I have a Rock 4 SE from Radxa and I’d like to control a fan. I want it to turn on when the temperature reaches a certain threshold, for example, between 50°C and 60°C. etc.
I’ve connected the fan to the following pins:
PIN#11 PWM0 GPIO4_C2 (Blue)
PIN#4 +5.0V(Red)
PIN#6 GND (Black)
Is this wiring correct?
Is there any way or script available to control the fan based on temperature?
what overlay is needed on other OS?
Hi, do you find a solution? If not, I have just developed a script to manage the fan speed based on the CPU temperature. Remember to enable the PWM pin in your SO.
You can find the project on GitHub (I’m not able to post the direct link): albertopiva/linux-fan-manager
Hi! I recently found this post and tried your script on LibreELEC but I could not make use of it and whatever I tried to do I got issues with the device or resource being busy. I decided to post on the LibreELEC-forum and got a response that the script seemed to be built for an older kernel than what they use, do you think it could be possible to see if maybe it is possible to mod your script to also work with LibreELEC?
Thanks for the good work! It looks nice and I hope I can make use of it
I have absolutely no idea about that, but what I’ve managed to find so far is that LibreELEC is using kernel 6.6 and has libgpiod v2.2 present. I managed to control my PWM fan by hooking up the 5V wire (red) to pin 2, ground (black) to pin 6 and pwm-wire (blue) to pin 11 (GPIO4_C2). Then I can turn the fan on and off by performing gpioset -c 4 18=0 and gpioset -c 4 18=1. I have tried a small bash script in which I simulate some sort of pulse which seem to be working:
for i in $(seq 1 500 ); do gpioset -p 10ms -t0 -c 4 18=1; gpioset -p 10ms -t0 -c 4 18=0; done
Below is a list of the pwm-folders on the system, as noticed there is no “pwm0”-folder present and when trying to enable it (echo 0 > /sys/class/pwm/pwmchip0/export) you are faced with a Device or resource busy error (maybe because it probably should be pwmchip4 and not pwmchip0, but no other chip is present in the folder).
Below you can see the folder structures (also posted on the LibreELEC-forum):
First off this kills any previous gpioset command on the relevant gpio-pin since you cannot “overwrite” a running process by creating a new one on the same pin.
Then this apparently sends a signal each 300µs followed by another signal 100µs later with the t-flag and demonizes it with the -z-flag, and this is what seems to be called software PWM which shows in htop where it seems to linger somewhere between 4 and 6% CPU.
This (I think) makes up a generated PWM signal of 25kHz with 25% duty cycle (sources wikipedia, Noctua PWM whitepaper, gpioset man-page).
As far as I can tell the pin 11 and 13 are supposed to have hardware PWM which does not put load on the CPU but this seem to not be exposed in the OS.
Looking through the device-tree files in the linux kernel I cannot find any reference to fan or pwm-fan in any relevant files for the Rock 4 SE. Is this by design or is there a reason for this?
Looking at other files, such as the rk3399-khadas-edge.dtsi I see a part that looks promising:
I have grepped through all files in the linux/arch/arm64/boot/dts/rockchip-folder in multiple releases from 5.1 until 6.14 but there does not seem to ever have been any file (of the above) that ever had this option.
Is PWM handled differently somehow for the Rock 4 SE or is there some other kernel to be used rather than the official linux kernel? I have also looked through the repos at Radxa github and rockhip github but cannot find any difference there. It feels like there are device-tree properties missing that should be added.
@alberto Which OS/version did you write the script for?
Hi alberto
I have installed your script, but i cannot get it to work…
I have trried to enable the overlay for PWM0 tho rsetup without any luck.
Do i need this enabled?
i am running the default raxda image, is there somehow i can test? or comfim that the GPIO can see the fan/pins
I have a problem where the fan only spins slightly after rebooting. How can I trigger it to work properly and ensure it stays running?
i also tried to trigger some stress for the cpu by doing: stress --cpu $(nproc) --timeout 30
but this is without any luck and the fan does not spin.
After some troubleshooting, I was able to get the fan to spin by modifying the following script but only on reboot…
set25(){
if [ "$actual" -ne 25 ]; then
echo 10000 > /sys/class/pwm/pwmchip0/pwm0/duty_cycle
actual=100 # Set the actual value to 100 instead of 25
sleep 2
fi
I didn’t mean I wanted it to run right after reboot, but rather just the fan could run if I stress tested it but it wouldn’t, but if I change this in the script it could run when there was a little load.
It’s been a while since I looked at it, but now it can run when there is a little load on the system.
For example, I couldn’t get it to run with stress --cpu $(nproc) --timeout 30
So just changing this worked, is that completely wrong?
