYV 4:2:2)
Field : None
Number of planes : 1
Flags :
Colorspace : sRGB
Transfer Function : Rec. 709
YCbCr/HSV Encoding: Rec. 709
Quantization : Full Range
Plane 0 :
Bytes per Line : 5184
Size Image : 10077696
List controls for /dev/video0
v4l2-ctl -d /dev/video0 -l
#or
v4l2-ctl --all
User Controls
white_balance_automatic 0x0098090c (bool) : default=0 value=0
exposure 0x00980911 (int) : min=4 max=1964 step=1 default=1000 value=886
gain_automatic 0x00980912 (bool) : default=0 value=0
horizontal_flip 0x00980914 (bool) : default=0 value=0 flags=modify-layout
vertical_flip 0x00980915 (bool) : default=0 value=0 flags=modify-layout
Camera Controls
auto_exposure 0x009a0901 (menu) : min=0 max=1 default=1 value=0
0: Auto Mode
1: Manual Mode
Turn auto exposure on
v4l2-ctl -d /dev/video0 -c auto_exposure=0
Capture a still
This includes capturing as yuyv and swabing to uyvy which is supported by image magic convert, the converting to png. It also includes skipping three frames, which improves the exposure for some crazy reason.
v4l2-ctl -d /dev/video0 --set-fmt-video=width=2592,height=1944,pixelformat=YUYV --stream-mmap=3 --stream-skip=3 --stream-count=1 --stream-to=test.yuyv
dd if=test.yuyv conv=swab > test.uyvy
convert -sampling-factor 4:2:2 -size 2592x1944 -depth 8 test.uyvy test.png
