|20:11:49 227|瑞芯微开发工具 v2.8.4.0 start run|
|20:12:17 934|RKDevTool v2.8.4.0 start run|
|20:12:38 577|Error:Loading firmware failed,err=-5|
|20:12:46 781|Layer<>: RunProc is ending, ret=0|
|20:12:50 210|Error:CheckDownloadItem--> is not existed!|
|20:12:51 469|Layer<>: RunProc is ending, ret=0|
|20:12:55 583|Error:Loading boot failed,err=-1|
|20:14:23 778|RKDevTool v2.8.4.0 start run|
|20:14:26 312|Error:RKU_Write-->WriteFile failed,bRet=0,err=31,size=31,write=0|
|20:14:48 348|INFO:RKU_ResetPipe-->DeviceIoControl OK|
|20:14:48 349|Error:RKU_Write-->WriteFile failed,bRet=0,err=31,size=31,write=0|
|20:14:48 350|Error:ReadDevicePartTableProc-->During checking gpt or parameter RKU_ReadLBA failed,err=-3|
|20:15:44 214|RKDevTool v2.8.4.0 start run|
|20:15:51 287|Error:RKU_Write-->WriteFile failed,bRet=0,err=995,size=31,write=0|
|20:15:53 297|ERROR:RKU_ResetPipe-->DeviceIoControl failed,err=31|
|20:15:53 301|Error:ReadDevicePartTableProc-->During checking gpt or parameter RKU_ReadLBA failed,err=-3|
|20:16:09 703|Error:RKU_Write-->WriteFile failed,bRet=0,err=31,size=31,write=0|
|20:16:31 740|INFO:RKU_ResetPipe-->DeviceIoControl OK|
|20:16:31 744|Error:RKU_Write-->WriteFile failed,bRet=0,err=31,size=31,write=0|
|20:16:31 745|<LAYER 1-5-2-1-3> ERROR:TestDevice-->RKU_TestDeviceReady failed,RetCode(-3),path=\\?\USB#VID_2207&PID_330C#8&DABAE1&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed}|
|20:16:37 759|Error:RKU_Write-->WriteFile failed,bRet=0,err=995,size=31,write=0|
|20:16:39 768|ERROR:RKU_ResetPipe-->DeviceIoControl failed,err=31|
|20:16:39 771|<LAYER 1-5-2-1-3> ERROR:TestDevice-->RKU_TestDeviceReady failed,RetCode(-3),path=\\?\USB#VID_2207&PID_330C#8&DABAE1&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed}|
|20:16:45 785|Error:RKU_Write-->WriteFile failed,bRet=0,err=995,size=31,write=0|
|20:16:47 803|ERROR:RKU_ResetPipe-->DeviceIoControl failed,err=31|
|20:16:47 807|<LAYER 1-5-2-1-3> ERROR:TestDevice-->RKU_TestDeviceReady failed,RetCode(-3),path=\\?\USB#VID_2207&PID_330C#8&DABAE1&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed}|
|20:17:25 017|Error:Loading firmware failed,err=-5|
|20:17:39 368|RKDevTool v2.8.4.0 start run|
|20:17:47 598|Error:Loading firmware failed,err=-5|
I still cannot get the program to do anything at all, even just loading the gpt images provided by radxa fails.
