My intention is to configure device so that I could upload OS/tested application through TFTP/NFS during UBoot. I did it some time ago on different ARM device and I would like to continue to work like this.
MY STEPS:
I’ve connected device to PC (serial console and USB OTG).
rkdeveloptool ld shows device DevNo=1 Vid=0x2207,Pid=0x350a,LocationID=303 Maskrom - which from me means I can upload idbloader and u-boot.itb. No short-circuited pins, neither SD card.
Following this instruction - https://wiki.radxa.com/Rock3/install/spi.
- Downloaded given images (RK356X loader, ROCK 3A idbloader, ROCK 3A u-boot.itb)
- created spi_image (sequence of dd and parted calls)
- upload the loader (flash helper)
rkdeveloptool db rk356x_spl_loader_ddr1056_v1.12.109_no_check_todly.bin - erase flash
rkdeveloptool ef - upload created spi_image
rkdeveloptool wl 0 spi_image.img - then reset
In result - serial console content ends with
cs 1:
the read training result:
DQS0:0x38, DQS1:0x37, DQS2:0x3b, DQS3:0x36,
min : 0x8 0x8 0xb 0x8 0x1 0x3 0x5 0x3 , 0x6 0x4 0x1 0x1 0xb 0x9 0x9 0x6 ,
0xb 0xb 0x9 0x8 0x3 0x1 0x3 0x4 , 0x8 0x6 0x6 0x1 0xc 0xb 0x9 0xb ,
mid :0x25 0x25 0x27 0x25 0x1e 0x20 0x21 0x1f ,0x22 0x21 0x1e 0x1e 0x27 0x26 0x25 0x23 ,
0x29 0x29 0x26 0x26 0x21 0x1f 0x20 0x21 ,0x25 0x23 0x22 0x1f 0x28 0x29 0x26 0x29 ,
max :0x42 0x42 0x44 0x42 0x3b 0x3e 0x3e 0x3c ,0x3f 0x3f 0x3b 0x3c 0x44 0x44 0x42 0x40 ,
0x48 0x47 0x44 0x44 0x3f 0x3e 0x3d 0x3f ,0x43 0x41 0x3f 0x3e 0x45 0x48 0x44 0x47 ,
range:0x3a 0x3a 0x39 0x3a 0x3a 0x3b 0x39 0x39 ,0x39 0x3b 0x3a 0x3b 0x39 0x3b 0x39 0x3a ,
0x3d 0x3c 0x3b 0x3c 0x3c 0x3d 0x3a 0x3b ,0x3b 0x3b 0x39 0x3d 0x39 0x3d 0x3b 0x3c ,
the write training result:
DQS0:0x42, DQS1:0x35, DQS2:0x39, DQS3:0x2c,
min :0x61 0x64 0x66 0x63 0x5a 0x5e 0x5e 0x5f 0x5f ,0x53 0x53 0x50 0x4f 0x58 0x58 0x55 0x56 0x51 ,
0x59 0x5a 0x58 0x57 0x50 0x4f 0x4f 0x53 0x54 ,0x4c 0x4b 0x4a 0x47 0x50 0x51 0x4d 0x51 0x48 ,
mid :0x7d 0x7f 0x81 0x7e 0x76 0x79 0x79 0x7a 0x7a ,0x6f 0x6e 0x6b 0x6b 0x74 0x73 0x71 0x71 0x6d ,
0x75 0x76 0x73 0x72 0x6c 0x6a 0x6a 0x6e 0x70 ,0x68 0x67 0x66 0x63 0x6d 0x6e 0x69 0x6e 0x65 ,
max :0x9a 0x9b 0x9d 0x9a 0x92 0x95 0x95 0x95 0x95 ,0x8c 0x8a 0x86 0x88 0x90 0x8e 0x8e 0x8c 0x8a ,
0x92 0x92 0x8f 0x8e 0x89 0x86 0x86 0x8a 0x8c ,0x85 0x83 0x82 0x80 0x8b 0x8c 0x85 0x8b 0x83 ,
range:0x39 0x37 0x37 0x37 0x38 0x37 0x37 0x36 0x36 ,0x39 0x37 0x36 0x39 0x38 0x36 0x39 0x36 0x39 ,
0x39 0x38 0x37 0x37 0x39 0x37 0x37 0x37 0x38 ,0x39 0x38 0x38 0x39 0x3b 0x3b 0x38 0x3a 0x3b ,
CA Training result:
cs:0 min :0x45 0x40 0x3f 0x37 0x40 0x33 0x40 ,0x45 0x3d 0x3f 0x35 0x3d 0x33 0x40 ,
cs:0 mid :0x81 0x82 0x7c 0x7a 0x7b 0x76 0x6f ,0x81 0x7e 0x7a 0x77 0x77 0x76 0x6e ,
cs:0 max :0xbe 0xc5 0xb9 0xbe 0xb6 0xba 0x9f ,0xbe 0xc0 0xb5 0xb9 0xb2 0xba 0x9d ,
cs:0 range:0x79 0x85 0x7a 0x87 0x76 0x87 0x5f ,0x79 0x83 0x76 0x84 0x75 0x87 0x5d ,
cs:1 min :0x44 0x41 0x3c 0x3b 0x3d 0x36 0x3f ,0x42 0x3f 0x3b 0x37 0x39 0x36 0x3f ,
cs:1 mid :0x82 0x81 0x7b 0x7b 0x7b 0x76 0x6f ,0x81 0x7f 0x79 0x77 0x77 0x77 0x6f ,
cs:1 max :0xc0 0xc1 0xbb 0xbb 0xb9 0xb7 0xa0 ,0xc0 0xbf 0xb8 0xb8 0xb6 0xb8 0x9f ,
cs:1 range:0x7c 0x80 0x7f 0x80 0x7c 0x81 0x61 ,0x7e 0x80 0x7d 0x81 0x7d 0x82 0x60 ,
out
I was expecting something like U-Boot SPL board init.
I seen it when I flash SD card with your ubuntu XFCE image (this image had problem with X) - started when Recovery PINS 1-2 where connected.
What am I doing wrong? How to reach state when UBoot tells about press button to stop autoboot?
