After some time rock 4 SE crash after some time (maybe it depends on load).
OS downloaded from radxa website.
OS installed on eMMC (on uSD - same thing).
[As a new user, I could noy post more than 2 links, so I had to modify the links, splitting them up and write github-com.]
Hmm, I also have issues with my (new) board.
I tried to flash a micro-sd card (128GB)
Since I don’t see anything on the HDMI, I do not know if everything is fine or if I got a crash.
Or if my board is broken.
What I see:
The green LED is lit, I don’t get any blinking blue LED.
I seem to be connected on physical/ethernet level, since the router turns on o LED for that port.
Waiting does not seem to help.
Some webpage said it could take 2 minutes, I don’t think I waited that long the first time I booted.
I used rock-4se_ubuntu_jammy_kde_2023-01-01T0627+0000_gpt.img from
https github-com /radxa-build/rock-4se/releases
I noted that https://wiki.radxa.com/Rockpi4/downloads for “Rock 4 SE” points to Rock 4B (don’t know if that is correct or not)
https github-com /radxa/debos-radxa/releases/download/20221109-1007/rockpi-4b-ubuntu-focal-server-arm64-20221109-1331-gpt.img.xz
I think I saw a post somewhere about later versions of the Rock 4 SE files did not work. But I cannot find it right not.
Can someone help me get the board to boot, or help debug if it is broken?
Unfortunately no. There was an beta image which was based on Linux kernel v.5 - that one has not the issue. I can not find this anymore. Tip: Search in web time machine for wiki radxa 4SE.
I know where the problem was, at least in my case. I installed Armbian with kernel 5 but it didn’t help. But finally, instead of using QC 3.0 power adapter, I switched to fixed 12V 2A adapter with usb-c connector. 4 days without hangs.
