使用rk3308_loader_uart0_m0_emmc_port_support_sd_20190717.bin这个文件
可以正常烧录SD Nand,烧录后可以正常启动
但是烧录EMMC(我自己的板子上面焊接了EMMC)后,不能正常启动
我确定我的emmc工作正常,因为我用AndroidTool烧录firefly的ubuntu.img,可以正常启动
自己的板子为什么要用别人的loader?
用这个loader可以正常烧录,只是无法正常启动,打印信息如下:
U-Boot 2017.09-02383-g233a23e3ed (Aug 05 2020 - 08:33:06 +0000), Build: jenkins-linux-build-release-293
Model: Radxa ROCK Pi S
PreSerial: 0
DRAM: 254 MiB
Relocation Offset is: 0f91c000
vdd_core 1044000 uV
vdd-core init 1044000 uV
MMC: dwmmc@ff480000: 0, dwmmc@ff490000: 1
Using default environment
In: serial@ff0c0000
Out: serial@ff0c0000
Err: serial@ff0c0000
Bootdev(atags): mmc 1
PartType: EFI
get part misc fail -1
boot mode: normal
CLK:
apll 816000 KHz
dpll 1300000 KHz
vpll0 1179647 KHz
vpll1 903167 KHz
aclk_bus 185714 KHz
hclk_bus 100000 KHz
pclk_bus 100000 KHz
aclk_peri 185714 KHz
hclk_peri 100000 KHz
pclk_peri 100000 KHz
hclk_audio 98303 KHz
pclk_audio 98303 KHz
Net: Net Initialization Skipped
No ethernet found.
Hit key to stop autoboot(‘CTRL+C’): 1 0
starting USB…
USB0: Core Release: 3.10a
USB1: USB EHCI 1.00
scanning bus 0 for devices… 1 USB Device(s) found
scanning bus 1 for devices… 1 USB Device(s) found
scanning usb for storage devices… 0 Storage Device(s) found
Device 0: unknown device
mmc_init: -95, time 9
switch to partitions #0, OK
mmc1(part 0) is current device
Scanning mmc 1:1…
Found U-Boot script /boot.scr
reading /boot.scr
2641 bytes read in 3 ms (859.4 KiB/s)
Boot script loaded from mmc 1
reading /uEnv.txt
317 bytes read in 1 ms (309.6 KiB/s)
reading /initrd.img-4.4.143-55-rockchip-g6b7accbc999b
6067960 bytes read in 134 ms (43.2 MiB/s)
reading /vmlinuz-4.4.143-55-rockchip-g6b7accbc999b
10663944 bytes read in 236 ms (43.1 MiB/s)
reading /dtbs/4.4.143-55-rockchip-g6b7accbc999b/rockchip/rk3308-rock-pi-s.dtb
63554 bytes read in 5 ms (12.1 MiB/s)
reading /dtbs/4.4.143-55-rockchip-g6b7accbc999b/rockchip/overlay/rk3308-uart0.dtbo
382 bytes read in 7 ms (52.7 KiB/s)
Applying kernel provided DT overlay rk3308-uart0.dtbo
reading /dtbs/4.4.143-55-rockchip-g6b7accbc999b/rockchip/overlay/rockchip-fixup.scr
1814 bytes read in 8 ms (220.7 KiB/s)
Applying kernel provided DT fixup script (rockchip-fixup.scr)
initrdsize = 0x5c96f8
Booting using the fdt blob at 0x1f00000
reserving fdt memory region: addr=1f00000 size=75000
Loading Ramdisk to 0ef41000, end 0f50a6f8 … OK
Loading Device Tree to 000000000eec9000, end 000000000ef40fff … OK
Adding bank: 0x00200000 - 0x10000000 (size: 0x0fe00000)
Starting kernel …
WARNING: suspend_mode_handler: Not support call: 0x4
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.143-55-rockchip-g6b7accbc999b (root@431768422ca2) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Wed Jul 29 02:54:35 UTC 2020
[ 0.000000] Boot CPU: AArch64 Processor [410fd042]
[ 0.000000] Reserved memory: failed to reserve memory for node ‘drm-logo@00000000’: base 0x0000000000000000, size 0 MiB
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] PERCPU: Embedded 19 pages/cpu @ffffffc00ff58000 s40344 r8192 d29288 u77824
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 64008
[ 0.000000] Kernel command line: initrd=initrd.img-4.4.143-55-rockchip-g6b7accbc999b root=UUID=ee60d2e1-358c-467c-acc8-a147c5b38695 rootwait rw rootfstype=ext4 console=tty1 console=ttyS0,1500000n8 panic=10 consoleblank=0 loglevel=7
[ 0.000000] PID hash table entries: 1024 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.000000] software IO TLB [mem 0x09ec9000-0x0dec9000] (64MB) mapped at [ffffffc009ec9000-ffffffc00dec8fff]
[ 0.000000] Memory: 171564K/260096K available (6910K kernel code, 558K rwdata, 2492K rodata, 384K init, 522K bss, 88532K reserved, 0K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbdbfff0000 ( 246 GB)
[ 0.000000] .init : 0xffffff80089c0000 - 0xffffff8008a20000 ( 384 KB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008740000 ( 6912 KB)
[ 0.000000] .rodata : 0xffffff8008740000 - 0xffffff80089c0000 ( 2560 KB)
[ 0.000000] .data : 0xffffff8008a20000 - 0xffffff8008aab808 ( 559 KB)
[ 0.000000] fixed : 0xffffffbffe7fd000 - 0xffffffbffec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbffee00000 - 0xffffffbfffe00000 ( 16 MB)
[ 0.000000] memory : 0xffffffc000200000 - 0xffffffc010000000 ( 254 MB)
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[ 0.000007] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.000975] Console: colour dummy device 80x25
[ 0.002487] console [tty1] enabled
[ 0.002541] Calibrating delay loop (skipped), value calculated using timer frequency… 48.00 BogoMIPS (lpj=96000)
[ 0.002620] pid_max: default: 32768 minimum: 301
[ 0.002737] Security Framework initialized
[ 0.002783] AppArmor: AppArmor disabled by boot time parameter
[ 0.002876] Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
[ 0.002923] Mountpoint-cache hash table entries: 512 (order: 0, 4096 bytes)
[ 0.003716] Initializing cgroup subsys io
[ 0.003772] Initializing cgroup subsys memory
[ 0.003837] Initializing cgroup subsys devices
[ 0.003885] Initializing cgroup subsys freezer
[ 0.003931] Initializing cgroup subsys net_cls
[ 0.003975] Initializing cgroup subsys perf_event
[ 0.004021] Initializing cgroup subsys net_prio
[ 0.004076] Initializing cgroup subsys hugetlb
[ 0.004118] Initializing cgroup subsys pids
[ 0.004467] sched-energy: CPU device node has no sched-energy-costs
[ 0.004517] Invalid sched_group_energy for CPU0
[ 0.004556] CPU0: update cpu_capacity 1024
[ 0.004638] ASID allocator initialised with 65536 entries
[ 0.039903] Detected VIPT I-cache on CPU1
[ 0.039958] Invalid sched_group_energy for CPU1
[ 0.039963] CPU1: update cpu_capacity 1024
[ 0.039968] CPU1: Booted secondary processor [410fd042]
[ 0.051927] Detected VIPT I-cache on CPU2
[ 0.051967] Invalid sched_group_energy for CPU2
[ 0.051972] CPU2: update cpu_capacity 1024
[ 0.051976] CPU2: Booted secondary processor [410fd042]
[ 0.063971] Detected VIPT I-cache on CPU3
[ 0.064010] Invalid sched_group_energy for CPU3
[ 0.064014] CPU3: update cpu_capacity 1024
[ 0.064019] CPU3: Booted secondary processor [410fd042]
[ 0.064098] Brought up 4 CPUs
[ 0.064541] SMP: Total of 4 processors activated.
[ 0.064586] CPU: All CPU(s) started at EL2
[ 0.064767] Invalid sched_group_energy for CPU3
[ 0.064813] Invalid sched_group_energy for Cluster3
[ 0.064852] Invalid sched_group_energy for CPU2
[ 0.064891] Invalid sched_group_energy for Cluster2
[ 0.064930] Invalid sched_group_energy for CPU1
[ 0.064968] Invalid sched_group_energy for Cluster1
[ 0.065005] Invalid sched_group_energy for CPU0
[ 0.065043] Invalid sched_group_energy for Cluster0
[ 0.065662] devtmpfs: initialized
[ 0.083077] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.083181] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.083673] pinctrl core: initialized pinctrl subsystem
[ 0.084986] NET: Registered protocol family 16
[ 0.096131] cpuidle: using governor menu
[ 0.096217] Registered FIQ tty driver
[ 0.096583] vdso: 2 pages (1 code @ ffffff8008746000, 1 data @ ffffff8008a24000)
[ 0.096681] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.096937] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.099843] console [pstore-1] enabled
[ 0.099887] pstore: Registered ramoops as persistent store backend
[ 0.099933] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[ 0.139679] vcc_1v8: regulator get failed, ret=-517
[ 0.140562] vcc_1v8_codec: regulator get failed, ret=-517
[ 0.141406] vcc_1v8: supplied by vcc_io
[ 0.141523] vcc_1v8_codec: supplied by vcc_io
[ 0.143728] SCSI subsystem initialized
[ 0.144366] usbcore: registered new interface driver usbfs
[ 0.144479] usbcore: registered new interface driver hub
[ 0.144620] usbcore: registered new device driver usb
[ 0.144810] media: Linux media interface: v0.10
[ 0.144899] Linux video capture interface: v2.00
[ 0.145056] pps_core: LinuxPPS API ver. 1 registered
[ 0.145098] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti [email protected]
[ 0.145192] PTP clock support registered
[ 0.146375] Advanced Linux Sound Architecture Driver Initialized.
[ 0.147162] Bluetooth: Core ver 2.21
[ 0.147252] NET: Registered protocol family 31
[ 0.147294] Bluetooth: HCI device and connection manager initialized
[ 0.147347] Bluetooth: HCI socket layer initialized
[ 0.147394] Bluetooth: L2CAP socket layer initialized
[ 0.147460] Bluetooth: SCO socket layer initialized
[ 0.148085] NetLabel: Initializing
[ 0.148132] NetLabel: domain hash size = 128
[ 0.148172] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.148271] NetLabel: unlabeled traffic allowed by default
[ 0.148935] rockchip-cpuinfo cpuinfo: Serial : e7b1e76a6526f5f3
[ 0.149578] clocksource: Switched to clocksource arch_sys_counter
[ 0.161879] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.161969] missing polling-delay-passive property
[ 0.162011] failed to build thermal zone soc_thermal: -22
[ 0.162360] NET: Registered protocol family 2
[ 0.163093] TCP established hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.163183] TCP bind hash table entries: 2048 (order: 3, 32768 bytes)
[ 0.163268] TCP: Hash tables configured (established 2048 bind 2048)
[ 0.163389] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.163451] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.163733] NET: Registered protocol family 1
[ 0.164326] Trying to unpack rootfs image as initramfs…
[ 0.610023] Freeing initrd memory: 5924K
[ 0.610688] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.614530] audit: initializing netlink subsys (disabled)
[ 0.614681] audit: type=2000 audit(0.612:1): initialized
[ 0.615522] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.624899] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.625747] fuse init (API version 7.23)
[ 0.630485] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 0.630740] io scheduler noop registered
[ 0.630792] io scheduler deadline registered (default)
[ 0.631013] io scheduler cfq registered
[ 0.636342] dma-pl330 ff2c0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.636437] dma-pl330 ff2c0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 0.638954] dma-pl330 ff2d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.639045] dma-pl330 ff2d0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 0.639456] rockchip-pvtm ff000000.grf:pmu-pvtm: failed to get rst 0 pmu
[ 0.639633] rockchip-pvtm ff00c000.syscon:pvtm: failed to get rst 0 core
[ 0.641144] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[ 0.643457] console [ttyS0] disabled
[ 0.643573] ff0a0000.serial: ttyS0 at MMIO 0xff0a0000 (irq = 11, base_baud = 1500000) is a 16550A
[ 0.720874] console [ttyS0] enabled
[ 0.722407] ff0e0000.serial: ttyS4 at MMIO 0xff0e0000 (irq = 12, base_baud = 5078125) is a 16550A
[ 0.724221] [drm] Initialized drm 1.1.0 20060810
[ 0.727187] Unable to detect cache hierarchy for CPU 0
[ 0.728807] brd: module loaded
[ 0.736405] loop: module loaded
[ 0.737169] SCSI Media Changer driver v0.25
[ 0.739777] rk_gmac-dwmac ff4e0000.ethernet: clock input or output? (output).
[ 0.740469] rk_gmac-dwmac ff4e0000.ethernet: Can not read property: tx_delay.
[ 0.741137] rk_gmac-dwmac ff4e0000.ethernet: set tx_delay to 0x30
[ 0.741767] rk_gmac-dwmac ff4e0000.ethernet: Can not read property: rx_delay.
[ 0.742437] rk_gmac-dwmac ff4e0000.ethernet: set rx_delay to 0x10
[ 0.743022] rk_gmac-dwmac ff4e0000.ethernet: integrated PHY? (no).
[ 0.748880] rk_gmac-dwmac ff4e0000.ethernet: init for RMII
[ 0.749517] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 0.750021] Ring mode enabled
[ 0.750325] DMA HW capability register supported
[ 0.750736] Normal descriptors
[ 0.751086] RX Checksum Offload Engine supported (type 2)
[ 0.751601] TX Checksum insertion supported
[ 0.752009] Wake-Up On Lan supported
[ 0.752417] Enable RX Mitigation via HW Watchdog Timer
[ 1.202272] libphy: stmmac: probed
[ 1.202639] eth%d: PHY ID 0000ffff at 0 IRQ POLL (stmmac-0:00) active
[ 1.203247] eth%d: PHY ID 0000ffff at 1 IRQ POLL (stmmac-0:01)
[ 1.203797] eth%d: PHY ID 0000ffff at 2 IRQ POLL (stmmac-0:02)
[ 1.204348] eth%d: PHY ID 0000ffff at 3 IRQ POLL (stmmac-0:03)
[ 1.204898] eth%d: PHY ID 0000ffff at 4 IRQ POLL (stmmac-0:04)
[ 1.205449] eth%d: PHY ID 0000ffff at 5 IRQ POLL (stmmac-0:05)
[ 1.206042] eth%d: PHY ID 0000ffff at 6 IRQ POLL (stmmac-0:06)
[ 1.206596] eth%d: PHY ID 0000ffff at 7 IRQ POLL (stmmac-0:07)
[ 1.207148] eth%d: PHY ID 0000ffff at 8 IRQ POLL (stmmac-0:08)
[ 1.207698] eth%d: PHY ID 0000ffff at 9 IRQ POLL (stmmac-0:09)
[ 1.208249] eth%d: PHY ID 0000ffff at 10 IRQ POLL (stmmac-0:0a)
[ 1.208808] eth%d: PHY ID 0000ffff at 11 IRQ POLL (stmmac-0:0b)
[ 1.209366] eth%d: PHY ID 0000ffff at 12 IRQ POLL (stmmac-0:0c)
[ 1.209951] eth%d: PHY ID 0000ffff at 13 IRQ POLL (stmmac-0:0d)
[ 1.210512] eth%d: PHY ID 0000ffff at 14 IRQ POLL (stmmac-0:0e)
[ 1.211070] eth%d: PHY ID 0000ffff at 15 IRQ POLL (stmmac-0:0f)
[ 1.211629] eth%d: PHY ID 0000ffff at 16 IRQ POLL (stmmac-0:10)
[ 1.212187] eth%d: PHY ID 0000ffff at 17 IRQ POLL (stmmac-0:11)
[ 1.212746] eth%d: PHY ID 0000ffff at 18 IRQ POLL (stmmac-0:12)
[ 1.213305] eth%d: PHY ID 0000ffff at 19 IRQ POLL (stmmac-0:13)
[ 1.213879] eth%d: PHY ID 0000ffff at 20 IRQ POLL (stmmac-0:14)
[ 1.214440] eth%d: PHY ID 0000ffff at 21 IRQ POLL (stmmac-0:15)
[ 1.214999] eth%d: PHY ID 0000ffff at 22 IRQ POLL (stmmac-0:16)
[ 1.215557] eth%d: PHY ID 0000ffff at 23 IRQ POLL (stmmac-0:17)
[ 1.216116] eth%d: PHY ID 0000ffff at 24 IRQ POLL (stmmac-0:18)
[ 1.216674] eth%d: PHY ID 0000ffff at 25 IRQ POLL (stmmac-0:19)
[ 1.217233] eth%d: PHY ID 0000ffff at 26 IRQ POLL (stmmac-0:1a)
[ 1.217813] eth%d: PHY ID 0000ffff at 27 IRQ POLL (stmmac-0:1b)
[ 1.218373] eth%d: PHY ID 0000ffff at 28 IRQ POLL (stmmac-0:1c)
[ 1.218932] eth%d: PHY ID 0000ffff at 29 IRQ POLL (stmmac-0:1d)
[ 1.219490] eth%d: PHY ID 0000ffff at 30 IRQ POLL (stmmac-0:1e)
[ 1.220048] eth%d: PHY ID 0000ffff at 31 IRQ POLL (stmmac-0:1f)
[ 1.221817] Rockchip WiFi SYS interface (V1.00) …
[ 1.222729] ff400000.usb supply vusb_d not found, using dummy regulator
[ 1.223432] ff400000.usb supply vusb_a not found, using dummy regulator
[ 1.453635] dwc2 ff400000.usb: EPs: 10, dedicated fifos, 972 entries in SPRAM
[ 1.454860] dwc2 ff400000.usb: DWC OTG Controller
[ 1.455353] dwc2 ff400000.usb: new USB bus registered, assigned bus number 1
[ 1.456049] dwc2 ff400000.usb: irq 20, io mem 0xff400000
[ 1.456737] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.457379] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.458109] usb usb1: Product: DWC OTG Controller
[ 1.458564] usb usb1: Manufacturer: Linux 4.4.143-55-rockchip-g6b7accbc999b dwc2_hsotg
[ 1.459322] usb usb1: SerialNumber: ff400000.usb
[ 1.460535] hub 1-0:1.0: USB hub found
[ 1.460944] hub 1-0:1.0: 1 port detected
[ 1.685070] phy phy-ff008000.syscon:[email protected]: charger = USB_SDP_CHARGER
[ 1.685795] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.686418] ehci-platform: EHCI generic platform driver
[ 1.690707] ehci-platform ff440000.usb: EHCI Host Controller
[ 1.691536] ehci-platform ff440000.usb: new USB bus registered, assigned bus number 2
[ 1.692417] ehci-platform ff440000.usb: irq 21, io mem 0xff440000
[ 1.701627] ehci-platform ff440000.usb: USB 2.0 started, EHCI 1.00
[ 1.702422] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.703065] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.703761] usb usb2: Product: EHCI Host Controller
[ 1.704230] usb usb2: Manufacturer: Linux 4.4.143-55-rockchip-g6b7accbc999b ehci_hcd
[ 1.704973] usb usb2: SerialNumber: ff440000.usb
[ 1.706127] hub 2-0:1.0: USB hub found
[ 1.706534] hub 2-0:1.0: 1 port detected
[ 1.707502] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.708145] ohci-platform: OHCI generic platform driver
[ 1.709006] ohci-platform ff450000.usb: Generic Platform OHCI controller
[ 1.709951] ohci-platform ff450000.usb: new USB bus registered, assigned bus number 3
[ 1.710833] ohci-platform ff450000.usb: irq 22, io mem 0xff450000
[ 1.769802] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.770445] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.771142] usb usb3: Product: Generic Platform OHCI controller
[ 1.771704] usb usb3: Manufacturer: Linux 4.4.143-55-rockchip-g6b7accbc999b ohci_hcd
[ 1.772446] usb usb3: SerialNumber: ff450000.usb
[ 1.773601] hub 3-0:1.0: USB hub found
[ 1.774013] hub 3-0:1.0: 1 port detected
[ 1.776426] i2c /dev entries driver
[ 1.777246] usbcore: registered new interface driver uvcvideo
[ 1.777825] USB Video Class driver (1.1.1)
[ 1.780465] rk_tsadcv2_temp_to_code: Invalid conversion table: code=4095, temperature=2147483647
[ 1.781622] rockchip-thermal ff1f0000.tsadc: tsadc is probed successfully!
[ 1.783612] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: [email protected]
[ 1.784448] Bluetooth: Virtual HCI driver ver 1.5
[ 1.785383] cpu cpu0: leakage=5
[ 1.785991] cpu cpu0: Failed to get pvtm
[ 1.787636] cpu cpu0: l=0 h=55000 hyst=5000 l_limit=1200000000 h_limit=1008000000
[ 1.789829] Synopsys Designware Multimedia Card Interface Driver
[ 1.791538] dwmmc_rockchip ff480000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.792276] dwmmc_rockchip ff480000.dwmmc: Using internal DMA controller.
[ 1.792923] dwmmc_rockchip ff480000.dwmmc: Version ID is 270a
[ 1.793523] dwmmc_rockchip ff480000.dwmmc: DW MMC controller at irq 23,32 bit host data width,256 deep fifo
[ 1.809710] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 1.826782] dwmmc_rockchip ff480000.dwmmc: 1 slots initialized
[ 1.827635] dwmmc_rockchip ff490000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.828362] dwmmc_rockchip ff490000.dwmmc: Using internal DMA controller.
[ 1.829009] dwmmc_rockchip ff490000.dwmmc: Version ID is 270a
[ 1.829649] dwmmc_rockchip ff490000.dwmmc: DW MMC controller at irq 24,32 bit host data width,256 deep fifo
[ 1.830618] dwmmc_rockchip ff490000.dwmmc: No vmmc regulator found
[ 1.831201] dwmmc_rockchip ff490000.dwmmc: No vqmmc regulator found
[ 1.845778] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 1.862782] dwmmc_rockchip ff490000.dwmmc: 1 slots initialized
[ 1.866031] dwmmc_rockchip ff4a0000.dwmmc: num-slots property not found, assuming 1 slot is available
[ 1.867046] dwmmc_rockchip ff4a0000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.867801] dwmmc_rockchip ff4a0000.dwmmc: Using internal DMA controller.
[ 1.868449] dwmmc_rockchip ff4a0000.dwmmc: Version ID is 270a
[ 1.869067] dwmmc_rockchip ff4a0000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 1.870114] dwmmc_rockchip ff4a0000.dwmmc: No vmmc regulator found
[ 1.870700] dwmmc_rockchip ff4a0000.dwmmc: No vqmmc regulator found
[ 1.872726] dwmmc_rockchip ff4a0000.dwmmc: allocated mmc-pwrseq
[ 1.885848] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 1.885857] mmc_host mmc1: Bus speed (slot 0) = 300000Hz (slot req 300000Hz, actual 300000HZ div = 0)
[ 1.901773] dwmmc_rockchip ff4a0000.dwmmc: 1 slots initialized
[ 1.906041] hidraw: raw HID events driver © Jiri Kosina
[ 1.907169] dwmmc_rockchip ff4a0000.dwmmc: card claims to support voltages below defined range
[ 1.908143] usbcore: registered new interface driver usbhid
[ 1.908713] usbhid: USB HID core driver
[ 1.909400] rockchip-dmc dmc: failed to get the count of devfreq-event in /dmc node
[ 1.910598] rockchip-dmc dmc: Failed to get leakage
[ 1.911233] rockchip-dmc dmc: Failed to get pvtm
[ 1.912097] rockchip-dmc dmc: failed to get vop bandwidth to dmc rate
[ 1.912743] rockchip-dmc dmc: failed to get vop pn to msch rl
[ 1.913319] rockchip-dmc dmc: don’t add devfreq feature
[ 1.916249] rknandc_base v1.1 2017-01-11
[ 1.916919] rksfc_base v1.1 2016-01-08
[ 1.921261] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[ 1.923382] mmc2: new high speed SDIO card at address 0001
[ 1.925129] dummy_codec dummy-codec: Unable to get mclk
[ 1.925843] mmc_host mmc1: Bus speed (slot 0) = 200000Hz (slot req 200000Hz, actual 200000HZ div = 0)
[ 1.926275] rk3308-acodec ff560000.acodec: Don’t need hp-ctl gpio
[ 1.926314] rk3308-acodec ff560000.acodec: Don’t need spk-ctl gpio
[ 1.926352] rk3308-acodec ff560000.acodec: Don’t need pa-drv gpio
[ 1.926357] rk3308-acodec ff560000.acodec: De-pop as much as possible
[ 1.926444] The acodec version is: a
[ 1.969750] mmc_host mmc1: Bus speed (slot 0) = 100000Hz (slot req 100000Hz, actual 100000HZ div = 0)
[ 1.983155] rk-multicodecs acodec-sound: rk3308-hifi <-> ff320000.i2s mapping ok
[ 1.985245] input: rockchip,rk3308-acodec Headphones as /devices/platform/acodec-sound/sound/card1/input0
[ 1.986984] u32 classifier
[ 1.987280] Netfilter messages via NETLINK v0.30.
[ 1.987795] ip_set: protocol 6
[ 1.989847] ip_tables: © 2000-2006 Netfilter Core Team
[ 1.990378] Initializing XFRM netlink socket
[ 1.991374] NET: Registered protocol family 10
[ 1.992937] ip6_tables: © 2000-2006 Netfilter Core Team
[ 1.993511] NET: Registered protocol family 17
[ 1.994051] NET: Registered protocol family 15
[ 1.994278] rk3308-acodec ff560000.acodec: Don’t need to change dac_output: 0
[ 1.995326] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 1.997238] Bridge firewalling registered
[ 1.997997] Bluetooth: RFCOMM TTY layer initialized
[ 1.998541] Bluetooth: RFCOMM socket layer initialized
[ 1.999109] Bluetooth: RFCOMM ver 1.11
[ 1.999548] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 2.000203] Bluetooth: HIDP socket layer initialized
[ 2.000737] 8021q: 802.1Q VLAN Support v1.8
[ 2.001237] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 2.002581] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 2.003121] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = rtl8723ds
[ 2.003889] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 2.004608] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 2.005533] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 0, flags = 0.
[ 2.006583] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 2.008230] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 2.008860] [BT_RFKILL]: Enter rfkill_rk_init
[ 2.010234] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 135.
[ 2.011144] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,power_gpio = 139.
[ 2.012081] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 140.
[ 2.012949] [BT_RFKILL]: bluetooth_platdata_parse_dt: clk_get failed!!!.
[ 2.013806] [BT_RFKILL]: Request irq for bt wakeup host
[ 2.014438] [BT_RFKILL]: ** disable irq
[ 2.015199] [BT_RFKILL]: bt_default device registered.
[ 2.015929] Key type dns_resolver registered
[ 2.017273] flash vendor_init_thread!
[ 2.017742] flash vendor storage:20170308 ret = -1
[ 2.020111] registered taskstats version 1
[ 2.086841] Key type encrypted registered
[ 2.088198] hctosys: unable to open rtc device (rtc0)
[ 2.104288] vcc_sd: disabling
[ 2.104622] vccio_sd: disabling
[ 2.105661] ALSA device list:
[ 2.105972] #0: Loopback 1
[ 2.106261] #1: rockchip,rk3308-acodec
[ 2.107387] Freeing unused kernel memory: 384K
Loading, please wait…
Starting version 241
[ 2.305752] usb 3-1: new full-speed USB device number 2 using ohci-platform
[ 2.492882] usb 3-1: not running at top speed; connect to a high speed hub
[ 2.500873] usb 3-1: New USB device found, idVendor=05e3, idProduct=0608
[ 2.501510] usb 3-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 2.502262] usb 3-1: Product: USB2.0 Hub
[ 2.504027] hub 3-1:1.0: USB hub found
[ 2.505817] hub 3-1:1.0: 4 ports detected
[ 2.801751] usb 3-1.1: new full-speed USB device number 3 using ohci-platform
[ 2.877736] usb 3-1.1: device descriptor read/64, error -62
Begin: Loading essential drivers … done.
Begin: Running /scripts/init-premount … done.
Begin: Mounting root file system … Begin: Running /scripts/local-top … done.
Begin: Running /scripts/local-premount … done.
Begin: Waiting for root file system … [ 3.061761] usb 3-1.1: device descriptor read/64, error -62
[ 3.237797] usb 3-1.1: new full-speed USB device number 4 using ohci-platform
[ 3.313769] usb 3-1.1: device descriptor read/64, error -62
[ 3.493726] usb 3-1.1: device descriptor read/64, error -62
[ 3.598923] usb 3-1-port1: attempt power cycle
Begin: Running /scripts/local-block … done.
[ 4.185754] usb 3-1.1: new full-speed USB device number 5 using ohci-platform
[ 4.593744] usb 3-1.1: device not accepting address 5, error -62
[ 4.665654] usb 3-1.1: new full-speed USB device number 6 using ohci-platform
[ 5.037842] vendor storage:20160801 ret = -1
[ 5.073752] usb 3-1.1: device not accepting address 6, error -62
[ 5.074933] usb 3-1-port1: unable to enumerate USB device
done.
Gave up waiting for root file system device. Common problems:
更改dts文件,修正emmc相关的配置,烧录后成功启动
