Can anyone describe what could be the possible issue in logs on the right hand side? The board of the left hand side board is working fine but the other gives error to test device failed.
Make sure you are using a high quality cable and try another USB port with adequate power.
Also check in advanced Functions of RKDevTool if emmc is the default storage medium and not SPINOR which is usually by default.
https://wiki.t-firefly.com/en/ROC-RK3568-PC-SE/03-upgrade_firmware_with_flash.html
https://wiki.t-firefly.com/en/ROC-RK3568-PC-SE/01-bootmode.html
If you tried to flash this firmware on a non ROC-RK3568-PC-SE device like Rock 3A then good luck.
Well I can say that USB cable is okay. When checking for default storage medium under advanced options, an error comes which says “Get capabilitiy failed”. I can download boot successfully like MiniLoaderAll.bin. But test device fails. I think there might be some issue with the addresses related:
which board do you use, is rock3A ? if so you can install os refer to https://docs.radxa.com/en/rock3/rock3a/other-os/android/install-os?target=windows
