Rkddr: a rockchip ddr editor
well it is time to make this official. here is the new tool i have been working on lately. With this now it is possible to run rk3588 in ddr5-6400 speed which boosts the overall performance about 20% including gpu.
The tool is located here: https://github.com/hbiyik/rkddr
Below is the copy paste of the readme and what and how it does
rkddr
rkddr is a a DRAM configuration editor for rockchip based devices. To make use of the tool, simply run the sudo rkddr and navigate to the setting that the tui shows. When finished save the configuration, you do not have to do anything more, the tools automagically manages everything , (no need to dd it back to the block device).
TUI when working with blobk device
TUI when working with an idb file
To verify that the new settings are in place, at least for the frequency settings.
cat /sys/class/devfreq/dmc/available_frequencies
should give the new frequencies that you have configured.
working with binary types
if no specific arguments provided, rkddr automatically finds the correct location where the DDR configuration is located and shows it at the header of the tui.
if you want to edit the ddr configuration in a specific block device you can also achieve if with
sudo rkddr -d /dev/path-to-block-device (ie:sdc. or mtdblock1)
if you want to edit the ddr configuration an idblock on your filesystem (ie: u-boot artifacts)
sudo rkddr -i path-to-idblock-file
if you want to edit the ddr configuration in raw ddr blob (ie: the ddr blobs provided by rockchip at https://github.com/rockchip-linux/rkbin/tree/master/bin/rk35)
sudo rkddr -b path-to-raw-ddr-blob
whenever a change is made, a backup of your existing binary is backed up at folder ~/.rkddr/ , for future analysis or recovery
it is also beneficial to check out the help output in case of new features
sudo rkddr -h usage: PROG [options] options: -h, --help show this help message and exit -d, --device DEVICE Work on on the DDR blob inside the found IDB of the given block device -i, --idb IDB Work on on the DDR blob inside the given IDB file -b, --blob BLOB Work on on the DDR blob file given
what are TPL, IDB, DDR Blobs?
When Rockchip is booting, the chip searches a specific format called idblock or IDB for short as specific sector (64 (0x40)) each storage medium.
You can consider idblock as a zip or tar file containing 2 files. 1st is TPL (tertiary boot loader) 2nd is the SPL (secondary boot loader) .
So overall simplified boot process is as below:
`Bootrom (the chip) -> Idblock@64[First TPL -> Then SPL] -> U-boot@32768 -> Kernel and Linux/Android@partition``
In rockchip the first code executed by the CHIP inside the idblock, is TPL. And and this particular TPL is provided by rockchip as closed source, responsible of configuring the DDR memory. That TPL binary is also referred as DDR blob.
It is very beneficial to look at this page for details: https://opensource.rock-chips.com/wiki_Boot_option
Real World results
Since rockchip deals with a lot of OEMs, their blobs are not always tuned up to the spec which is solder as a DRAM chip on the board.
I have noticed that all DDR5 rk3588 boards are tuned with under-frequency, and some rk3528 board are severely capped. So be my guest on trying to find out more.
One thing to note is how dmc governor works on rockchip bsp kernel. When first DDR blob is initialized, it trains the given frequency, and 5 alternative ones.
Once it is trained with the main fequency, it passes those frequencies to kernel. At this point kernel has 2 frequency source, first is what DDR blob provides, 2nd is what is available in the dts.
What kernel does in this case is to iterate each frequency given by the blob, and fetches the voltage from from the DTS which has dts_frequency >= blob_freqency.
So dts dmc opp table is only a lookup table for the voltages. In some cases dts max frequency may not be enough for the blob frequency that the board can achieve, in this case to achieve higher frequncies maximum frequncy in the dts needs to be bumped. ie: https://github.com/hbiyik/linux/commit/c277791c584a3b53b95006f2ddb3ed06d1021f70, this is to achieve ddr5-6400 frequencies in rk3588.
Limitations
Currently only rk35xx boards are supported. It is technically possible to support earlier boards but i dont have any rk33xx so i dont want to blindly copy paste code. Any PR is weelcome int hat regard, you can refer to ddr V0 structure here: https://github.com/rockchip-linux/rkbin/blob/f43a462e7a1429a9d407ae52b4745033034a6cf9/tools/ddrbin_tool.py#L218C1-L219C20 (the part with v0_info)
Warnings
This is not a bios, and there is no clear CMOS jumper or battery. Meaning that if you do somehting wrong, your board can freeze. In such a case, you can manually write your idblock in backups using maskrom . Additionally not likely but possibly, things you enter might physically damage your hardware. You should be taking this responsibility when using this tool.
Like always ! Boogie for president ! :muscle:t2:Thanks !
I’ve also enabled this option for armbian rk3588 builds.
The DTS change is available as an overlay to be enabled through armbian-config. Then you can use boogie’s rkddr to set your DDR clock speed (please note that 6400MT/s == 3200MHz). Happy tinkering :slight_smile:
The related PR: https://github.com/armbian/linux-rockchip/pull/352
Great news, we did not had any reply from Rockchip about DDR5 vs DDR4 topic and You solved it!
How much it can gain from Rock5B (ddr4) vs Rock 5B+ (ddr5)? Any changes in temp and power consumption?
I have no DDR5 RK3588 to test :frowning:
Running at 6400MT/s I observed it consumed 0.5w more on load but it wasn’t some scientific tests I did here. Voltages weren’t changed so heat output shouldn’t be much more
Sounds good. Increased performance may save some power with faster operation.
Any real gain on DDR4 or its only usbale for DDR5?
No that is running at max speed already. Maybe some power saving possible through turning down opp table voltages according to the used modules.
though i agree with all there is always a possiblity that SCMI is just lying to us, and reporting the requested frequency as it was set, but in reality it might be running the frequency whatever the PVTPLL deems appropriate.
I guess we can never know know this unless someones hooks an oscilloscope or frequency analyzer to the board and inspect the ddr clock signal.
I don’t have this file, whole tree /sys/class/devfreq/dmc seems not available on my machine, running linux-image-rock-5b-plus kernel version 6.1.84-6.
Any hint about this?
it could be that your kernel config has not enabled dmc governor.
Looks ok to me:
# zcat /proc/config.gz | grep DMC
CONFIG_ARM_ROCKCHIP_DMC_DEVFREQ=y
Ok, there was something about GPU not tuned with right speed.
So thanks to changes 5B+ and 5T should perform better, anyone already got any benchmarks? difference should be visible even in geekbench.
Yes I wrote an article: https://sbcwiki.com/news/articles/tune-your-rk3588/
The Rock5-ITX models also get that performance boost. GPU 1GHz fix is merged to Armbian as of today too
It would be great for most users just to get optimised image and information what are the differences, timing and results. I don’t know how risky is to set new values for DDR5, but this still sounds not like overclocking but fix.
@tkaiser revisited his article with 6.8 kernel comparison, but he also used older 5.1 instead of BSP 6.1 (why it was skipped?). For now I briefly checked idle power consumption for bsp 6.1, mainline 6.14 and collabora release (I think it was 6.13) and still everything except bsp have +2.5W more idle power consumption. Still it’s not clear for me if Thomas fixes are already applied, is Armbian still patching only per device as mentioned in Your article and how to get that final configuration?
can You please try to make geekbenches using sbc-bench? It’s not perfect tool, but makes bunch of operation, easy to compare on web. It should clearly improve after those tweaks.
I forget about that one. Sure it also has DDR5 :slight_smile:
And this one is overclocking or optimisation? Is it also DDR5 only fix or generally for RK3588?
So for LPDDR5 if the TRM is to believed it would be an overclock for the SoC memory controller (without modifiying voltages) as it only is optimized for LPDDR5-5500MT/s but what boogie noticed is that not only does Radxa use faster RAM modules but also that you can edit the values to make use of the actual ram modules rated speeds. In his and my testing it has been stable but we can’t say if that applies to all and since TRM says LPDDR5-5500 we’re saying that it’s rather an overclock.
GPU is a bug fix.
Is it possible to apply the same boost on Rock 5B+ running Ubuntu? And what are the practical steps to do so?
Hello! I have a task to disable one memory chip, because of incorrect layout. Tell me, is it possible to do this by adjusting the parameters via ./ddrbin_tool for rk3588_ddr_lp4_1800MHz_lp5_2736MHz_v1.15.bin? What parameters need to be changed? Memory modules: MT53E512M32D2NP-046 WT:E
I also wonder how you can swap bits inside a DDR byte?
dq0-dq4
dq1-dq3
dq2-dq5
dq3-dq2
dq4-dq6
dq5-dq7
dq6-dq1
dq7-dq0
dq8-dq15
dq9-dq9
dq10-dq13
dq11-dq14
dq12-dq12
dq13-dq8
dq14-dq11
dq15-dq10
i am not sure exactly what parameters do but i can try to do some guess work, i might be wrong.
ddr blobs internally have versions. in latest versions it seems like ddr blobs do not have configuration values for dqs. if you open your rk3588 blob you wont see dq config. (should be version 4 or 5). But if you take an old example of version 2 blob like https://github.com/rockchip-linux/rkbin/blob/b1599ee3c6e84f76d3a066a4da51e0bfa2976168/bin/rk35/rk3528_ddr_1056MHz_2L_PCB_v1.07.bin, you can see the dq config is there.
If you really wanna play with dqs may be you can browser rkbin history and find an old version of rk3588 bin which already has dq config.
in the newer versions there is a hash config thing where, in such blobs you can see bank masks and rank maks. Those are 64bit integers, and each bit represent something that i dont know, may be that can help you to force to use specific chips
Yes, I went about this way, looked at early versions of blobs. I also looked into “ddrbin_tool.py”
there is such a structure
struct dq_map_info
dq_map_info = {
‘byte_map_0’ : 0,
‘byte_map_1’ : 0,
‘lp3_dq0_7_map’ : 0,
‘lp2_dq0_7_map’ : 0,
‘ddr4_dq_map_0’ : 0,
‘ddr4_dq_map_1’ : 0,
‘ddr4_dq_map_2’ : 0,
‘ddr4_dq_map_3’ : 0,
'ddr4_cs0_dq0_dq15_map': {'value': 0, 'num_base': 'hex', 'index': 'dq_map_index', 'position': 'ddr4_dq_map_0', 'shift': 0, 'mask': 0xffffffff, 'version': 2},
'ddr4_cs0_dq16_dq31_map': {'value': 0, 'num_base': 'hex', 'index': 'dq_map_index', 'position': 'ddr4_dq_map_1', 'shift': 0, 'mask': 0xffffffff, 'version': 2},
'ddr4_cs1_dq0_dq15_map': {'value': 0, 'num_base': 'hex', 'index': 'dq_map_index', 'position': 'ddr4_dq_map_2', 'shift': 0, 'mask': 0xffffffff, 'version': 2},
'ddr4_cs1_dq16_dq31_map': {'value': 0, 'num_base': 'hex', 'index': 'dq_map_index', 'position': 'ddr4_dq_map_3', 'shift': 0, 'mask': 0xffffffff, 'version': 2},
And I don’t understand how to encode 16 addresses (ddr4_cs0_dq0_dq15_map) with 4 bytes (‘mask’: 0xffffffff)
