With the Zero 3E/W just around the corner, it’s a good idea to warm up on camera stuff before it launches.
Here are some basic instructions to stream video on Rock 3A, which i think will also work on Zero 3.
For the instructions, we are streaming video from the imx219 sensor without the tuning file.
The print screens are converted to jpeg to fit the size to upload the image.
Make sure the camera is detected
rock@rock3a:~$ ls /dev/video* /dev/video0 /dev/video2 /dev/video4 /dev/video6 /dev/video8 /dev/video1 /dev/video3 /dev/video5 /dev/video7 -
Check our Rock 3A IP which will be our server.
rock@rock3a:~/rockchip/gstreamer$ ifconfig eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 inet 192.168.254.187 netmask 255.255.0.0 broadcast 192.168.255.255 inet6 fe80::8a6b:bf67:85ab:9985 prefixlen 64 scopeid 0x20<link> inet6 2804:7f4:322a:3049:261f:9a4d:3ddc:73bf prefixlen 64 scopeid 0x0<global> inet6 2804:7f4:322a:3049:9d91:626d:6064:be1a prefixlen 64 scopeid 0x0<global> inet6 2804:7f4:322a:3049:29d6:d7f5:acf2:27c8 prefixlen 64 scopeid 0x0<global> inet6 2804:7f4:322a:3049:f8f4:5c30:a607:a544 prefixlen 64 scopeid 0x0<global> ether 2e:76:74:ce:a4:6e txqueuelen 1000 (Ethernet) RX packets 15737 bytes 1450280 (1.4 MB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 3513 bytes 72985157 (72.9 MB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 device interrupt 38 lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536 inet 127.0.0.1 netmask 255.0.0.0 inet6 ::1 prefixlen 128 scopeid 0x10<host> loop txqueuelen 1000 (Local Loopback) RX packets 338 bytes 22652 (22.6 KB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 338 bytes 22652 (22.6 KB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 wlan0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500 ether 18:93:7f:b3:d9:e2 txqueuelen 1000 (Ethernet) RX packets 0 bytes 0 (0.0 B) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 2 bytes 240 (240.0 B) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
Pre-requisites:
- rockchip mpp and rga
- gstreamer with rockchip rkmpp
- imx219
Building gstreamer rtsp server
rock@rock3a:~/rockchip/gstreamer$ mkdir rtsp-server
rock@rock3a:~/rockchip/gstreamer$ cd rtsp-server/
rock@rock3a:~/rockchip/gstreamer/rtsp-server$ wget https://gstreamer.freedesktop.org/src/gst-rtsp-server/gst-rtsp-server-1.20.3.tar.xz
rock@rock3a:~/rockchip/gstreamer/rtsp-server$ tar -xf gst-rtsp-server-1.20.3.tar.xz
rock@rock3a:~/rockchip/gstreamer/rtsp-server$ cd gst-rtsp-server-1.20.3/
rock@rock3a:~/rockchip/gstreamer/rtsp-server/gst-rtsp-server-1.20.3$ mkdir build && cd build
rock@rock3a:~/rockchip/gstreamer/rtsp-server/gst-rtsp-server-1.20.3/build$ meson --prefix=/usr --wrap-mode=nofallback -D buildtype=release -D package-origin=https://gstreamer.freedesktop.org/src/gstreamer/ -D package-name="GStreamer 1.20.3" ..
The Meson build system
Version: 0.61.2
Source dir: /home/rock/rockchip/gstreamer/rtsp-server/gst-rtsp-server-1.20.3
Build dir: /home/rock/rockchip/gstreamer/rtsp-server/gst-rtsp-server-1.20.3/build
Build type: native build
Project name: gst-rtsp-server
Project version: 1.20.3
C compiler for the host machine: cc (gcc 11.4.0 "cc (Ubuntu 11.4.0-1ubuntu1~22.04) 11.4.0")
C linker for the host machine: cc ld.bfd 2.38
Host machine cpu family: aarch64
Host machine cpu: aarch64
Compiler for C supports link arguments -Wl,-Bsymbolic-functions: YES
Compiler for C supports arguments -fvisibility=hidden: YES
Compiler for C supports arguments -fno-strict-aliasing: YES
Message: Disabling GLib cast checks
Compiler for C supports arguments -Wmissing-declarations: YES
Compiler for C supports arguments -Wmissing-prototypes: YES
Compiler for C supports arguments -Wredundant-decls: YES
Compiler for C supports arguments -Wundef: YES
Compiler for C supports arguments -Wwrite-strings: YES
Compiler for C supports arguments -Wformat: YES
Compiler for C supports arguments -Wformat-nonliteral: YES
Compiler for C supports arguments -Wformat-security: YES
Compiler for C supports arguments -Wold-style-definition: YES
Compiler for C supports arguments -Waggregate-return: YES
Compiler for C supports arguments -Winit-self: YES
Compiler for C supports arguments -Wmissing-include-dirs: YES
Compiler for C supports arguments -Waddress: YES
Compiler for C supports arguments -Wno-multichar: YES
Compiler for C supports arguments -Wdeclaration-after-statement: YES
Compiler for C supports arguments -Wvla: YES
Compiler for C supports arguments -Wpointer-arith: YES
Found pkg-config: /usr/bin/pkg-config (0.29.2)
Run-time dependency glib-2.0 found: YES 2.72.4
Run-time dependency gstreamer-1.0 found: YES 1.20.3
Run-time dependency gstreamer-rtsp-1.0 found: YES 1.20.1
Run-time dependency gstreamer-rtp-1.0 found: YES 1.20.1
Run-time dependency gstreamer-sdp-1.0 found: YES 1.20.1
Run-time dependency gstreamer-app-1.0 found: YES 1.20.1
Run-time dependency gstreamer-net-1.0 found: YES 1.20.3
Run-time dependency gstreamer-check-1.0 found: YES 1.20.3
Header <gst/gstconfig.h> has symbol "GST_DISABLE_GST_DEBUG" with dependency gstreamer-1.0: NO
Message: GStreamer debug system is enabled
Program g-ir-scanner found: YES (/usr/bin/g-ir-scanner)
Run-time dependency gobject-introspection-1.0 found: YES 1.72.0
Dependency gobject-introspection-1.0 found: YES 1.72.0 (cached)
Program g-ir-compiler found: YES (/usr/bin/g-ir-compiler)
Run-time dependency gstreamer-plugins-base-1.0 found: YES 1.20.1
Run-time dependency gstreamer-plugins-bad-1.0 found: YES 1.20.3
Found CMake: /usr/bin/cmake (3.22.1)
Run-time dependency libcgroup found: NO (tried pkgconfig and cmake)
Program /usr/libexec/gstreamer-1.0/gst-plugins-doc-cache-generator found: NO
../docs/meson.build:50: WARNING: GStreamer plugin inspector for documentation not found, can't update the cache
Program hotdoc found: NO
Message: Hotdoc not found, not building the documentation
Program scripts/extract-release-date-from-doap-file.py found: YES (/home/rock/rockchip/gstreamer/rtsp-server/gst-rtsp-server-1.20.3/scripts/extract-release-date-from-doap-file.py)
Message: Package release date: 2022-06-15
Configuring config.h using configuration
Build targets in project: 41
gst-rtsp-server 1.20.3
User defined options
buildtype : release
prefix : /usr
wrap_mode : nofallback
package-name : GStreamer 1.20.3
package-origin: https://gstreamer.freedesktop.org/src/gstreamer/
Found ninja-1.10.1 at /usr/bin/ninja
rock@rock3a:~/rockchip/gstreamer/rtsp-server/gst-rtsp-server-1.20.3/build$ ninja -j4
[105/105] Linking target examples/test-video-rtx
Installing gstreamer rtsp-server:
rock@rock3a:~/rockchip/gstreamer/rtsp-server/gst-rtsp-server-1.20.3/build$ sudo ninja install
sudo ldconfig
[sudo] password for rock:
[0/1] Installing files.
Installing gst/rtsp-server/libgstrtspserver-1.0.so.0.2003.0 to /usr/lib/aarch64-linux-gnu
Installing symlink pointing to libgstrtspserver-1.0.so.0.2003.0 to /usr/lib/aarch64-linux-gnu/libgstrtspserver-1.0.so.0
Installing symlink pointing to libgstrtspserver-1.0.so.0 to /usr/lib/aarch64-linux-gnu/libgstrtspserver-1.0.so
Installing gst/rtsp-server/GstRtspServer-1.0.gir to /usr/share/gir-1.0
Installing gst/rtsp-server/GstRtspServer-1.0.typelib to /usr/lib/aarch64-linux-gnu/girepository-1.0
Installing gst/rtsp-sink/libgstrtspclientsink.so to /usr/lib/aarch64-linux-gnu/gstreamer-1.0
Installing /home/rock/rockchip/gstreamer/rtsp-server/gst-rtsp-server-1.20.3/gst/rtsp-server/rtsp-auth.h to /usr/include/gstreamer-1.0/gst/rtsp-server
Installing /home/rock/rockchip/gstreamer/rtsp-server/gst-rtsp-server-1.20.3/gst/rtsp-server/rtsp-address-pool.h to /usr/include/gstreamer-1.0/gst/rtsp-server
Installing /home/rock/rockchip/gstreamer/rtsp-server/gst-rtsp-server-1.20.3/gst/rtsp-server/rtsp-context.h to /usr/include/gstreamer-1.0/gst/rtsp-server
Installing /home/rock/rockchip/gstreamer/rtsp-server/gst-rtsp-server-1.20.3/gst/rtsp-server/rtsp-params.h to /usr/include/gstreamer-1.0/gst/rtsp-server
Installing /home/rock/rockchip/gstreamer/rtsp-server/gst-rtsp-server-1.20.3/gst/rtsp-server/rtsp-sdp.h to /usr/include/gstreamer-1.0/gst/rtsp-server
Installing /home/rock/rockchip/gstreamer/rtsp-server/gst-rtsp-server-1.20.3/gst/rtsp-server/rtsp-thread-pool.h to /usr/include/gstreamer-1.0/gst/rtsp-server
Installing /home/rock/rockchip/gstreamer/rtsp-server/gst-rtsp-server-1.20.3/gst/rtsp-server/rtsp-media.h to /usr/include/gstreamer-1.0/gst/rtsp-server
Installing /home/rock/rockchip/gstreamer/rtsp-server/gst-rtsp-server-1.20.3/gst/rtsp-server/rtsp-media-factory.h to /usr/include/gstreamer-1.0/gst/rtsp-server
Installing /home/rock/rockchip/gstreamer/rtsp-server/gst-rtsp-server-1.20.3/gst/rtsp-server/rtsp-media-factory-uri.h to /usr/include/gstreamer-1.0/gst/rtsp-server
Installing /home/rock/rockchip/gstreamer/rtsp-server/gst-rtsp-server-1.20.3/gst/rtsp-server/rtsp-mount-points.h to /usr/include/gstreamer-1.0/gst/rtsp-server
Installing /home/rock/rockchip/gstreamer/rtsp-server/gst-rtsp-server-1.20.3/gst/rtsp-server/rtsp-permissions.h to /usr/include/gstreamer-1.0/gst/rtsp-server
Installing /home/rock/rockchip/gstreamer/rtsp-server/gst-rtsp-server-1.20.3/gst/rtsp-server/rtsp-stream.h to /usr/include/gstreamer-1.0/gst/rtsp-server
Installing /home/rock/rockchip/gstreamer/rtsp-server/gst-rtsp-server-1.20.3/gst/rtsp-server/rtsp-stream-transport.h to /usr/include/gstreamer-1.0/gst/rtsp-server
Installing /home/rock/rockchip/gstreamer/rtsp-server/gst-rtsp-server-1.20.3/gst/rtsp-server/rtsp-session.h to /usr/include/gstreamer-1.0/gst/rtsp-server
Installing /home/rock/rockchip/gstreamer/rtsp-server/gst-rtsp-server-1.20.3/gst/rtsp-server/rtsp-session-media.h to /usr/include/gstreamer-1.0/gst/rtsp-server
Installing /home/rock/rockchip/gstreamer/rtsp-server/gst-rtsp-server-1.20.3/gst/rtsp-server/rtsp-session-pool.h to /usr/include/gstreamer-1.0/gst/rtsp-server
Installing /home/rock/rockchip/gstreamer/rtsp-server/gst-rtsp-server-1.20.3/gst/rtsp-server/rtsp-token.h to /usr/include/gstreamer-1.0/gst/rtsp-server
Installing /home/rock/rockchip/gstreamer/rtsp-server/gst-rtsp-server-1.20.3/gst/rtsp-server/rtsp-client.h to /usr/include/gstreamer-1.0/gst/rtsp-server
Installing /home/rock/rockchip/gstreamer/rtsp-server/gst-rtsp-server-1.20.3/gst/rtsp-server/rtsp-server.h to /usr/include/gstreamer-1.0/gst/rtsp-server
Installing /home/rock/rockchip/gstreamer/rtsp-server/gst-rtsp-server-1.20.3/gst/rtsp-server/rtsp-server-object.h to /usr/include/gstreamer-1.0/gst/rtsp-server
Installing /home/rock/rockchip/gstreamer/rtsp-server/gst-rtsp-server-1.20.3/gst/rtsp-server/rtsp-server-prelude.h to /usr/include/gstreamer-1.0/gst/rtsp-server
Installing /home/rock/rockchip/gstreamer/rtsp-server/gst-rtsp-server-1.20.3/gst/rtsp-server/rtsp-onvif-server.h to /usr/include/gstreamer-1.0/gst/rtsp-server
Installing /home/rock/rockchip/gstreamer/rtsp-server/gst-rtsp-server-1.20.3/gst/rtsp-server/rtsp-onvif-client.h to /usr/include/gstreamer-1.0/gst/rtsp-server
Installing /home/rock/rockchip/gstreamer/rtsp-server/gst-rtsp-server-1.20.3/gst/rtsp-server/rtsp-onvif-media-factory.h to /usr/include/gstreamer-1.0/gst/rtsp-server
Installing /home/rock/rockchip/gstreamer/rtsp-server/gst-rtsp-server-1.20.3/gst/rtsp-server/rtsp-onvif-media.h to /usr/include/gstreamer-1.0/gst/rtsp-server
Installing /home/rock/rockchip/gstreamer/rtsp-server/gst-rtsp-server-1.20.3/build/meson-private/gstreamer-rtsp-server-1.0.pc to /usr/lib/aarch64-linux-gnu/pkgconfig
Testing the rtsp-server:
rock@rock3a:~/rockchip/gstreamer/rtsp-server$ cd examples/
rock@rock3a:~/rockchip/gstreamer/rtsp-server/gst-rtsp-server-1.20.3/build/examples
rock@rock3a:~/rockchip/gstreamer/rtsp-server/gst-rtsp-server-1.20.3/build/examples$ sudo ./test-launch "( videotestsrc ! video/x-raw,format=NV12,width=1920,height=1080 ! mpph264enc ! rtph264pay name=pay0 pt=96 )"
From our PC box, we can check the result using ffplay, like so:
ffplay -rtsp_transport tcp rtsp://192.168.254.187:8554/test
ffplay version 3.4.11-0ubuntu0.1 Copyright (c) 2003-2022 the FFmpeg developers
built with gcc 7 (Ubuntu 7.5.0-3ubuntu1~18.04)
configuration: --prefix=/usr --extra-version=0ubuntu0.1 --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --enable-gpl --disable-stripping --enable-avresample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librubberband --enable-librsvg --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libopencv --enable-libx264 --enable-shared
libavutil 55. 78.100 / 55. 78.100
libavcodec 57.107.100 / 57.107.100
libavformat 57. 83.100 / 57. 83.100
libavdevice 57. 10.100 / 57. 10.100
libavfilter 6.107.100 / 6.107.100
libavresample 3. 7. 0 / 3. 7. 0
libswscale 4. 8.100 / 4. 8.100
libswresample 2. 9.100 / 2. 9.100
libpostproc 54. 7.100 / 54. 7.100
Input #0, rtsp, from 'rtsp://192.168.254.187:8554/test': 0B f=0/0
Metadata:
title : Session streamed with GStreamer
comment : rtsp-server
Duration: N/A, start: 0.199989, bitrate: N/A
Stream #0:0: Video: h264 (High), yuv420p(progressive), 1920x1080, 30 fps, 30 tbr, 90k tbn, 60 tbc
73.39 M-V: -0.001 fd= 10 aq= 0KB vq= 309KB sq= 0B f=1/1
If everything is all right we can see the stream:
Now we can stream the contents of the imx219 camera (1920x1080 h264):
sudo ./test-launch "( v4l2src device=/dev/video0 io-mode=dmabuf ! video/x-raw,format=NV12,width=1920,height=1080,framerate=30/1 ! mpph264enc ! rtph264pay name=pay0 pt=96 )"
Here is the result:
As you can see, not perfect, there are some issues that can be resolved with the tunning file, like whitening and noise reduction but it is not as bad as the compressed image shown here (jpeg) and updated kernel.
