Hello everyone,
[First time posting]
=== goal ===
I have a Rock 3B and would need to use rkdeveloptool to write the MMC.
=== issue ===
I cannot reach MaskROM as indicated on the documentation page here.
Here is my attempt:
- I have attached a UART to pins 6,8,10 and can see the u-boot logs via picocom
- I have shorted the pins as indicated by the documentation page (i could post a photo, woudl it be if necessary ?)
- I have set the OTG switch to “device” as indicated by the documentation page
- I have removed SD and NVME, leaving only a brand new MMC attached.
- I have connected a USB-A to USB-A cable from the OTG to my PC
When connecting the power I see the following logs, on the serial port, where the execution seems to go straight to an SPL that seems to be the one from U-Boot SPI (? I have tried to reach MaskMODE event without the MMC, so no external memory at all (no SD, no MMC, no NVME), and still I am seeing these logs)
Type [C-a] [C-h] to see available commands
Terminal ready
�DDR V1.16 6f71c736ce typ 23/03/02-20:01:48
In
LP4/4x derate en, other dram:1x trefi
ddrconfig:0
LPDDR4X, 324MHz
BW=32 Col=10 Bk=8 CS0 Row=16 CS=1 Die BW=16 Size=2048MB
tdqss: cs0 dqs0: 24ps, dqs1: -48ps, dqs2: -24ps, dqs3: -120ps,
change to: 324MHz
PHY drv:clk:36,ca:36,DQ:29,odt:0
vrefinner:24%, vrefout:41%
dram drv:40,odt:0
clk skew:0x61
change to: 528MHz
dram drv:40,odt:0
clk skew:0x58
change to: 780MHz
dram drv:40,odt:0
clk skew:0x58
change to: 1560MHz(final freq)
PHY drv:clk:36,ca:36,DQ:29,odt:60
vrefinner:16%, vrefout:22%
dram drv:40,odt:80
vref_ca:00000071
clk skew:0x1c
cs 0:
the read training result:
DQS0:0x36, DQS1:0x36, DQS2:0x39, DQS3:0x33,
min : 0xd 0xf 0x11 0xc 0x2 0x5 0x9 0x3 , 0xa 0x9 0x2 0x1 0xc 0xb 0xf 0x7 ,
0x13 0x13 0xe 0xc 0x4 0x2 0x6 0x6 , 0xc 0xa 0x8 0x1 0xf 0x10 0xe 0x10 ,
mid :0x2a 0x2c 0x2d 0x29 0x1e 0x23 0x24 0x20 ,0x26 0x25 0x1e 0x1d 0x28 0x27 0x2a 0x24 ,
0x2e 0x2f 0x29 0x27 0x1f 0x1e 0x20 0x22 ,0x27 0x25 0x22 0x1c 0x2b 0x2b 0x29 0x2b ,
max :0x47 0x49 0x49 0x47 0x3b 0x41 0x3f 0x3e ,0x43 0x42 0x3a 0x3a 0x45 0x44 0x46 0x41 ,
0x4a 0x4b 0x45 0x42 0x3b 0x3b 0x3b 0x3e ,0x43 0x41 0x3d 0x38 0x47 0x47 0x45 0x47 ,
range:0x3a 0x3a 0x38 0x3b 0x39 0x3c 0x36 0x3b ,0x39 0x39 0x38 0x39 0x39 0x39 0x37 0x3a ,
0x37 0x38 0x37 0x36 0x37 0x39 0x35 0x38 ,0x37 0x37 0x35 0x37 0x38 0x37 0x37 0x37 ,
the write training result:
DQS0:0x20, DQS1:0x13, DQS2:0x18, DQS3:0x5,
min :0x69 0x6e 0x6e 0x6c 0x5f 0x63 0x63 0x64 0x63 ,0x58 0x57 0x50 0x4f 0x5c 0x5b 0x5a 0x59 0x53 ,
0x63 0x63 0x5e 0x5d 0x54 0x52 0x53 0x59 0x59 ,0x50 0x4d 0x4c 0x47 0x53 0x55 0x50 0x56 0x4b ,
mid :0x84 0x88 0x88 0x85 0x77 0x7c 0x7d 0x7b 0x7b ,0x73 0x72 0x69 0x69 0x78 0x74 0x74 0x72 0x6e ,
0x7f 0x7f 0x78 0x78 0x70 0x6d 0x6e 0x73 0x74 ,0x6c 0x69 0x66 0x60 0x6f 0x70 0x6b 0x70 0x67 ,
max :0xa0 0xa3 0xa3 0x9e 0x90 0x96 0x98 0x93 0x94 ,0x8f 0x8e 0x83 0x84 0x94 0x8e 0x8f 0x8b 0x89 ,
0x9c 0x9c 0x92 0x94 0x8c 0x89 0x8a 0x8d 0x90 ,0x89 0x86 0x81 0x79 0x8c 0x8c 0x87 0x8b 0x83 ,
range:0x37 0x35 0x35 0x32 0x31 0x33 0x35 0x2f 0x31 ,0x37 0x37 0x33 0x35 0x38 0x33 0x35 0x32 0x36 ,
0x39 0x39 0x34 0x37 0x38 0x37 0x37 0x34 0x37 ,0x39 0x39 0x35 0x32 0x39 0x37 0x37 0x35 0x38 ,
CA Training result:
cs:0 min :0x47 0x49 0x3f 0x3c 0x3f 0x3a 0x42 ,0x45 0x42 0x3d 0x39 0x3d 0x39 0x40 ,
cs:0 mid :0x87 0x87 0x7e 0x7c 0x7e 0x78 0x6e ,0x84 0x81 0x7a 0x77 0x79 0x77 0x6c ,
cs:0 max :0xc8 0xc5 0xbd 0xbc 0xbd 0xb6 0x9b ,0xc4 0xc1 0xb8 0xb6 0xb6 0xb6 0x98 ,
cs:0 range:0x81 0x7c 0x7e 0x80 0x7e 0x7c 0x59 ,0x7f 0x7f 0x7b 0x7d 0x79 0x7d 0x58 ,
out
U-Boot SPL latest-2023.07.02-6-4257d241-g4257d241 (Oct 12 2023 - 07:58:46 +0000)
Trying to boot from SPI
## Checking hash(es) for config config-1 ... OK
## Checking hash(es) for Image atf-1 ... sha256+ OK
## Checking hash(es) for Image u-boot ... sha256+ OK
## Checking hash(es) for Image fdt-1 ... sha256+ OK
## Checking hash(es) for Image atf-2 ... sha256+ OK
## Checking hash(es) for Image atf-3 ... sha256+ OK
## Checking hash(es) for Image atf-4 ... sha256+ OK
## Checking hash(es) for Image atf-5 ... sha256+ OK
INFO: Preloader serial: 2
NOTICE: BL31: v2.3():v2.3-181-gc9a647cae-dirty:xsf
NOTICE: BL31: Built : 11:30:09, Oct 18 2022
INFO: pmu v1 is valid
INFO: dfs DDR fsp_param[0].freq_mhz= 1560MHz
INFO: dfs DDR fsp_param[1].freq_mhz= 324MHz
INFO: dfs DDR fsp_param[2].freq_mhz= 528MHz
INFO: dfs DDR fsp_param[3].freq_mhz= 780MHz
INFO: boot cpu mask: 0
INFO: Entry point address = 0xa00000
INFO: SPSR = 0x3c9
U-Boot latest-2023.07.02-6-4257d241-g4257d241 (Oct 12 2023 - 07:58:46 +0000)
Model: Radxa ROCK 3 Model B
DRAM: 2 GiB
PMIC: RK8090 (on=0x40, off=0x00)
Core: 340 devices, 31 uclasses, devicetree: separate
MMC: mmc@fe2b0000: 1, mmc@fe310000: 0
In: serial@fe660000
Out: serial@fe660000
Err: serial@fe660000
Net: No ethernet found.
starting USB...
Bus usb@fcc00000: Register 2000140 NbrPorts 2
Starting the controller
USB XHCI 1.10
Bus usb@fd000000: Register 2000140 NbrPorts 2
USB XHCI 1.10
Bus usb@fd800000: USB EHCI 1.00
Bus usb@fd840000: USB OHCI 1.0
Bus usb@fd880000: USB EHCI 1.00
Bus usb@fd8c0000: USB OHCI 1.0
scanning bus usb@fcc00000 for devices... 1 USB Device(s) found
scanning bus usb@fd000000 for devices... 1 USB Device(s) found
scanning bus usb@fd800000 for devices... 2 USB Device(s) found
scanning bus usb@fd840000 for devices... 1 USB Device(s) found
scanning bus usb@fd880000 for devices... 1 USB Device(s) found
scanning bus usb@fd8c0000 for devices... 1 USB Device(s) found
Hit Ctrl+C key in 0 seconds to stop autoboot...
pcie_dw_rockchip pcie@fe260000: PCIe-0 Link Fail
pcie_dw_rockchip pcie@fe280000: PCIe-1 Link Fail
scanning bus for devices...
No ethernet found.
No ethernet found.
## Error: "distro_bootcmd" not defined
Boot failed. Reset in 3 seconds...
resetting ...
=== emptying the SPI ===
I thought that by emptying the SPI I could convince the BootROM that only MaskROM is available, but i cannot find, in rsetup, the option to manually emptying the SPI (as otherwise indicated in the documentation here)
=== questions ===
- how to correctly get to MaskMODE in Rock 3B ? Any visible mistakes ?
- is SPI SPL that i see in the logs ? If yes would removing it allow me to reach MaskMODE ? if yes how ?
Thanks you in advance,
Any sort of help would be appreciated,
Have a great week,
Cheers,
