Rock 3A not booting with any image
Hi @t4_4t,
thank you so much for you info, especially about the boot prio and the role of the SPI.
I was able to start the device in maskrom-mode and to erase everything:
It is strange that the RKDevTool can only access the device if I downloaded the spi-loader file to the device first → erasing everything is working afterwards.
This is the serial log after booting the image from the SD:
serial log:
▒▒▒▒▒DDR V1.16 6f71c736ce typ 23/03/02-20:01:48
In
LP4/4x derate en, other dram:1x trefi
ddrconfig:7
LPDDR4X, 324MHz
BW=32 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=8 Size=8192MB
tdqss: cs0 dqs0: 72ps, dqs1: -72ps, dqs2: -72ps, dqs3: -144ps,
tdqss: cs1 dqs0: 48ps, dqs1: -48ps, dqs2: -48ps, dqs3: -120ps,
change to: 324MHz
PHY drv:clk:36,ca:36,DQ:29,odt:0
vrefinner:24%, vrefout:41%
dram drv:40,odt:0
clk skew:0x61
change to: 528MHz
dram drv:40,odt:0
clk skew:0x58
change to: 780MHz
dram drv:40,odt:0
clk skew:0x58
change to: 1560MHz(final freq)
PHY drv:clk:36,ca:36,DQ:29,odt:60
vrefinner:16%, vrefout:22%
dram drv:40,odt:80
vref_ca:00000071
clk skew:0x26
cs 0:
the read training result:
DQS0:0x33, DQS1:0x33, DQS2:0x33, DQS3:0x30,
min : 0xe 0x10 0x12 0x12 0x2 0x6 0x7 0x6 , 0x9 0x5 0x2 0x2 0xe 0xc 0xe 0x7 ,
0x10 0xf 0xd 0xa 0x4 0x1 0x6 0x6 , 0xd 0x5 0x6 0x2 0x10 0xf 0xd 0x10 ,
mid :0x29 0x2a 0x2c 0x2c 0x1d 0x20 0x22 0x21 ,0x24 0x21 0x1d 0x1d 0x29 0x26 0x28 0x22 ,
0x29 0x29 0x25 0x23 0x1d 0x1b 0x1d 0x1f ,0x26 0x22 0x22 0x1d 0x2a 0x2a 0x28 0x2a ,
max :0x44 0x45 0x46 0x46 0x39 0x3b 0x3e 0x3d ,0x3f 0x3e 0x38 0x38 0x44 0x40 0x42 0x3d ,
0x42 0x44 0x3e 0x3d 0x36 0x35 0x35 0x38 ,0x40 0x3f 0x3e 0x38 0x45 0x46 0x44 0x44 ,
range:0x36 0x35 0x34 0x34 0x37 0x35 0x37 0x37 ,0x36 0x39 0x36 0x36 0x36 0x34 0x34 0x36 ,
0x32 0x35 0x31 0x33 0x32 0x34 0x2f 0x32 ,0x33 0x3a 0x38 0x36 0x35 0x37 0x37 0x34 ,
the write training result:
DQS0:0x34, DQS1:0x18, DQS2:0x18, DQS3:0xa,
min :0x78 0x7c 0x7e 0x7b 0x6c 0x70 0x73 0x75 0x73 ,0x5c 0x59 0x53 0x53 0x5e 0x5d 0x5e 0x5d 0x56 ,
0x62 0x62 0x5c 0x5a 0x52 0x50 0x53 0x58 0x57 ,0x50 0x4e 0x4c 0x48 0x53 0x56 0x52 0x57 0x4c ,
mid :0x95 0x98 0x99 0x96 0x86 0x8b 0x8e 0x8f 0x8c ,0x74 0x72 0x6c 0x6b 0x77 0x75 0x76 0x75 0x70 ,
0x7d 0x7d 0x77 0x76 0x6d 0x6c 0x6e 0x72 0x72 ,0x6c 0x6a 0x68 0x62 0x6f 0x70 0x6d 0x72 0x68 ,
max :0xb2 0xb4 0xb5 0xb2 0xa1 0xa6 0xa9 0xa9 0xa6 ,0x8d 0x8c 0x86 0x84 0x90 0x8d 0x8f 0x8e 0x8b ,
0x98 0x99 0x92 0x92 0x89 0x88 0x89 0x8c 0x8e ,0x88 0x86 0x84 0x7d 0x8b 0x8b 0x89 0x8d 0x84 ,
range:0x3a 0x38 0x37 0x37 0x35 0x36 0x36 0x34 0x33 ,0x31 0x33 0x33 0x31 0x32 0x30 0x31 0x31 0x35 ,
0x36 0x37 0x36 0x38 0x37 0x38 0x36 0x34 0x37 ,0x38 0x38 0x38 0x35 0x38 0x35 0x37 0x36 0x38 ,
cs 1:
DQS0:0x33, DQS1:0x32, DQS2:0x33, DQS3:0x2e,
min : 0xd 0xd 0x11 0x10 0x2 0x5 0x7 0x5 , 0xa 0x5 0x2 0x2 0xf 0xb 0xd 0x7 ,
0x11 0x11 0xe 0xc 0x5 0x2 0x6 0x7 , 0x9 0x4 0x4 0x1 0xf 0xf 0xd 0x10 ,
mid :0x28 0x28 0x2c 0x2a 0x1d 0x20 0x22 0x20 ,0x23 0x20 0x1b 0x1c 0x28 0x24 0x26 0x20 ,
0x2a 0x2a 0x26 0x24 0x1c 0x1b 0x1d 0x1e ,0x23 0x20 0x1f 0x1b 0x29 0x29 0x28 0x29 ,
max :0x43 0x44 0x47 0x44 0x39 0x3b 0x3e 0x3c ,0x3d 0x3b 0x34 0x37 0x41 0x3e 0x3f 0x3a ,
0x44 0x43 0x3e 0x3c 0x34 0x34 0x34 0x36 ,0x3d 0x3c 0x3b 0x36 0x44 0x44 0x43 0x42 ,
range:0x36 0x37 0x36 0x34 0x37 0x36 0x37 0x37 ,0x33 0x36 0x32 0x35 0x32 0x33 0x32 0x33 ,
0x33 0x32 0x30 0x30 0x2f 0x32 0x2e 0x2f ,0x34 0x38 0x37 0x35 0x35 0x35 0x36 0x32 ,
min :0x77 0x77 0x7a 0x78 0x69 0x6d 0x70 0x73 0x6f ,0x5e 0x5a 0x55 0x55 0x60 0x61 0x61 0x61 0x59 ,
0x63 0x65 0x5e 0x5d 0x55 0x53 0x55 0x5c 0x59 ,0x54 0x52 0x50 0x4c 0x59 0x5a 0x57 0x5c 0x50 ,
mid :0x93 0x93 0x96 0x93 0x83 0x88 0x8b 0x8c 0x88 ,0x79 0x75 0x6f 0x6e 0x7a 0x79 0x7a 0x79 0x74 ,
0x7e 0x7f 0x78 0x78 0x6f 0x6d 0x6f 0x75 0x74 ,0x70 0x6d 0x6c 0x67 0x74 0x75 0x71 0x77 0x6b ,
max :0xaf 0xb0 0xb2 0xaf 0x9d 0xa3 0xa6 0xa6 0xa2 ,0x94 0x90 0x89 0x88 0x94 0x92 0x93 0x92 0x8f ,
0x99 0x9a 0x92 0x94 0x8a 0x88 0x89 0x8e 0x8f ,0x8c 0x89 0x88 0x82 0x8f 0x90 0x8c 0x92 0x87 ,
range:0x38 0x39 0x38 0x37 0x34 0x36 0x36 0x33 0x33 ,0x36 0x36 0x34 0x33 0x34 0x31 0x32 0x31 0x36 ,
0x36 0x35 0x34 0x37 0x35 0x35 0x34 0x32 0x36 ,0x38 0x37 0x38 0x36 0x36 0x36 0x35 0x36 0x37 ,
CA Training result:
cs:0 min :0x54 0x50 0x4b 0x46 0x4b 0x3d 0x4f ,0x52 0x4a 0x48 0x41 0x48 0x42 0x53 ,
cs:0 mid :0x90 0x8f 0x87 0x85 0x85 0x7e 0x7f ,0x8d 0x8b 0x82 0x81 0x84 0x81 0x82 ,
cs:0 max :0xcc 0xcf 0xc4 0xc4 0xbf 0xc0 0xaf ,0xc9 0xcc 0xbd 0xc2 0xc1 0xc1 0xb2 ,
cs:0 range:0x78 0x7f 0x79 0x7e 0x74 0x83 0x60 ,0x77 0x82 0x75 0x81 0x79 0x7f 0x5f ,
cs:1 min :0x52 0x58 0x49 0x4f 0x49 0x47 0x53 ,0x4e 0x51 0x45 0x48 0x47 0x4a 0x4e ,
cs:1 mid :0x93 0x92 0x8a 0x88 0x89 0x83 0x85 ,0x8f 0x8c 0x85 0x83 0x86 0x84 0x81 ,
cs:1 max :0xd5 0xcd 0xcb 0xc2 0xc9 0xbf 0xb7 ,0xd1 0xc7 0xc6 0xbe 0xc6 0xbf 0xb4 ,
cs:1 range:0x83 0x75 0x82 0x73 0x80 0x78 0x64 ,0x83 0x76 0x81 0x76 0x7f 0x75 0x66 ,
out
U-Boot SPL latest-2023.07.02-3-b1eb2bde-gb1eb2bde (Aug 29 2023 - 10:43:04 +0000)
Trying to boot from MMC2
Checking hash(es) for config config-1 … OK
Checking hash(es) for Image atf-1 … sha256+ OK
Checking hash(es) for Image u-boot … sha256+ OK
Checking hash(es) for Image fdt-1 … sha256+ OK
Checking hash(es) for Image atf-2 … sha256+ OK
Checking hash(es) for Image atf-3 … sha256+ OK
Checking hash(es) for Image atf-4 … sha256+ OK
Checking hash(es) for Image atf-5 … sha256+ OK
INFO: Preloader serial: 2
NOTICE: BL31: v2.3():v2.3-181-gc9a647cae-dirty:xsf
NOTICE: BL31: Built : 11:30:09, Oct 18 2022
INFO: pmu v1 is valid
INFO: dfs DDR fsp_param[0].freq_mhz= 1560MHz
INFO: dfs DDR fsp_param[1].freq_mhz= 324MHz
INFO: dfs DDR fsp_param[2].freq_mhz= 528MHz
INFO: dfs DDR fsp_param[3].freq_mhz= 780MHz
INFO: boot cpu mask: 0
INFO: Entry point address = 0xa00000
INFO: SPSR = 0x3c9
U-Boot latest-2023.07.02-3-b1eb2bde-gb1eb2bde (Aug 29 2023 - 10:43:04 +0000)
Model: Radxa ROCK3 Model A
DRAM: 8 GiB (effective 7.7 GiB)
PMIC: RK8090 (on=0x40, off=0x00)
→ Boot process is stuck
I then shortened pin 1 and 2 of the recovery header and restarted the device → exactly the same output on the serial log.
Note: I was not able to disable the MASKROM-mode → device is permanently in MASKROM-mode. Could that be an explanation for the boot failure? Any idea how to disable MASKROM-mode?
Thanks for your support!
I do not know what happened but suddenly I am able to boot official Radxa images and also Armbian images from SD and eMMC!!
Thanks to all of you for your support!!
@Carsten
#17 March 20, 2025, 7:48pm
#19 March 22, 2025, 3:27pm
Both of the two logs you presented above fail to start, but #19 works pretty well and is relatively better.
Among the images currently provided, the following two are similar to this configuration.
Try the following two images with “the jumper pins in place”.
If you see any changes, it may be a clue to the analysis.
rock-3a-debian-bullseye-xfce4-arm64-20230301-0341-gpt.img.xz
rock-3a_debian_bullseye_xfce_b23.img.xz
The “rock-3a” I own has 4GB of memory,
but I’ve confirmed that it works without any problems with the b25 suggested by @Mitchell.
