Using newest rock-2_bullseye_cli_b6 image after installing image to sd-card, and updating system using rsetup system update. After subsequence reboot to use Wi-Fi properly requires
sudo systemctl restart NetworkManager
otherwise in nmcli it shows
wlan0: unmanaged
“AICSemi AIC 8800D80”
wifi (usb), 88:00:02:00:00:01, hw, mtu 1500
sudo systemctl enable NetworkManager doesn’t fix the problem.
I have a similar problem! It occurs only after updating the system and I can’t cure it, there is also a problem with mounting /root when rebooting, it throws me into the shell and I mount it manually after which everything boots normally, the system is very unstable and raw, the visual slows down and glitches… I wanted to install Armbian but nothing works, Ubuntu also doesn’t work, no system except the official Debian (((
Armbian works now, some things are broken (overlays have the wrong prefix, no pcie) but the system works.
