I am trying to build mainline atf, u-boot, and arch on this board.
i built atf (bl31.elf
), u-boot with rkbin’s (rk3568_ddr_1560MHz_v1.21.bin), and got the rootfs arch from https://archlinuxarm.org/platforms/armv8/generic.
I flashed u-boot-rockchip-spi.bin to SPI on the board.
I created a gtp partition table on the emmc with 1 ext4 partition and extracted the arch image to the ext4 drive (sudo bsdtar -xpf "ArchLinuxARM-aarch64-latest.tar.gz" -C "whereimountemmc"
). I created this file with these contents
/boot/extlinux/extlinux.conf
menu title Select kernel timeout 100 label Arch kernel /boot/Image initrd /boot/initramfs-linux.img devicetree /boot/dtbs/rockchip/rk3568-rock-3a.dtb append console=ttyS0,115200 console=tty1 rw root=UUID=df42bbe6-9be9-483c-b56b-9bccbf67a65f
And then booted the board and I get this output
DDR 2d653b3476 typ 24/01/20-15:04:19,fwver: v1.21
In
LP4/4x derate en, other dram:1x trefi
ddrconfig:7
LPDDR4X, 324MHz
BW=32 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=8 Size=8192MB
tdqss: cs0 dqs0: 48ps, dqs1: -72ps, dqs2: -48ps, dqs3: -120ps,
tdqss: cs1 dqs0: 48ps, dqs1: -72ps, dqs2: -48ps, dqs3: -144ps,change to: 324MHz
PHY drv:clk:36,ca:36,DQ:29,odt:0
vrefinner:24%, vrefout:41%
dram drv:40,odt:0
clk skew:0x61
rx vref: 34.4%
tx vref: 42.0%change to: 528MHz
dram drv:40,odt:0
clk skew:0x58
rx vref: 34.4%
tx vref: 38.0%change to: 780MHz
PHY drv:clk:36,ca:36,DQ:29,odt:60
vrefinner:16%, vrefout:41%
dram drv:40,odt:0
clk skew:0x58
rx vref: 16.6%
tx vref: 36.0%change to: 1560MHz(final freq)
vrefinner:16%, vrefout:22%
dram drv:40,odt:80
vref_ca:00000071
clk skew:0x26
rx vref: 16.6%
tx vref: 22.8%
cs 0:
the read training result:
DQS0:0x33, DQS1:0x32, DQS2:0x36, DQS3:0x2f,
min : 0xd 0x11 0x11 0x11 0x2 0x5 0x9 0x5 , 0x9 0x9 0x1 0x2 0xc 0xc 0xd 0xa ,
0x10 0x10 0xe 0xb 0x5 0x2 0x4 0x9 , 0x9 0x8 0x6 0x2 0xc 0xe 0xb 0xe ,
mid :0x29 0x2a 0x2b 0x2b 0x1c 0x20 0x23 0x21 ,0x24 0x23 0x1c 0x1d 0x27 0x26 0x27 0x24 ,
0x2b 0x2b 0x27 0x26 0x20 0x1d 0x1e 0x23 ,0x23 0x22 0x20 0x1c 0x27 0x29 0x25 0x29 ,
max :0x45 0x43 0x46 0x45 0x37 0x3b 0x3e 0x3e ,0x3f 0x3d 0x37 0x39 0x42 0x41 0x41 0x3e ,
0x47 0x47 0x41 0x41 0x3b 0x39 0x39 0x3e ,0x3e 0x3c 0x3a 0x36 0x43 0x44 0x40 0x45 ,
range:0x38 0x32 0x35 0x34 0x35 0x36 0x35 0x39 ,0x36 0x34 0x36 0x37 0x36 0x35 0x34 0x34 ,
0x37 0x37 0x33 0x36 0x36 0x37 0x35 0x35 ,0x35 0x34 0x34 0x34 0x37 0x36 0x35 0x37 ,
the write training result:
DQS0:0x2f, DQS1:0x18, DQS2:0x1d, DQS3:0xa,
min :0x78 0x7b 0x7d 0x7a 0x6b 0x6f 0x73 0x73 0x72 ,0x5c 0x57 0x54 0x53 0x5d 0x5c 0x5c 0x5d 0x58 ,
0x67 0x67 0x62 0x5f 0x58 0x58 0x59 0x5e 0x5e ,0x53 0x4f 0x4d 0x48 0x53 0x56 0x4f 0x57 0x4e ,
mid :0x93 0x95 0x98 0x95 0x85 0x8a 0x8e 0x8d 0x8b ,0x78 0x73 0x6e 0x6d 0x79 0x76 0x78 0x77 0x72 ,
0x82 0x82 0x7c 0x7a 0x73 0x72 0x73 0x78 0x79 ,0x6d 0x69 0x67 0x62 0x6e 0x70 0x6b 0x72 0x68 ,
max :0xaf 0xb0 0xb4 0xb1 0xa0 0xa5 0xa9 0xa8 0xa5 ,0x94 0x90 0x89 0x87 0x95 0x91 0x94 0x92 0x8d ,
0x9d 0x9e 0x97 0x95 0x8e 0x8d 0x8e 0x93 0x95 ,0x87 0x83 0x81 0x7c 0x8a 0x8b 0x88 0x8e 0x83 ,
range:0x37 0x35 0x37 0x37 0x35 0x36 0x36 0x35 0x33 ,0x38 0x39 0x35 0x34 0x38 0x35 0x38 0x35 0x35 ,
0x36 0x37 0x35 0x36 0x36 0x35 0x35 0x35 0x37 ,0x34 0x34 0x34 0x34 0x37 0x35 0x39 0x37 0x35 ,
cs 1:
CA Training result:
cs:0 min :0x54 0x50 0x49 0x43 0x49 0x3e 0x4e ,0x4f 0x49 0x47 0x3e 0x48 0x3e 0x4c ,
cs:0 mid :0x90 0x8f 0x85 0x82 0x85 0x7e 0x7e ,0x8c 0x89 0x82 0x7f 0x82 0x7f 0x7c ,
cs:0 max :0xcc 0xce 0xc2 0xc2 0xc1 0xbf 0xae ,0xc9 0xca 0xbd 0xc0 0xbd 0xc1 0xac ,
cs:0 range:0x78 0x7e 0x79 0x7f 0x78 0x81 0x60 ,0x7a 0x81 0x76 0x82 0x75 0x83 0x60 ,
cs:1 min :0x4f 0x57 0x45 0x49 0x48 0x46 0x51 ,0x4e 0x51 0x45 0x48 0x48 0x48 0x4f ,
cs:1 mid :0x90 0x92 0x86 0x84 0x87 0x80 0x83 ,0x8f 0x8c 0x85 0x81 0x88 0x84 0x81 ,
cs:1 max :0xd2 0xcd 0xc7 0xbf 0xc7 0xbb 0xb6 ,0xd1 0xc8 0xc6 0xbb 0xc9 0xc0 0xb4 ,
cs:1 range:0x83 0x76 0x82 0x76 0x7f 0x75 0x65 ,0x83 0x77 0x81 0x73 0x81 0x78 0x65 ,
outU-Boot SPL 2024.10-00926-gc7aafb20ce99 (Oct 15 2024 - 10:14:58 -0500)
Trying to boot from SPIChecking hash(es) for config config-1 … OK
Checking hash(es) for Image atf-1 … sha256+ OK
Checking hash(es) for Image u-boot … sha256+ OK
Checking hash(es) for Image fdt-1 … sha256+ OK
Checking hash(es) for Image atf-2 … sha256+ OK
NOTICE: BL31: v2.11.0(release):v2.11.0-753-geaaf26e3e
NOTICE: BL31: Built : 18:47:07, Oct 14 2024
NOTICE: BL31: Rockchip release version: v1.0U-Boot 2024.10-00926-gc7aafb20ce99 (Oct 15 2024 - 10:14:58 -0500)
Model: Radxa ROCK 3A
DRAM: 8 GiB (effective 7.7 GiB)
PMIC: RK809 (on=0x40, off=0x00)
Core: 343 devices, 31 uclasses, devicetree: separate
MMC: mmc@fe000000: 2, mmc@fe2b0000: 1, mmc@fe310000: 0
Loading Environment from nowhere… OK
In: serial@fe660000
Out: serial@fe660000
Err: serial@fe660000
Net: eth0: ethernet@fe010000Hit any key to stop autoboot: 0
Scanning for bootflows in all bootdevs
Seq Method State Uclass Part Name Filename
Scanning global bootmeth ‘efi_mgr’:
No EFI system partition
Failed to persist EFI variables
0 efi_mgr ready (none) 0
** Booting bootflow ‘’ with efi_mgr
Loading Boot0000 ‘mmc 0’ failed
EFI boot manager: Cannot load any image
Boot failed (err=-14)
Scanning bootdev ‘mmc@fe2b0000.bootdev’:
Scanning bootdev ‘mmc@fe310000.bootdev’:
1 extlinux ready mmc 1 mmc@fe310000.bootdev.part /boot/extlinux/extlinux.conf
** Booting bootflow ‘mmc@fe310000.bootdev.part_1’ with extlinux
Select kernel
1: Arch Linux
Enter choice: 1: Arch Linux
Retrieving file: /boot/Image
Retrieving file: /boot/initramfs-linux.img
append: console=ttyS0,115200 console=tty1 rw root=UUID=df42bbe6-9be9-483c-b56b-9bccbf67a65f
Retrieving file: /boot/dtbs/rockchip/rockchip/rk3568-rock-3a.dtb
Skipping fdtdir /boot/dtbs/rockchip/ for failure retrieving dtsFlattened Device Tree blob at eded39c0
Booting using the fdt blob at 0xeded39c0
Working FDT set to eded39c0
Loading Ramdisk to ec799000, end ececf5e8 … OK
Loading Device Tree to 00000000ec780000, end 00000000ec79839f … OK
Working FDT set to ec780000Starting kernel …
efi_free_pool: illegal free 0x00000000ececf040
efi_free_pool: illegal free 0x00000000ececc040
Those last 2 lines seem to be the problem. Does this suggest a ram memory problem? I can’t find any info on the internet about this issue or how to fix it.
U-boot can find the menu config, it can find the kernel, and when it tries to load the kernel I get this problem. The kernel does not continue past these 2 errors after waiting 30 minutes. Arch says it this kernel is built to support the device trees provided in /boot/dtbs. Nothing was changed in the rootfs except the extlinux.conf.
Anybody got an idea on what to do? Thanks
And if I’m able to get this working I can provide all the steps needed to get a full mainline vanilla Arch linux install running.
EDIT : After rebuilding u-boot without modifications (had made some for display but didn’t work) I get this error instead
append: initrd=/boot/initramfs-linux.img console=ttyS0,1500000 console=tty1 rw root=UUID=df42bbe6-9be9-483c-b56b-9bccbf67a65f
Retrieving file: /boot/dtbs/rockchip/rk3568-rock-3a.dtbFlattened Device Tree blob at 12000000
Booting using the fdt blob at 0x12000000
Working FDT set to 12000000
Loading Ramdisk to ec7a3000, end eced95e8 … OK
Loading Device Tree to 00000000ec782000, end 00000000ec7a217e … OK
Working FDT set to ec782000Starting kernel …
“Synchronous Abort” handler, esr 0x96000004, far 0x76b1ba0296fa8f6f
elr: 0000000000a8de50 lr : 0000000000a77f70 (reloc)
elr: 00000000eff9fe50 lr : 00000000eff89f70
x0 : 76b1ba0296fa8f6f x1 : 00000000effaad4c
x2 : 0000000000000010 x3 : 0000000000000007
x4 : 0000000000000000 x5 : 76b1ba0296fa8f6f
x6 : 00000000eccaf000 x7 : 0000000000000004
x8 : 00000000ededd0d0 x9 : 00000000ffffffd0
x10: 00000000ec79ffff x11: 00000000edf29b50
x12: 0000000000000003 x13: 00000000ec782000
x14: 0000000000000000 x15: 00000000ededd048
x16: 00000000eff6713c x17: 0000000000000000
x18: 00000000edef2d70 x19: 00000000eceb6040
x20: 00000000eff12f58 x21: 00000000effaad4c
x22: 0000000000200000 x23: 00000000edf40bd0
x24: 00000000effcabb8 x25: 00000000eceda000
x26: 00000000edf2ffa0 x27: 00000000ecedb000
x28: 00000000effcabb8 x29: 00000000ededce80Code: eb04005f 54000061 52800000 14000006 (386468a3)
Resetting CPU …resetting …
