i flashed rock-3a-debian-buster-xfce4-arm64-20220601-1116-gpt.img to the emmc, then installed wget and curl, and ran the script
curl -sL https://rock.sh/get-rockpi-penta | sudo -E bash -
then during installation i get this error
Reading state information... Done E: Unable to locate package libmraa Traceback (most recent call last): File "setup.py", line 3, in <module> from setuptools import setup, find_packages ModuleNotFoundError: No module named 'setuptools'
when i check under lspci
i only read this :
0002:20:00.0 PCI bridge: Fuzhou Rockchip Electronics Co., Ltd Device 3566 (rev 01)
after restarting i check the status of rockpi.pentahat service using
sudo systemctl status rockpi-penta.service
and i get this
lspci doesnt show the connected penta hat and also lsblk has no hdd
tried running the service manually and i get this error
sudo python3 /usr/bin/rockpi-penta/main.py
File “/usr/bin/rockpi-penta/main.py”, line 3, in
import fan
File “/usr/bin/rockpi-penta/fan.py”, line 3, in
import mraa # pylint: disable=import-error
ModuleNotFoundError: No module named ‘mraa’
if this might help, dmesg is here
https://termbin.com/5f17
using 60 watt power supply from allnetchina
i have a m2 adapter, and it works flawlessly with the same 3a and ribbon connector
some help pls?
