I tried to use rkdeveloptool to backup the onboard flash.
checking to size with
fdisk -l show
Disk /dev/mmcblk1: 964 MiB, 1010827264 bytes, 1974272 sectors
so we have 1974272 sectors here.
So i run
rkdeveloptool rl 0 1974272 dump_with_rk_tool.img
and try to write it on a second device. The second device will not boot.
So i create a second image using
dd if=/dev/mmcblk1 of=/mnt_USB_stick/dump_with_dd.img
Write this to a new device works. The device boot.
1010827264 dump_with_dd.img
1010827264 dump_with_rk_tool.img
fdisk -l dump_with_rk_tool.img
The backup GPT table is corrupt, but the primary appears OK, so that will be used.
Disk dump.img: 964 MiB, 1010827264 bytes, 1974272 sectors
Units: sectors of 1 * 512 = 512 bytes
Disklabel type: gpt
Disk identifier: A330076C-5D56-49B2-8D57-1B1332C7517B
Device Start End Sectors Size Type
dump.img1 32768 262143 229376 112M EFI System
dump.img2 262144 1972319 1710176 835M Linux filesystem
fdisk -l dump_with_dd.img
Disk /mnt/dmp.img: 964 MiB, 1010827264 bytes, 1974272 sectors
Disklabel type: gpt
/mnt/dmp.img1 32768 262143 229376 112M EFI System
/mnt/dmp.img2 262144 1972319 1710176 835M Linux filesystem
Why will dumping the image using rkdevtool break the gpt or did i missed something?
