Hello. I’ve been trying to use an IMX-219 CSI camera with Rock 3A and Rock 3C.
My problem is that no matter what I do, the image is always dark green (on both boards and also 4SE).
Why would that matter? My current OS image is completely up-to-date.
I always do updates first thing after installing a new image.
Reading package lists... Done
Building dependency tree... Done
Calculating upgrade... Done
The following package was automatically installed and is no longer required:
yq
Use 'sudo apt autoremove' to remove it.
Because you’re using a cli image without a desktop, there are a lot of packages missing by default, and you can install the missing packages with the command sudo apt install task-rock3c
Huh? Why would they make the decision not to include some of the functionalities in CLI images for the 3 series? RK356X are too weak to handle a desktop environment in a usable way anyway so making it a requirement only wastes RAM and disk space.
I can confirm that installing said package (task-rock-3c, there’s a dash missing) did make the camera work properly, but…
I swear I’m not complaining just for the sake of it. I’m simply genuinely confused, especially since Raspberry Pi CLI images have full camera support no problem.
In general, we recommend using the desktop version of the image, cli version of the temporary support is not comprehensive, must be used cli, you need to install their own.
That is not what I’m asking. I understand what you’re saying. I understood what you said the first time.
What I’m asking is “why?”.
The 3 and 4 series aren’t performant enough to handle a desktop environment.
And hardware acceleration isn’t present anyway.
So why make a DE version in the first place?
Well… Maybe just try using the officially supported OS which is Debian Bullseye XFCE.
Also… The OV5647 is a crappy sensor all by itself, so don’t expect miracles…
New cameras? lol. Not even the current ones are working… Especially on the Rock 5 series… It’s like the support comes for a second and then disappears for months…
But I kinda get it. It’s visible that Radxa is quite strained when it comes to software development. Hopefully by the end of next year, the matter of software will be solved.
Until then, I guess I’ll stick to USB cameras only.
Yeah it looks like nobody cares there. When asking for help I mainly got a info that said “you need to buy the sdk to get help from us”.
On the rock5 I’m still tweaking stuff, but my kernel will have a few more goodies, like the imx462,imx477,imx708,imx519 support.
Just still having tons of problems
Sadly on the Rock3 side of things we never really got far, and rockchip just complains that I’m not buying the 10.000usd sdk to develop opensource stuff.
Ha! At least you’re smart enough to be able to tinker with the kernel! The best I can do was activating the overlays before rsetup was a thing. I can semi-understand the concepts involved in all of this, but I’m far from being able to do anything all by myself. No cams for me I guess…
Shame I’m stuck with four useless 4Ks that I wanted to use with the NPU for AI-assisted monitoring or control…
P.S. Rock 3 IMHO ain’t worth it anyway, neither from the performance per watt, nor from the price to performance ratio’s perspective…
