Rock 3a does not enter maskroom mode
the most interesting thing is that via the android terminal I can go to the bootloader at least it seems to be but the command “sudo rkdeveloptool ld” always returns no device found.
Model: Rockchip RK3568 Evaluation Board
PreSerial: 2, raw, 0xfe660000
DRAM: 4 GiB
Sysmem: init
Relocation Offset: ed357000
Relocation fdt: eb9f8c48 - eb9fecd0
CR: M/C/I
Using default environment
no mmc device at slot 1
dwmmc@fe2b0000: 1 (SD), dwmmc@fe2c0000: 2, sdhci@fe310000: 0
Bootdev(atags): mmc 1
MMC1: Legacy, 52Mhz
PartType: EFI
DM: v1
boot mode: bootloader <-------- Here
Android 11.0, Build 2021.8, v2
Found DTB in boot part
DTB: rk-kernel.dtb
HASH(s): OK
ANDROID: fdt overlay OK
I2c0 speed: 100000Hz
vsel-gpios- not found! Error: -2
vdd_cpu init 900000 uV
PMIC: RK8090 (on=0x10, off=0x00)
vdd_logic init 900000 uV
vdd_gpu init 900000 uV
vdd_npu init 900000 uV
io-domain: OK
Model: Radxa ROCK 3 Model A
enter fastboot!
Rockchip UBOOT DRM driver version: v1.0.1
VOP have 1 active VP
vp0 have layer nr:6[0 2 4 1 3 5 ], primary plane: 4
vp1 have layer nr:0[], primary plane: 0
vp2 have layer nr:0[], primary plane: 0
disp info 0, type:11, id:0
hdmi@fe0a0000 disconnected
CLK: (sync kernel. arm: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
apll 1416000 KHz
dpll 780000 KHz
gpll 1188000 KHz
cpll 1000000 KHz
npll 1200000 KHz
vpll 24000 KHz
hpll 24000 KHz
ppll 200000 KHz
armclk 1416000 KHz
aclk_bus 150000 KHz
pclk_bus 100000 KHz
aclk_top_high 500000 KHz
aclk_top_low 400000 KHz
hclk_top 150000 KHz
pclk_top 100000 KHz
aclk_perimid 300000 KHz
hclk_perimid 150000 KHz
pclk_pmu 100000 KHz
Net: eth1: ethernet@fe010000
MMC error: The cmd index is 1, ret is -110…
mmc_init: -95, time 21
Enter fastboot…OK
now in the lsusb command it appears as xiaomi.
disconnecting the usb it disappears
it really seems to be the usb cable my fourth cable started to give a signal in windows it appears in the deposit manager only in linux it is appearing with xiaomi
but the app still pops up that it didn’t find the device
finally solved, thanks to everyone who helped me.
These were the steps I took in case someone has the same problem:
1. jumper two first pins
2. I took a USB-A Y cable for an external HD case (I took a USB-A Y cable for an external HD case).
!!! just be careful the unmarked usb is just for power
3. be careful with this switch, it has to be on the opposite side of the usb 3.0 (blue usb) on the board.
thanks for sharing this experience,
I would not trust this kind of usb cable, also there are some issues with some usb ports on laptops so it’s always worth to double check our setup :slight_smile:
