我的Rock 3A无法正常工作
之前发过一个帖子描述问题,我使用了 rock3a-android11-20220408_1204-gpt.img ,这次附带上无限唤醒期间得到的串口log,除了 wakeup count 会逐次递增,其它内容是一致的:
ABCDEINFO: [TEST]: wakeup count: 10
INFO: wake interput IINFO: wake interput ID: 150
INFO: wake interput ID: 187
WAKEUP SOURCE: 0x10
INFO: s wakeup source
INFO: GPIO0A3
INFO: GPIO4B4
FG▒L1MI/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switchi
I/TC: Secondary CPU 2 initializing
I/TC: Secondary CPU 2 switching to normal world boot
I/TC: Secondary CPU 3 initializing
I/TC: Secondary CPU 3 switching to normal world boot
[ 313.587363] [WLAN_RFKILL]: Enter rfkill_wlan_suspend
[ 313.41] Disabling non-boot CPUs …
[ 313.668569] CPU1: shutdown
] psci: CPU1 killed (polled 0 msutdown
[ 313.685082] psci: CPU2 killed (polled 0 ms)
[ 313.704965] CPU3: shutdown
[ 313.704978] psci: CPU3 killed (polled 0 ms)
[ 313.709344] pm_system_irq_wakeup:
[ 313.709497] Enabling non-boot CPUs …
[ 313.710658] Detecche on CPU1
[ 313.710709] GICv3: CPU1: found redistributor 100000000fd480000
[ 313.710804] Cocessor 0x0000000100 [0x412fd050 up
[ 313.713030] Detected VIPT I-cache on CPU2
[ 313.7130682: found redistributor 200 region 0:0x00000000fd4a0000
[ 313.713136] CPU2: Booted secondary processor 0x0000000200 [0x412fd050 313.713925] CPU2 is up
[ 313.716982] Detected VIPT I-cache on CPU3
[ 313.717022] GICv3: CPU3: found redistributor 300 regio00000000fd4c0000
[ 313.717097]rocessor 0x0000000300 [0x412fd050]
[ 313.718128] CPU3 is up
usb usb1: root hub lost power or was reset
[ 313.725886] usb usb2: root hub lost power or was reset
[ 313.784977] usb usb3t hub lost power or was reset
[ 313.844964] usb usb4: root hub lost power or was reset
[ 313.850174] rk_gmac-dwmac fe010000.et: init for RGMII
[ 314.00100eed USB device number 2 using ehci-platform
[ 314.031001] dwmaXI performs any burst length
[ 314.031040] rk_gmac-dwmac fe010000.ethernet eth0: No Safety Features support found
[ 314.0331WLAN_RFKILL]: Enter rfkill_wlan_resume
[ 314.038436] usb usb5: root hub lost power or was reset
[ 314.038447] usb usb6: rootost power or was reset
[ 314.0 lost power or was reset
[ 314.040690] usb usb8: root hub losts reset
[ 314.048868] gsensor_mxc6655 5-0015: sensor_active:fail to active sensor
[ 314.048880] gsensor_mxc6655 5-0015: sensit:line=87,error
[ 314.048887] gsensor_mxc6655 5-0015: sensor_initial:fail to init sensor
[ 314.374359] usb 4-1: reset low-sSB device number 2 using ohci-plb 1-1.1: reset low-speed USB device number 3 using ehci-platform856] OOM killer enabled.
[ 315.139867] Restarting tasks … done.
[ 315.145045] Resume caused by IRQ 83, rk817
[ 315.14509: suspend exit
[ 315.149615] healthd: battery l=50 v=3 t=2.6 h=2 st=3 fc=100 chg=au
[ 315.158189] mmc_host mmc0: Bus speed () = 375000Hz (slot req 400000Hz,
[ 315.338134] PM: suspend entry (deep)
[ 315.338237] PM: Syncing filesystems …
[ 315.486694] mmc_host mmc0: Bus speed (slot 0) = 0000Hz, actual 148500000HZ div =[ 315.650474] dwmmc_rockchip fe2b0000.dwmmc: Successfully tuned[ 315.681283] done.
[ 315.681497] Freezing user space processes … (elapsed 0.007 seconds) done.
[ 315.688787] O[ 315.688797] Freezing remaining freezable tasks … (elapsed 0.004 seconds) done.
[ 315.6932ole(s) (use no_console_suspend to debug)
abcdeghINFO: sleep mode config[0x5ec]:
INFO: mode: RKPM_SLP_ode: RKPM_SLP_ARMOFF_LOGOFF
INFO: mode: RKPM_SLP_PMIC_LP
I mode: RKPM_SLP_HW_PLLS_PD
INFO: mode: RKPM_SLP_PMUALIVE_32K
INFO: mode: RKPM_SLP_OSC_DIS
INFO: mode: RKPM_SLP_32K_PVTM
INFO: wakeup sourceNFO: Enable GPIO0 interrupt as wakeup source
ijsramwfiABCDEINFO: [TEST]: wakeup count: 11
INFO: WAKEUP SOURCE: 0x10
INFO: GPIO0 interrupt as wakeup source
INFO: GPIO0A3
IB4
I/TC: Secondary CPal world boot
[ 315.741748] [WLAN_RFKILL]: Enter rfkill_wlan_suspend
[ 315.Us …
[ 315.821795] CPU1: shutdown
[ 315.821807] psci: CPU1 killed (polled 0 ms)
[ 315.85own
[ 315.851605] psci: CPU2 killed (polled 0 ms)
[ 315.871494] CPU3: shutdown
[ 315.871506] psci: CPU3 killed (polled 0 ms)
[ 315.872902] pm_system_irq_wakeup: 83 triggered rk817
[ 315.873] Enabling non-boot CPUs …
[ 315.874186] Detected VIPT I-cache on CPU1
[ 315.874236] GICv3butor 100 region 0:0x00000000fd480000
[ 315.874331] CPU1: Booted secondary processor 0x0000000100 [0x412fd050]
[ 315.875256]5.876410] Detected VIPT I-cache GICv3: CPU2: found redistributor 200 region 0:0x00000000fd4a000015] CPU2: Booted secondary processor 0x0000000200 [0x412fd050]
[ 315.877294] CPU2 is up
[ 315.878491] Detected VIPT I-cache U3
[ 315.878529] GICv3: CPU3: found redistributor 300 region 0:0x00000000fd4c0000
[ 315.878595] CPU3: Booted secondary procex0000000300 [0x412fd050]
[ 315315.887084] usb usb2: root hub lost power or was reset
[ 315.8b1: root hub lost power or was reset
[ 315.944856] usb usb3: root hub lost power or was reset
[ 316.004845] usb usb4: root hst power or was reset
[ 316.010067] rk_gmac-dwmac fe010000.ethernet: init for RGMII
[ 316.160903] usb 1-1: reset high-speed vice number 2 using ehci-platfor: Master AXI performs any burst length
[ 316.190911] rk_gmac-d.ethernet eth0: No Safety Features support found
[ 316.192984] [WLAN_RFKILL]: Enter rfkill_wlan_resume
[ 316.198405] usb usbot hub lost power or was reset
[ 316.198415] usb usb6: root hub lost power or was reset
[ 316.200666] usb usb7: root hub losr or was reset
[ 316.200677] uower or was reset
[ 316.209011] gsensor_mxc6655 5-0015: sensorto active sensor
[ 316.209025] gsensor_mxc6655 5-0015: sensor_error
[ 316.209032] gsensor_mxc6655 5-0015: sensor_initial:fail to init sensor
[ 316.534244]w-speed USB device number 2 using ohci-platform
[ 316.900890] eset low-speed USB device number[ 317.299541] OOM killer enabled.
[ 317.299557] Restarting ta
[ 317.308290] healthd: battery l=50 v=3 t=2.6 h=2 st=3 fc=100 chg=au
[ 317.314307] Resume caused by IRQ 83, rk817
[ 317.3] PM: suspend exit
[ 317.328668] mmc_host mmc0: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ [ 317.642574] mmc_host mmc0: Bus speed (slot 0) = 148500000Hz (slot req 150000000Hz, actual 148[ 317.791578] dwmmc_rockchip fe2b0000.dwmmc: Successfully tuned phase to 237
[ 317.908951] PM: suspend entry (deep)
[ 317.908996] PM: Syncing filesystems … done.
[ 317.924387] Freezing user space processes … (elapsed 0.019 seconds) done.
[ 317.944226] O
[ 317.944232] Freezing remaining freezable tasks … (elapsed 0.002 seconds) done.
[ 317.9468ing console(s) (use no_console_sabcdeghINFO: sleep mode config[0x5ec]:
INFO: mode: RKPM_SLP_CENTER_PD
INFO: mode: RKPM_
INFO: mode: RKPM_SLP_HW_D
INFO: mode: RKPM_SLP_PMUAode: RKPM_SLP_OSC_DIS
INFO: eup source config[0x10]:
INFO: Enable GPIO0 interrupt as wakeup source
ijsramwfi
我的前同事曾经修改过dts文件,使它从GPIO输出图像而非HDMI输出,我缺少这方面的知识,不太清楚这是否直接影响到了工作结果?
如果是的话我应该从哪里获取一个原始的.dts来覆盖修改?
下面附带该文件
rk3568-rock-3-a.zip (5.4 KB)
