I have tried the instructions from this page but I don’t see anything on my screen. The HDMI output works fine with my standard monitor, so I know the Rock 3A is working.
At the bottom of the display configuration page, it says “Please note that RPI 7’TS need 5V power supply.”
The screen only has the MIPI DSI cable connection. Is there a way to enable the 5V power supply over the MIPI DSI cable, or do I need to supply it from the GPIO pins?
I tried to power from the 5VDC GPIO pins and it hasn’t made any difference so far.
Some more details: I’m using the Debian distribution from the Radxa page and in the Display configuration application I only see HDMO-1 as an available display.
I also tried editing the config .txt with each of these lines one at a time without any noticeable change:
dtoverlay=rock-3c-raspberrypi-7inch-touchscreen (original from the linked page)
dtoverlay=rock-3a-raspberrypi-7inch-touchscreen (just a guess)
dtoverlay=rk3568-raspberrypi-7inch-touchscreen (matched the other dtoverlay lines in config.txt)
I have BIGTREE TECH Pi TFT 7.0 Display and another 7 inch raspberry compatible display. This display seems to have better quality and one particular thing that was very interesting, is the possibility of switching HOR/VER by hardware.
For this display, the TS works without any changes, but i can’t turn the backlight on.
And for the other, everything works, but i really would like to get this one to work.
@jack , any chance you can get this one and test it on 3A?
I also tested it with radxa raspi driver but kernel crashed.
